Old 05-14-2012, 09:09 PM   #76
HEAVY3100
Re: 1959 Fleetside REBORN
I can't wait to see the IRS installed
HEAVY3100 is offline   Reply With Quote
Old 05-14-2012, 09:37 PM   #77
shadow1967
shadow1967's Avatar
Kabwe,
I really didn't know what he meant by softlip, so I said what do you think. And this is what I got.
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
shadow1967 is offline   Reply With Quote
Old 05-14-2012, 10:39 PM   #78
Kabwe
Certified Car Nut
Kabwe's Avatar
Originally Posted by shadow1967 View Post
Kabwe,
Well you done good. In my opinion a the rolled softlip is a much nicer looking wheel. You lucked up buddy.lol
Kabwe is offline   Reply With Quote
Old 05-15-2012, 01:01 AM   #79
Kim57
Kim57's Avatar
Both color combos look real nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 05-15-2012, 09:02 PM   #80
_Ogre
_Ogre's Avatar
obviously i like the brighter of the 2 choices
shop air compressor timer
Old 05-15-2012, 10:28 PM   #81
shadow1967
shadow1967's Avatar
I wouldn't have expected that from a person with a chrome yellow truck!!!!
Could you really see me going to the hardware store and asking for 4 sheet of plywood and 20 2x4's. O'yes customer service rep." please put on your sunglasses, I don't want you to get retina damage.
Old 05-16-2012, 10:33 AM   #82
_Ogre
_Ogre's Avatar
Lol. I was going to suggest more yellow too
Old 05-16-2012, 10:58 AM   #83
hopped up
hopped up's Avatar
i love 58 car bumpers on these trucks!!
hopped up is offline   Reply With Quote
Old 05-16-2012, 06:35 PM   #84
ZR2RICK
ZR2RICK's Avatar
What year Impala bumper is that? great project by the way.
Learn to deal with reality, or reality will deal with you.
ZR2RICK is offline   Reply With Quote
Old 05-16-2012, 07:01 PM   #85
shadow1967
shadow1967's Avatar
Originally Posted by zr2rick View Post
what year impala bumper is that? Great project by the way.
1958
Old 05-16-2012, 11:06 PM   #86
shadow1967
shadow1967's Avatar
Well I knew the hammer had to drop. Mom and Dad's 50th wedding anniversary went off saturday without a hitch. Returning to work after a long weekend went south. So today I decided to go to work in the garage. Mounting the tires to the rearend. The pinion shaft is off center by 2.5".So now I need to cut the cradle and remove 2.5" and get an axle cut.
Old 05-17-2012, 07:48 AM   #87
buggy5872
buggy5872's Avatar
Why would you need to cut the cradle and get an axles made? It will work off set like that. I have been running a dana 44 in my 59 that is offset to the passengerside for years with not a bit of trouble. The u-joints will take care of it. Just make sure your driveshaft has enough room. Not sure what you already have set up on the frame. There are a lot of vehicles from the factory that are set up with the tranny output shaft centered in the csr and the rear off set one way or the other. Here's mine
buggy5872 is offline   Reply With Quote
Old 05-17-2012, 09:29 AM   #88
ricott
I think your plan to shrink the cradle is a good one. I faced this problem when we restomodded a 66 GTO. The 12 bolt was over 1/2 inch from center. I offset the engine/tranny by that amount. While I know it would have worked, I didn't want to introduce additional angles for the driveshaft to deal with (side to side and up and down). I believe in your case, the 2.5 pinion offset would result in a side to side driveline angle that would exceed 4 degrees, and would probably give you some vibration at speed. On a positive note, if you take 2.5 inches out of the cradle as proposed, it will give you additional fender lip/tire clearance. Finally, wouldn't you be able to make a passenger shaft work on the driver's side if they are now both the same? I love your build and the paint colors you like are very close to ones my wife wants on her 58 corvette that we are currently restomodding. Keep the pictures coming.
