Old 09-29-2015, 07:35 AM   #76
matt_l
Re: 1966 C10 Father Son Build
DKO,
Thanks for the compliments, that means a lot coming from someone putting together as beautiful truck as yours!
The rear suspension is coming along nicely, so it is on to the next adventure. I am going to push it a little more with a turbo 5.3. I am going to follow the Hot rod magazine build as a guide.
http://www.hotrod.com/how-to/engine/...lock-for-3252/
This will be a big challenge, but hopefully with a little patience, it should go smoothly....
Matt
Father Son 66 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=564694
matt_l is offline   Reply With Quote
Old 09-29-2015, 10:49 PM   #77
matt_l
Adding in the upper bag support. I figured I better practice welding tunes if I plan to fab up the hot side of the turbo and the exhaust system.
Matt
Old 10-18-2015, 08:08 AM   #78
matt_l
Now that the rear suspension is back together, Now it is time for the next big step... turbo 5.3 ls swap.
I want to fab up a good portion of it myself, so I decided to start with the turbo hot side collector into the t4 flange. I figured if I could do this joint, the rest would be easy.
Here is the plan:
5.3 junkyard motor and transmission. I found a pretty good deal on craigslist for motor, trans, re-flashed ECU, and cut down harness.
I am going to get the turbo kit that sloppy mechanic suggests on his site:
https://sites.google.com/site/sloppy...unkyardturbols
Here are the pics of the merge pipe coming together. I created the flat patterns in solidworks, then transferred them to the tube, fit them together, and burned them up. Not the prettiest, but it will look just fin under the heat wrap.
Matt
Old 10-18-2015, 02:56 PM   #79
tinydb84
tinydb84's Avatar
I love the sloppy mechanics stuff. Denmah makes some crazy fast stuff. Are you running a single gate or two?
Be careful with those rear bag mounts. They will eventually twist your arms due to being mounted offset.
David
Instagram: myfabguy
Old 10-19-2015, 12:31 PM   #80
matt_l
David,
I am going to run a single wastegate right there at the merge.
I had the same concern over the twisting, but a couple board members have been running it with no issue. I plan to monitor it regularly to make sure nothing goes haywire.
Matt
Matt
Old 10-19-2015, 08:25 PM   #81
tinydb84
tinydb84's Avatar
Good stuff. Cant wait to see how it comes out.
David
Instagram: myfabguy
Old 10-25-2015, 06:14 PM   #82
matt_l
Rear shocks mounted. Progress is slow and steady.
Matt
Old 11-08-2015, 06:46 PM   #83
matt_l
I got the air tank mounted. I bought this tank last year on close out. Since it was bigger than most, it does not fit on the side of the frame rail where I wanted to put it. Even though this wasn't my first choice, it should work out fine. It will be below the raised bed, and still give me good clearance to all moving parts when the truck is aired all the way down.
Matt
Old 11-17-2015, 08:10 AM   #84
matt_l
Making a bit more progress before the cold winter arrives and I lose my garage spot....
I mounted a boyds welding tank with aeromotive intank fuel pump. It was not cheap, but I did not want to skimp on the tank. It is a beautifully made tank, it is a shame it will be hidden under the bed. I did not want the tank to sit lower than the frame rails, so I fabbed up some brackets to mount it to the frame. the flanged holes are a bit of overkill, but I wanted to practice my welding and fabrication on some non visible parts. They turned out really good, now i am a little bummed they will also be hidden under the bed.
Matt
Old 11-17-2015, 04:46 PM   #85
azdude1964
azdude1964's Avatar
cool build
efi 496bbc th350 custom brakes narrowed 9 coilover rear.
azdude1964 is offline   Reply With Quote
Old 11-17-2015, 06:43 PM   #86
tinydb84
tinydb84's Avatar
I really like those brackets. Did you use a dimple die? How do you plan on painting the inside? I want to buy some dimple dies that DV8 makes I just don't know if I would use them enough.
