03-27-2014, 10:42 PM | #76 |
Re: 69 K-10 Build for Dad
Still interested
03-28-2014, 10:06 AM | #77 |
Boosted Member
Sorry, I'll dig thru and try to find some pics.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
03-30-2014, 09:41 PM | #78 | |
Boosted Member
03-30-2014, 09:51 PM | #79 |
Boosted Member
Dad came down this weekend, and my brother Dan came over to help, too.
Dan and Dad taking the front clip apart so we can get rid of the old core support. Cab is on! Got the new core support on, along with some of the AC stuff. Buttoned up some loose ends here Dan doing some wiring for the VHX dash Contemplating the best way to tackle the disassembly. Rolled it outside today and got some nice shots of it outside, since it's FINALLY starting to warm up here New carpet for it, from ACC. Vintage Air unit all installed and wired. New core support, battery box, etc. I also located where the 4x4 shifter needs to go, and cut the holes. Still need to install it, and adjust the linkage.
03-30-2014, 10:11 PM | #80 |
Ephesians 2:8
Nice work Jeff!
72 Suburban making it mine My 79 C10 story 79 C10 LS swap 94 LS swapped Daily Driver Tahoe Limited Instagram - @piersonclassics 83 K20 Farm Truck Build |
03-30-2014, 11:14 PM | #81 |
Sweet!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
04-09-2014, 12:37 PM | #82 |
Great progress. Your dad has to be getting itchy to go for a cruise.
1970 SWB 2wd C10, Vortec 454/80e, CPP 3/5, slotted mags, patina 1972 K20 Super Cheyenne, Short bed, EFI 396, NV4500, NP208 1970 GTO Judge, heads/cam LS1 & stalled 4L60e |
04-18-2014, 12:47 AM | #83 |
Enjoying left field
What kind of mileage are you expecting? I know the 2wds can do pretty well, but what about a lifted 67-72?
04-18-2014, 07:35 AM | #84 |
Still Learning
Awesome progress! the interior and engine bay look great.
05-23-2014, 10:20 PM | #85 |
Nice work on the truck. Looks great! I noticed in post 35 that you don't have a tailgate handle and it appears that you did not use the standard relocation kit, unless I just missed it. Care to divulge any secrets!
05-28-2014, 11:34 PM | #86 |
Proprietor of Dale's Corner
Lookin really good
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
06-09-2014, 02:50 PM | #87 |
Rusty Nuts
That is one nice build and beautiful truck.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
06-13-2014, 12:34 AM | #88 |
Boosted Member
Been quite awhile since I posted an update...
Got the newer truck shifter installed. And then the seats put in I then welded bosses to the new aluminum radiator to mount the Dodge Intrepid electric fan to. Fits nice Random shot with my blazer in the background AC and heater hoses finished up ECM mounted Slapped the fenders and hood on quick to get them off the floor. Still need to align everything Got everything outside of the shop for spring cleaning Pulled the front diff cover to check everything out and change the oil Rebuilding the front hubs New bearings, studs, rotors...the parts store gave me 2wd calipers so I still need to exchange them yet.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! Last edited by Wasted Income; 06-13-2014 at 12:42 AM. |
06-13-2014, 10:58 AM | #89 |
Gettin close buddy
70 Chevelle SS (clone), 454, 350 auto 71 K5 350, 350 auto, 3" body lift, 35's -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |____|__|___] *.*..*.*.._@_ _ _ _ @ |
06-19-2014, 05:47 PM | #90 |
Great work as usual!
06-19-2014, 11:53 PM | #91 |
Still Learning
Awesome progress!
06-25-2014, 07:57 AM | #92 |
Boosted Member
Well THAT was a pain in the azz...and I'm glad it's finally done.
Been poring over what to do about a fuel filler for months. Didn't really want to cut a hole externally in the bedside, but it needed to be fairly easy to get to. Here's what I ended up with... Decided to start with the inside fuel filler cover from a Blazer Then start cutting it up and get to work Found a nice vented boat filler neck with integrated cap, should work nicely. The only issue is that to get the angle of the neck right, the "GAS" reads upside down. I know that's going to drive my dad nuts....because it drives ME nuts....but it is what it is. I backpurged and TIG'd a stainless tube to allow for the flow to be as smooth as possible to the tank. It will also be durable, especially if it happens to come in contact with the bed supports that I plasma'd out. Finished product!
06-25-2014, 08:43 PM | #93 |
Itll look right side up if you look over the side of the bed!
06-26-2014, 12:38 AM | #94 |
Very nice build!!!
2014 Dodge Charger SXT 100th Anniversary Edition 2009 Chevy Silverado Z71 1978 Chevy Scottsdale 4x4-Project "Colonel"- Build http://67-72chevytrucks.com/vboard/s...d.php?t=632039 |
06-30-2014, 09:32 AM | #95 |
Boosted Member
Dad came down to visit and work on the truck again this weekend...got some good work done.
-Brakes bled -Lokar trans shifter linkage installed and adjusted. -AC wiring finished up -Trans filled with oil -Fuel filler buttoned up, and gas in tank -Misc wiring completed -Battey cables installed And the pinnacle of the weekend...
06-30-2014, 09:52 AM | #96 |
looks good like the fuel filler mod
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
07-01-2014, 04:45 AM | #97 |
Nice progress!
07-01-2014, 08:18 AM | #98 |
Still Learning
Congrats on getting her running!
09-08-2014, 01:29 PM | #99 |
any updates?
10-27-2014, 01:34 PM | #100 |
This thread needs an update... I know you have some to post!
