Old 04-04-2012, 10:11 PM   #76
oakstcustomz
oakstcustomz's Avatar
Re: How about some pics of Static dropped 60-66
Originally Posted by Swifty View Post
oakcustoms, how bouncey is your ride since you cut all your coils? I like your stance and if its not bad, i'll probably end up doing the same thing.
its rough on the road, feel every bump, pothole ect. i like it too but i need lower spindles to control the bumpsteer
1965 Chevy C-20 slammed 292 L6 TH400
1967 Chevy C-20 on 91 suburban frame project(wife's)
1972 Chevy K-20 Mild 350/th350/np2o5 dd
1952 Ford Customline 2door kustom project
1967 Cadillac Superior Hearse (wife's)
1998 GMC Saffari (wife's dd)
oakstcustomz is offline   Reply With Quote
Old 04-04-2012, 10:20 PM   #77
lolife99
67-72 parts collector,…
lolife99's Avatar
Originally Posted by oakstcustomz View Post
when you cut a coil spring not heat it it will increase the load capacity and make it ride horrible......now i do have a c-20 so the springs are heavy duty! i am saving up for a 5 lug and air bags
Did you remove the bumpstops front and rear?
Keith
Convert to disc brakes.
Old 04-05-2012, 10:37 AM   #78
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Here is a pic of the truck with cut coils before I started all the work. It rode great. Maybe the 3/4 tons dont I have no idea on that. but the 1/2 tom with 1.5 or 2 coil cut rode fine. Been too long to know how much I trimmed off.
GMR-PERFORMANCE is offline   Reply With Quote
Old 04-08-2012, 09:17 AM   #79
txinliner
txinliner's Avatar
this is betty lou
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390
txinliner is offline   Reply With Quote
Old 04-10-2012, 11:43 AM   #80
oakstcustomz
yea i removed the bumpstops in the rear but not the front
Old 04-23-2012, 02:40 PM   #81
RPM-Racing
RPM-Racing's Avatar
1965 GMC - 2.5 front / 3 in rear. Just finsihing up the project and looking for wheels.
RPM-Racing is offline   Reply With Quote
Old 04-23-2012, 07:31 PM   #82
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Great looking Truck!
Welcome to the forums.
66 C20 Service Truck:
Old 04-24-2012, 07:30 PM   #83
waspp
waspp's Avatar
Thats a great looking truck! I wonder if you could post a pic showing the full side view. I was planning on doing 2.5 front 3 rear drop.
Hal
waspp is offline   Reply With Quote
Old 04-25-2012, 08:07 PM   #84
Fastest32
Fastest32's Avatar
Here's mine. I cut 1 1/2 coils and used to springs in the rear.
Fastest32 is offline   Reply With Quote
Old 04-27-2012, 09:28 AM   #85
63swb
63swb's Avatar
Here's my 63. 5.5 frt and 5 in the rear.
63swb is offline   Reply With Quote
Old 04-28-2012, 12:47 AM   #86
Swifty
Swifty's Avatar
63swb, what did you do to get that much of a drop? the stance looks great!
Swifty is offline   Reply With Quote
Old 04-28-2012, 10:09 AM   #87
63swb
63swb's Avatar
It has 84 Chevy upper and lower control arms with the stock cross member. 2 1/2" dropped spindles and 3" springs. The rear has a 84 Chevy rear end and I made a set of trailing arms with 3" springs and 2" blocks.
Old 04-30-2012, 10:41 AM   #88
Ahmitchell1
Ahmitchell1 is offline   Reply With Quote
Old 04-30-2012, 03:41 PM   #89
DAN66
DAN66's Avatar
Here's my 3/5 drop. CPP springs.
'66 "Wrong bed" (Long stepper) 350, 4-speed
'66 Shortbed Stepside, 350/TH350
www.instagram.com/d_ray_pinstriping
DAN66 is offline   Reply With Quote
Old 05-16-2012, 11:41 AM   #90
Cuss in Custom
Cuss in Custom's Avatar
Both trucks static dropped. black one has 454 and blue one has 283.
Cuss in Custom is offline   Reply With Quote
Old 05-16-2012, 05:29 PM   #91
cori 64
cori 64's Avatar
here is mine
cori 64 is offline   Reply With Quote
Old 05-16-2012, 10:28 PM   #92
RPM-Racing
RPM-Racing's Avatar
Someone asked for a side view, this is the best I got right now. It is a leaf spring rearend, I am in the process of switching it over to a 5 bolt pattern so it is on jack stands right now. I have a 2 inch further drop in the rear to level it out.
Old 05-16-2012, 11:24 PM   #93
wagonslayer
Originally Posted by cori 64 View Post
here is mine
What did you do to lower yours, looks great !!
wagonslayer is offline   Reply With Quote
Old 05-17-2012, 09:55 AM   #94
cori 64
cori 64's Avatar
cut stock front springs,cut cpp 5inch springs one coil, cpp step notch and track bar ,when i put the new track bar in it rides stiffer ...weird maybe its too tight!!!,cpp shocks all around rides pretty good!!!....getting all the parts for air ride!!!!!
Old 05-17-2012, 10:41 AM   #95
MisterC
MisterC's Avatar
What are the stats on the one with the 454?
Front/Rear drop?
Wheel/Tire sizes?
That looks picture perfect to me!
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 05-17-2012, 11:03 PM   #96
Cuss in Custom
The fronts are 255/50 18's dropped 4 inches and the rears are 295/45 20's dropped about 6 inches. Drop springs and spindles on the front and drop springs and blocks in the rear.
Stock trailing arm setup with 12 bolt posi rear end geared high. Built 454 with 700r4 trans. 75mph at 1800 rpm.
Under dash air with newer compressor.
Old 05-19-2012, 05:02 PM   #97
Mia66GMC
Cool Re: How about some pics of Static dropped 60-66
My 66 Chevy C10 Step Side that I sold to Jay in Rhode Island.... This was a Bad Ass Truck! It will be missed!
Mia66GMC is offline   Reply With Quote
Old 05-25-2012, 11:08 PM   #98
1enick72
1enick72's Avatar
Just finished my drop 4.5/5.
Front - 2.5" drop spindles and 3" springs
Rear - 2" blocks and 3" springs
Just bought some new wheels today, can't wait to get tires mounted and on the truck.
1enick72 is offline   Reply With Quote
Old 05-26-2012, 02:14 PM   #99
Kerlijah
Kerlijah's Avatar
That is one of the coolest trucks I've ever seen! Love the photography, very nostalgic, makes me miss my '63 more than ever!
~Wooden Indian~
1979 C10 SWB, shaved bed rails, drip rails, tailgate handle. 350 w/ Comp cam, hydraulic lifters, Edelbrock Performer intake, Edelbrock 650 carb, Flowtech headers, Flowmaster 40s, turbo 350 w/stage 2 shift kit...so much fun!
Kerlijah is offline   Reply With Quote
Old 05-28-2012, 10:00 AM   #100
63MOUSE
2 inch dropped spindles and 1and half inch dropped springs in front and 3 inch dropped springs in back
63MOUSE is offline   Reply With Quote
