Old 12-31-2010, 03:34 PM   #76
pig rig
pig rig's Avatar
Re: My 84 CC Dually mod thread - there will be plenty of pics
just a thought it looks like your upper ball joints are riveted in? if so their factory you might want to replace them and the bottoms while its all tore apart
its just easier to do now then after you go get it alined and they can't aline it cause ball joints are bad
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 12-31-2010, 06:43 PM   #77
502ss
502ss's Avatar
Too late! Everything is already back together! pics coming next!
I did check the uppers and they were still great! The lowers were replaced last year just before I bought the truck so I think I am good for now! I didn't even need to change the rotors.(which were factory) but I have a connection for a huge discount on auto parts so I went ahead and put on new ones.
1984 CC Dually - 454 - TH400 - Western Hauler Edition
Big plans are coming!
My build thread HERE
502ss is offline   Reply With Quote
Old 12-31-2010, 06:49 PM   #78
502ss
502ss's Avatar
She is tucking tires now!
Ended up closer to a 5" drop in the nose (not sure why)
Old 12-31-2010, 07:22 PM   #79
blakeduren
Originally Posted by 502ss View Post
I do have plans to remove the top overload spring. My question is in regards to the flat spring located on the bottom of the spring pack. It is located right above the axle.
I wouldn't take that overload spring(s) out if you are hauling a 30 foot boat with it.
blakeduren is offline   Reply With Quote
Old 12-31-2010, 07:23 PM   #80
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Just get helper bags ( better and safer) just my .02
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 12-31-2010, 07:30 PM   #81
502ss
502ss's Avatar
The boat has about 800lbs. of tongue weight. When I towed last year she never even came close to touching the overload springs. Sitting still the a$$ end only went down an inch with the boat hooked up! I am sure I will be fine removing the overload spring!
Old 12-31-2010, 09:47 PM   #82
ratty 46
Then I wouldn't really worry about the spring deal. Go with the helper bags "just in case".
Nice stance in the front.
Ratty 46
ratty 46 is offline   Reply With Quote
Old 12-31-2010, 09:56 PM   #83
mooseknuckles
mooseknuckles's Avatar
sweet!
mooseknuckles is offline   Reply With Quote
Old 12-31-2010, 10:42 PM   #84
Matt Man
Matt Man's Avatar
what size tires do you have? I got my hangers in my truck but now the front sits to high! Looks like your gonna rub in the front.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 01-01-2011, 02:13 AM   #85
502ss
502ss's Avatar
Right now she still has stock 235/85-16. I will be purchasing some bolt on 19's and running either a 245/40-19 or a 245/45-19
Old 01-08-2011, 07:01 PM   #86
502ss
502ss's Avatar
Removed the two overload springs and two additional leafs leaving a total of 6. Now just waiting for the new U-bolts so I can bolt everything back together. Tomorrow I might start mocking up the new 31 gallon fuel tank mounts!
Some before and afters....
Old 01-10-2011, 01:05 PM   #87
Hulk Will Smash
Hulk Will Smash's Avatar
Truck's coming along nice! I like what you've done so far and that's a great vid of the Scarab. I have the overload spring out of my dually and it still pulls my 28 Pantera just fine. I'm probably going to put bags under the back for a "security blanket" though.
'87 R30 Crew Cab Dually
It's 11 PM, do you know where your IAC pintle is?
Hulk Will Smash is offline   Reply With Quote
Old 01-10-2011, 06:29 PM   #88
502ss
502ss's Avatar
Thanks man!
Did you just remove the overload springs? I removed the upper,lower overload plus two additional. With 800lbs of tongue weight I think I will definitely need a helper bag system.
Do you have a pic of your dually towing your boat? I love to see pics of dually's hauling boats! Hmmm, maybe a new thread topic??
Old 01-10-2011, 08:10 PM   #89
Hulk Will Smash
Great idea on the thread topic! The guy who I bought my truck had the overload removed, so I honestly don't know what he did exactly. I'll have to count the spring pack and see how many are left. I thought he said he pulled the overload and had another de-arched...
Anyhow, I'll have to dig the boat out of storage within the next couple weeks to pull the motor back out and then I'll take and post a pic!
Old 01-11-2011, 09:07 PM   #90
502ss
502ss's Avatar
What do you have for a power plant in the boat?
Old 01-13-2011, 06:43 PM   #91
502ss
502ss's Avatar
Came home to find some packages on the door step!
New C-notches
New U-Bolts
Old 01-13-2011, 06:45 PM   #92
502ss
502ss's Avatar
Started fitting the burb gas tank and decided to put the fuel filler behind the left tail light!
Old 01-13-2011, 07:09 PM   #93
Pop's C-10
Pop's C-10's Avatar
nice
Pop's C-10 is offline   Reply With Quote
Old 01-14-2011, 02:06 AM   #94
HarleyHauler
Is there any details or a thread on how to do this fuel filler mod behind the tail light?
HarleyHauler is offline   Reply With Quote
Old 01-14-2011, 09:32 AM   #95
502ss
502ss's Avatar
I haven't found one for the 73-87. Several guys have done it over in the 67-72 thread. I will be posting plenty of pictures as I do mine. There are several ways to do it. The filler I think will be the easy part, the hard part will be getting the light to hinge properly. I think I am going to modify a regular bed gas door hinge and attach it to the light housing. I will then use magnetic catches to keep the lens closed.
Stay tuned!
Old 01-14-2011, 02:24 PM   #96
budget78gmc
budget78gmc's Avatar
Nice
budget78gmc is offline   Reply With Quote
Old 01-14-2011, 04:47 PM   #97
ratty 46
As for the filler door ... check out the stock 1956 chevy 210 style set up ... it's "factory". It might give you some guidence.
Ratty 46
Old 01-14-2011, 11:11 PM   #98
502ss
502ss's Avatar
Made a little progress after work today. Tomorrow I cut!
Old 01-15-2011, 07:32 AM   #99
madcow75
madcow75's Avatar
I was thinking of a suburban tank myself. You must have removed the inboard shocks as they are in the way? Where did you move them?
madcow75 is offline   Reply With Quote
Old 01-15-2011, 08:07 AM   #100
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
Lookin Good!
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
