Old 10-26-2013, 10:34 AM   #76
lowlife4life
lowlife4life's Avatar
Re: 60-66 hood and grille combos
Just fell in love with the 64 5 6 big truck grill does it bolt right in ? Great thread man much appreciated
lowlife4life is offline   Reply With Quote
Old 10-26-2013, 01:25 PM   #77
wjjeeper
wjjeeper's Avatar
Yes sir.
Follow me on Instagram
http://instagram.com/ryno._b
wjjeeper is offline   Reply With Quote
Old 10-27-2013, 03:13 AM   #78
Grizz1963
Grizz1963's Avatar
Great thread for guidance.
We originally wanted a 60/61 truck for the hood but ended up with a 66
I think that if parts were more available in the UK/Europe, I would have gone for the hood and possibly the grille too.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 10-27-2013, 04:04 PM   #79
markeb01
Senior Enthusiast
markeb01's Avatar
Probably been seen before, but here’s a 1960 GMC, 1962-66 Chevy hood, 1955 Buick grille bar inspired directly from post #36:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 11-03-2013, 02:31 AM   #80
SNTOS63
SNTOS63's Avatar
Talking Re: 60-66 hood and grille combos
Originally Posted by jonzcustomshop View Post
a cut down 1960 big truck grille and a 60 hood, and an uncut (as far as I can tell) 1960 big truck grille and a 61 hood
Would Love to get ahold of one of these 61-63 Big truck grills for my 63.. Can anyone point me in the right direction??
SNTOS63 is offline   Reply With Quote
Old 11-03-2013, 12:28 PM   #81
lowlife4life
eBay item number. 131036723756. it's a 456 but nice wish I could have it not sure how to add link
Old 11-03-2013, 05:15 PM   #82
chad64chevy
chad64chevy's Avatar
lowlife4life, you need to keep the headlight buckets from a 456 c10 grille and switch them for the c50/60 headlight buckets
chad64chevy is offline   Reply With Quote
Old 04-30-2014, 11:13 AM   #83
CaliberNick
THIS IS EXACTLY WHAT I WAS LOOKING FOR!!! WOOO
Thanks for putting this together, it is so awesome to see all the different grills and hoods, I would like to do a swap of some sort but was interested in seeing all the options out there, this definitely helped... but at the same time made it much more difficult because I can only choose one... Unless... I can buy more trucks, hahaha
Daily Driver: Dodge Caliber SRT4
Sunday Cruiser: '69 Camaro Convertible
Project Car: '62 Panel Build Thread
CaliberNick is offline   Reply With Quote
Old 04-30-2014, 02:43 PM   #84
seanrolandwood
60 hood,61 grill on a 66lwb fleet
seanrolandwood is offline   Reply With Quote
Old 04-30-2014, 06:58 PM   #85
hotrod66
hotrod66's Avatar
61 chevy grill with gmc letters and a 60 or 61 gmc hood
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 09-13-2014, 11:49 AM   #86
VictoriaHardware
VictoriaHardware's Avatar
My '66 C10 Suburban and it's older and bigger brother, a '65 C80 American LaFrance
VictoriaHardware is offline   Reply With Quote
Old 09-13-2014, 12:46 PM   #87
jbgroby
jbgroby's Avatar
Here's my '60 factory setup.
jbgroby is offline   Reply With Quote
Old 09-13-2014, 03:04 PM   #88
murphy98
murphy98's Avatar
Always liked the colour scheme on your truck jbgroby, looks great!
Here's my '62 with 60-61 hood & 58-59 parking lamps.
Murph
murphy98 is offline   Reply With Quote
Old 09-13-2014, 03:37 PM   #89
jbgroby
jbgroby's Avatar
Thanks. Yours looks cool as well
Old 09-14-2014, 01:50 PM   #90
Budman56
Budman56's Avatar
Smile Re: 63 chevy grille & 60 gmc hood
Here is what I have, What do you think?
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 09-14-2014, 10:20 PM   #91
jbgroby
jbgroby's Avatar
You I always kinda thought if Batman would pick a truck, it would have been a 60-61 because of the hood scoops.
Old 09-17-2014, 09:24 PM   #92
Steaksauce
Originally Posted by jonathan-m View Post
This one right here is a winner. Best look I've seen so far.
Wow. I need this in my life, looks awesome.
Steaksauce is offline   Reply With Quote
Old 11-07-2014, 12:39 AM   #93
Jonnyspringfield
I'm really wanting to drop a '60(?) grill with the twin dual head lamps into my 64 dually. I'm just more partial to the look of the earlier headlight setup. I'm having a really hard time finding info as to whether or not it will match up properly or if there are other years that will. I'm completely okay with using the gmc grill and doing some custom badge work on it. Thanks for any help
Jonnyspringfield is offline   Reply With Quote
Old 11-07-2014, 01:21 AM   #94
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
the top outer bolt holes will line up, you will have to drill out the other 3 holes.
I ran the 62 grille in my 65 with just the 2 bolts holding it for a while, no problems... I went ahead and drilled the new holes when I changed to the gmc grille.
a trick for the holes... I bolted it on with the 2 that fit, then I grabbed some spray paint and spray bombed around the mount, pulled the grille off, and there was the pattern for the new holes.
Old 11-07-2014, 01:23 AM   #95
seanrolandwood
jonnyspringfeild if you're lookin to go to an earlier grill on your truck you'll need to source a grill support panel as well when i did mine 61 grill on a 66 i was able to find one so im not sure about the aftermarket panels and how they fit i also im not sure about the gmc support panels and if they fit the early chevy grills but im sure with a gmc grill and support panel it would bolt right in.. I'm sure I'll be corrected here but i believe that the 60-61 grills will need the same year support panel as the 62 isn't a direct bolt in as the bolt pattern is different for grill, all years have the same bolt pattern for fenders i also had to rework the bottom of grill support panel to fit over frame rails other than that no issues at all pretty simple swap
Old 11-07-2014, 07:22 PM   #96
hotrod66
hotrod66's Avatar
i like it but, my truck is still uglier
Old 11-07-2014, 08:34 PM   #97
jonzcustomshop
1961 crewcab
all you need to do is drill the correct holes, the dual headlight grille support panels have a little indentation for the inner headlamps that the single ones do not have... however it will still fit, the wiring /plug ends up being a little close, but there is still about a half inch of clearance....
Old 11-07-2014, 10:25 PM   #98
Wilson!
what is this i have found?
Wilson! is offline   Reply With Quote
Old 11-07-2014, 11:31 PM   #99
jonzcustomshop
1961 crewcab
does it look like the mesh was cut out of a c/10 64-66 grille?, if not then it is probably the COE style grille that uses the bowtie in the center , but does not have room for the upper letters, so they are stamped in like the c/10 style.....
Old 11-08-2014, 01:46 AM   #100
Wilson!
it's a 65 that the mess has been cut out of. used for mock-up. this one is really rusty and is pretty much not savable. i have another that i'm going to cut, fill the letters and add a GMC badge to (i have a 65 GMC).