Ricky
ricott is offline   Reply With Quote
Old 05-17-2012, 09:30 AM   #89
Chevette
Chevette's Avatar
What Buggy says is true. I wouldn't mess with the rear cradle and axle. Many of the old mopars were built with an offset. If you look under the hood the engines were offset to match. I know 2.5" seems like a lot, but I would have a serious look at dealing with it the way it is. Whatever way you go, Good Luck with your build.
Chevette is offline   Reply With Quote
Old 05-17-2012, 09:50 AM   #90
ZR2RICK
ZR2RICK's Avatar
I looks like the ends on your bumper are straight,? all 58's have an upward curve on the ends.
Old 05-17-2012, 09:59 PM   #91
shadow1967
shadow1967's Avatar
You guys are correct If the camaro and corvette used u-joints anymore. they use driveshaft couplers that look like this. They pretty much want it at zero. And it will give me better rim selection if I want to go 20x10 rims later on, If I add a turbo.
Old 05-17-2012, 10:08 PM   #92
shadow1967
shadow1967's Avatar
you are looking to carefully. It is a picture of another truck that I had the colors change by a couple of good guys in the photoshop section of this forum. This picture is at an angle, but you can still see it goes passed the wheel area on the side, And i have not seen one used on the back. The side needs to be cut back about an 1.75".
Old 05-18-2012, 05:24 AM   #93
OKGMC4
OKGMC4's Avatar
A good CNC operator could machine an adapter that would bolt to the rear and accepts the U joint of your choice. Not sure how many machine shops can do heat treating. Just a thought. Could make building a new driveshaft easier down the road.
Offsets are normal. I centered my C4 rear but offset the engine right 1.75 inches to clear the steering shaft.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 05-20-2012, 09:32 PM   #94
shadow1967
shadow1967's Avatar
Well I got alot of little thing buttoned up on the front end. I still have the c-notches for the rack and to double up the upper shock mounts. Hopefully I can get to that during the week. I would like to do the dash nexts weekend (3 days). My goal is to have it running for El Segundo car show Aug. 25, 2012.
Old 05-20-2012, 10:00 PM   #95
_Ogre
_Ogre's Avatar
semi-permanent jack stands, good idea
clears a lot of floor space for working
Old 05-21-2012, 12:37 AM   #96
Kim57
Kim57's Avatar
Looking good.
Kim
My build thread
Old 05-21-2012, 02:36 PM   #97
1959Chev
1959Chev's Avatar
You are really making a lot of progress. I really like the 58 bumper. The stock one just looks like GM grabbed something off the shelf and threw it on.
2006 Chevy Silverado 3500(Duaramax/Allison) - DD
1997 Honda Civic - Work Beater
1981 Chevy Malibu - Race Car
1959 Chevy Truck - Project
http://67-72chevytrucks.com/vboard/s...d.php?t=481442
2006 Honda Accord - Wife's ride
1959Chev is offline   Reply With Quote
Old 05-26-2012, 03:53 AM   #98
shadow1967
shadow1967's Avatar
Memorial weekend!! Thanks to all the VETERENS out there!!!! Well here goes the dash. And I must add here a big thanks to chuckdriver....
http://67-72chevytrucks.com/vboard/s...=334552&page=3
He did all the leg work and so mine could be done quickly...Here is where I started.
Old 05-26-2012, 07:09 AM   #99
72ArizonaBurb
Your build is looking great. Good luck with the dash install. I recently put a 59 dash in my 1950 truck. It took me longer than 3 days but it wasn't difficult. Lots of trimming and fitting. I also got a lot of inspiration from Chuckdriver's build thread. Vintage air makes a set of A/C controls that will fit in the original AC/heat control space. You may want to check it out. Keep the pictures comming.
72ArizonaBurb is offline   Reply With Quote
Old 05-26-2012, 08:35 AM   #100
shadow1967
shadow1967's Avatar
Well I figured out where I going to cut. So here it is. We'll see how it goes later.
