Old 05-10-2016, 08:04 AM   #76
piratexpress1369a
piratexpress1369a's Avatar
Re: Project: Tiki Express, '65 C10 Panel Truck Build
Nice score
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 01-17-2017, 04:16 PM   #77
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Well not much update on this but hopefully that will be changing this year. I just picked up a '55 Chevy 210, 4 door wagon. Before I get into that project, my plan is to get the panel on the road.
On MLK day, I finally finished the rear brake line and got the Wilwood prop valve mounted and frame lines hooked to it. Still need to finish the MC to prop valve lines. Here are a couple pics from the rear lines.
Oh, and a pic of the '55.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-18-2017, 09:20 AM   #78
piratexpress1369a
Nice score on the 55
63
Old 01-18-2017, 12:16 PM   #79
chevy_mike
chevy_mike's Avatar
Thanks!
Well I got the fittings and finished up the MC to Prop Valve lines. Very happy with them and have to say this NiCopp brake line is the easiest stuff I have ever worked with. So easy to bend and doesn't kink or rust!
Old 01-20-2017, 04:55 PM   #80
343CA
Very clean set up. I sold my 55 wagon to buy my 65 burb.
343CA is offline   Reply With Quote
Old 04-10-2017, 10:44 AM   #81
chevy_mike
chevy_mike's Avatar
Been making a little progress on the panel. Brakes are bled. Swapped out the fuel line from pump to carb and ran the pump into a fuel can. Put a new battery in and amazingly I got it started with little fanfare. First time is has run in 5 years.
Got a new power steering pump and painted that all up. Mocked up the pump. Need to do a little shimming of the bracket to line up the pulleys. Finally installed the rear doors weatherstripping, which I have had for 4 years.
Making progress...
Old 05-24-2017, 11:14 AM   #82
chevy_mike
chevy_mike's Avatar
Well, another minor update. I had pulled the fuel tank, not knowing there was about a half tank of 5 year old gas in it. Dang it was heavy but the transmission jack helped a lot. Drained the tank and it looks nice and clean inside. Bought a new sending unit, just to be proactive (don't really want to drop again) and glad I did as the old one was missing the filter sock on the end. Put all new rubber gas filler and fuel hoses on and got it back installed. Just need to change a couple more pieces of fuel line and that system should be done.
One step at a time...
Old 05-30-2017, 06:37 PM   #83
chevy_mike
chevy_mike's Avatar
Got some more done this past weekend. Finished up all the new rubber fuel lines. Ready to pour gas into the tank. Finished up the rear panhard bar. Got it adjusted to center the rear end at ride height. Worked on getting the PS pump shimmed to line up the pulleys, only to find out the pulley is bent. I did get the PS lines mocked into place.
Little by little, getting there.
Old 05-31-2017, 12:34 AM   #84
Captainfab
60-66 Nut
It's good to hear you are making some progress.
Old 06-08-2017, 11:11 AM   #85
chevy_mike
chevy_mike's Avatar
Well I am knocking out projects little by little. Ordered a replacement PS pulley from Summit and got things in alignment. Figured out the hose routing. Test fitted the new fan shroud and found the fan was sitting in to far so ordered a new spacer which should fix that. Since I had the front stuff off, I decided to replace the balancer, which I knew had issues as the timing marks never lined up. Glad I did!!!
Here is why old balancers should be replaced. The outer ring not only rotated but walked out. The pulley was keeping it on. From the backside you can see the rubber has a missing area and was pushing out as well. This was a disaster waiting to happen. This engine is from '81 (based on numbers ran) so it's not even as old as many ones from the '60's and '70's.
New one
Old 06-10-2017, 07:57 AM   #86
northern 85
northern 85's Avatar
Wow good catch!!!!
northern 85 is offline   Reply With Quote
Old 06-21-2017, 11:04 AM   #87
chevy_mike
chevy_mike's Avatar
Well knocking out little items bit by bit. Got the new fan shroud installed. Finished up the power steering lines and started getting the system bled. Still have a little air in the system to get worked out but mostly done. Put fuel in the tank and got it fired off.
Still have lots of little stuff to go but making progress.
Old 06-22-2017, 01:44 AM   #88
Captainfab
60-66 Nut
It sounds like it won't be long before you are driving this down the road
Old 01-24-2019, 11:34 AM   #89
The Rocknrod
Moderator
The Rocknrod's Avatar
What drop in inches are those rear springs?
Old 01-24-2019, 11:48 AM   #90
chevy_mike
chevy_mike's Avatar
Okay, a little update on the rear springs. The CPP "heavy duty" 4" drop springs were actually giving me closer to 6" of drop, even though CPP claims they are for Burb and Panels. I only had about an inch or so between the axle and frame. This made it look a little too low in the back compared to the front.
