Old 08-25-2016, 03:01 PM   #76
timmytimm3
Re: Project "Full Circle" 66 C10
New/used bedside
BIG RED
489ci BBC- all forged, 781 oval port heads with oversized valves. He regrets this now and wishes he spent a little extra on some aluminum ones. Trans is a built powerglide and the transfercase is a reversed drop box. The truck should be a handful
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 05-08-2017, 08:53 AM   #77
timmytimm3
After screwing around for too long I'm finally back working on my truck. I welded a small patch on the driver side floor and got the passenger inner rocker tacked in. The rear part of the rocker was too short like the driver side so I pie cut it and filled it in first.
timmytimm3 on IG
Old 05-09-2017, 06:48 AM   #78
Bomp
Bomp's Avatar
Glad to see you're back at it. Nice work on smoothing out the welds.
Bomp is offline   Reply With Quote
Old 05-18-2017, 09:17 AM   #79
timmytimm3
More-
These fat "cut off wheels" are awesome for grinding welds!
Scored a new bench. I'm going to cover it with 3/16" steel
Driver side cab corner- Need to fill in the bottom gap a bit
Passenger side floor vent
timmytimm3 on IG
Old 05-21-2017, 07:00 AM   #80
Gary V
Active Member
Gary V's Avatar
Awesome! You guys do nice work!
Best regards,
Gary
DOMERINGER BUILD
Gary V is offline   Reply With Quote
Old 06-01-2017, 09:09 AM   #81
timmytimm3
More updates. Hung the passenger side door and the bottom was hitting the rocker. These aftermarket panels always seem to need adjusting...
I also cut about 1/4" out of the inner door bottom and pie cut the corners to help with clearance.
timmytimm3 on IG
Old 06-07-2017, 09:34 AM   #82
timmytimm3
Driver side floor vent
timmytimm3 on IG
Old 06-19-2017, 07:55 AM   #83
timmytimm3
Continuing on the rust repairs. The A pillar had some rust hidden behind it so I drilled it out but was unable to remove it without bending the crap out of it. I decided to pull the dash out to be able to fix everything right the first time.
timmytimm3 on IG
Old 06-19-2017, 07:58 PM   #84
tinydb84
tinydb84's Avatar
Damn. That is a lot of work. Cabs around here are so much nicer. Good work sir.
David
Instagram: myfabguy