David
Instagram: myfabguy
Old 11-19-2015, 03:42 PM   #87
matt_l
Thanks for the compliment. They turned out better than expected for my first trial. I used a simple dimple die and a Harbor Freight H frame press. I had a friend of mine make the die for me at his machine shop.(He owed me a favor) I am planning to make some more sizes this winter when I take a machining class at the local community college. I looked at the DV8 dies. Those are really nice, but hard to justify the cost for the frequency I will use them.
Yes, I painted it with POR15 after it was welded to the frame.
Matt
Old 07-11-2016, 10:14 AM   #88
matt_l
Started working on the raised bed. Slow go, trying to figure out how to do it with the least amout of cutting on the existing parts. I also plan to have the center section lift up for access to the air system and gas tank. I would like it to be air driven as well, but I will start with a manual lift and add the power lift later.
Matt
Old 07-13-2016, 07:34 AM   #89
matt_l
More slow progress on the raised floor. it goes so much faster in my mind than in reality. Measure cut, weld, remeasure, cut apart, weld, fit, and redo again.
My helper really wants to go for a ride....
Matt
Old 05-22-2017, 10:10 AM   #90
matt_l
Made some progress on the bed.
Matt
Old 05-22-2017, 10:17 AM   #91
matt_l
I put the bed on hold as I get started on my LS swap. I ran across a great deal on a 5.3 motor out of an 05 truck. I got the engine, transmission, accessories, harness, and ECU. They also threw in the pedal and module.
Matt
Old 05-22-2017, 10:21 AM   #92
matt_l
Plans and progress on the swap. The plan is to follow sloppy mechanics 500 rwhp build. I will be swapping out the cam and valve springs and adding a turbo. I am not sure if i will do the turbo or add it in stages. I will be mouting it with Dirty Dingo sliders and a cpp trans crossmember.
Right now I am cleaning up the motor and getting ready to swap out the cam and springs.
Matt
Old 05-25-2017, 10:32 AM   #93
matt_l
It doesn't look any different, but the new cam is in. Thanks to sloppy mechanic for the great video on how to do the swap. Plan is to get the valve springs swapped out tonight, then it is time to paint the block and start putting it back together.
Matt
Old 05-31-2017, 10:53 PM   #94
matt_l
Making more progress on the motor. Valve springs replaced. I started putting the front accessories back on, flipped the exhaust manifolds, and installed the Dirty Dingo sliders.
Matt
Old 06-04-2017, 09:13 PM   #95
matt_l
I got the old motor out and getting ready to drop the new one in. I am going to test fit the motor to see if the stock truck pan fits.
Once that is set, I am also going to cut the existing trans cross member out and figure out where to put the replacement.
Matt
Old 07-18-2017, 08:12 PM   #96
matt_l
Making some more progress. The hot side is starting to come together. Fit tack fit adjust cut tack.... Radiator lower mounts are in amd hammer forming an upper mount. Intercooler mounted. Slowly but surely checkimg things off the list and having a lot of fun in the process.
Matt
Old 10-22-2017, 08:10 PM   #97
matt_l
Started it today... She runs. Now it is time to get it tuned.
Matt
Old 10-30-2017, 01:44 PM   #98
Notch1988
Notch1988's Avatar
Looking good. What VS turbo is that? What did you run for a waste gate? Are you running a stall?
66 GMC swb dropmember accuair
Link to my build:
My GMC Project
Notch1988 is offline   Reply With Quote
Old 11-02-2017, 04:52 PM   #99
Homebuilt Hotrods
Homebuilt Hotrods's Avatar
cool build
Garage Built
Homebuilt Hotrods is offline   Reply With Quote
Old 11-08-2017, 06:51 PM   #100
matt_l
It id VSR 78/75 .96ar T4. Here is the link.
http://www.vsracing.net/catalog/prod...348b9893413cb0
Matt