I talked to the guys at Early Classic Enterprise about this issue, as I only wanted a 4" drop. They suggest to people with burbs/panels, to order 1" less dropped spring then the actual drop you want. In my case I ordered a set of ECE springs in a 3" drop and actually got the 4" I wanted. Now I got the rake I wanted and way more axle to frame clearance.
Hope that helps.
Old 01-24-2019, 12:14 PM   #91
The Rocknrod
Moderator
That makes sense, thanks.
Old 01-28-2019, 12:24 PM   #92
chevy_mike
chevy_mike's Avatar
Well I have been doing some work the last couple weekends on the panel. Been getting some projects completed that I have put off for quite a while.... okay for the last couple years...
When I worked on it back in 2017, I found all of the ball joint and tie rods boots had cracked, even though these were all brand new parts. It really pissed me off as I knew I would have to disassemble the front suspension again, to replace the boots. Then I couldn't find replacements easily so it sat. I finally found some info to replace the boot with Prothane boots, which should last a very long time. I pulled apart the front end, which came apart much easier then it did with all of the original parts. Ok, check that project off.
The last thing I was working on in 2017 was drilling out the lower control arm u-bolt mounts. Stock was 7/16" and GM upgraded to 9/16" versions because they were having some breakage issues. I had gotten 3 out of 4 done but then my air drill died. I finally got the 4th one done.
I put in some different rear springs, since the CPP "Heavy Duty" 4" dropped springs gave 6-7" drop. Way more than I wanted. Replaced them with ECE 3" dropped springs, which gave me the 4" I wanted, per ECE recommendation. They said for panels/burbs, go with 1" less drop then what you want to end up with.
Now with the rear sitting how I wanted, the rear end was shifted off center, from side to side. Readjusted the panhard bar and got things centered up.
I also got the front sway bar remounted.
Last thing was dealing with the leaking calipers, where the hoses mount to the calipers. Back in 2017 I had bled everything and was dealing with those leaks. Tried new copper washers (even though the ones installed were new) and still no luck. Even replace one caliper, which I hoped stopped it. It seemed to but after sitting a couple days, was still leaking. I have read that many of these calipers when being rebuilt, the rebuilders are causing issues with the threads/mounting surface by removing the little "rings" or putting too much taper at the beginning of the threads. This is causing them not to seal correctly. I decided to upgrade from these and bought a set of Wilwood D52 replacement calipers. These are dual piston and it seems so far, no freaking leaks!!! Here's a pic of one installed.
At this point I think the suspension and brakes are all done.... finally. Next up is the cooling system. Ordered a new radiator and have new hoses. Hoping in the next couple months to finally have this on the road.
Old 02-24-2019, 08:31 PM   #93
chevy_mike
chevy_mike's Avatar
Been knocking out a few more things on the panel. Got the old radiator and water pump out. Replaced with new pump and radiator. Upper hose is good, need to sort out the lower hose.
Then I pulled the old exhaust manifolds off and put on a set of ceramic coated 2 1/2" exit ram horn manifolds. Fit great and looks good. Making progress and getting closer...
Old 02-25-2019, 12:40 AM   #94
Captainfab
60-66 Nut
Nice! Is that radiator from Auto City?
Old 02-25-2019, 02:16 PM   #95
chevy_mike
chevy_mike's Avatar
Yes, Auto City on Ebay. It is a nice unit and I like it being aluminum (with large tubes) but has a factory appearance. I am not a fan of the flat fabricated tank design, since when you open the hood, it stares you right in the face.
Old 02-26-2019, 01:07 AM   #96
Captainfab
60-66 Nut
How does the top hold down, the lower saddles and rubbers fit the tanks?
Old 02-26-2019, 03:09 PM   #97
chevy_mike
chevy_mike's Avatar
Sadly my panel was not originally with this radiator setup so I am not sure what the PO had done. The top mount wasn't even with my truck as someone made a sheet metal holder. I am not sure if there was different tank sizes or not. The top one I have fits okay but the rubber is fairly hard and doesn't quite let it sit all the way down. Where it bolts to the top of the core support, it's about a 1/2" up, so I am going to make a spacer. The lower saddles are not original to this truck and not sure if they are correct for this but they were big enough that the lower tank fit with a little room.
If you were swapping an original like kind for like kind, it would likely fit well.
Old 02-27-2019, 01:16 AM   #98
Captainfab
60-66 Nut
Thanks for the info
Old 03-25-2019, 11:34 AM   #99
chevy_mike
chevy_mike's Avatar
Finally had time to finish up the cooling system with new hoses. Got coolant in and fired it up for the first time in a years.
Next things is to get the shifter linkage slop down to a manageable level. Right now you can't tell which gear you have shifted into (manual car 4 speed trans). Then get the new Dakota Digital VHX gauges installed and mount the seats. After that, should be alignment and exhaust system and should be able to drive it.
Old 03-26-2019, 12:18 AM   #100
Captainfab
60-66 Nut
It sounds like you just might be cruisin in a Burb this summer!
