Old 12-07-2014, 11:53 AM   #76
slowcpe
slowcpe's Avatar
Re: RideTech's New C10 CoilOver Kits
Truck looks great. Killer stance!
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 12-07-2014, 04:05 PM   #77
Kook87
Kook87's Avatar
Don't sweat the petty things and don't pet the sweaty things.
Kook87 is offline   Reply With Quote
Old 12-07-2014, 06:17 PM   #78
duallyjams
duallyjams's Avatar
Originally Posted by Kook87 View Post
do you have a pic of the front cross member ground clearance
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-07-2014, 06:48 PM   #79
Kook87
Kook87's Avatar
[URL=http://s852.photobucket.com/user/kook_2010/media/cars/20141207_173951.jpg.html][/URL
3 1/2" clearance at lowest point.
Old 12-07-2014, 07:19 PM   #80
dkauffman05
dkauffman05's Avatar
What sway bar do you have ?
dkauffman05 is offline   Reply With Quote
Old 12-07-2014, 07:23 PM   #81
Kook87
Kook87's Avatar
Ride tech muscle bars front and rear
Old 12-09-2014, 01:23 PM   #82
Hugger67rsss
Hugger67rsss's Avatar
Truck looks awesome, can't wait to get mine installed on my 66.
Hugger67rsss is offline   Reply With Quote
Old 12-09-2014, 02:29 PM   #83
lolife99
67-72 parts collector,…
lolife99's Avatar
Lowest?
Meaning the bottom of the coil over shock?
Or the crossmember?
Keith
Convert to disc brakes.
Old 12-10-2014, 05:11 PM   #84
Kook87
Kook87's Avatar
Lowest?
Or the crossmember?
Lowest point is on the bottom of the A-arm. This is the closest point to the ground.
Old 12-10-2014, 09:17 PM   #85
dkauffman05
Been thinking about my build and kinda worried about the front spring rate and ride height . I have a all aluminum ls6 and t56. What is the spring rate set up for that comes with the kit ? Sbc with iron heads? I know on my 68 when I went from an iron block ls to a aluminum block the front suspension came up a little . I didn't measure the rise but I fore sure noticed it.
Old 12-12-2014, 09:19 PM   #86
Kook87
Kook87's Avatar
If you call ride tech they will tell you what you need based on info you give them.
Old 12-26-2014, 01:37 PM   #87
aod92
aod92's Avatar
I love the ride height....any bed or crossmember mods on your truck? I'm really thinking about ordering one of these kits.
aod92 is offline   Reply With Quote
Old 12-26-2014, 03:21 PM   #88
Kook87
Kook87's Avatar
Just the c notch that comes with the kit for the frame in the rear. Great ride and fit. I highly recommend this kit.
Old 01-09-2015, 06:11 PM   #89
aod92
aod92's Avatar
I ordered my front kit last week....Hopefully I'll get the rear ordered soon. I'll post pics as its going in!
Old 01-12-2015, 10:45 AM   #90
chase@ridetech
chase@ridetech's Avatar
Thumbs up Re: RideTech's New C10 CoilOver Kits
i look forward to seeing it.
chase@ridetech is offline   Reply With Quote
Old 02-04-2015, 10:33 AM   #91
chase@ridetech
Did you get your kit bolted on yet?
Old 02-04-2015, 01:00 PM   #92
Hugger67rsss
I got the kit installed for my 66 and the frame powdercoated. Still a long ways to go before I set the cab and bed back on but I am very happy with the quality of the parts.
Aarik Gault
1966 GMC SWB, Ridetech Suspenion
1968 Camaro autocross/track car
Old 02-04-2015, 01:02 PM   #93
Hugger67rsss
Still need to tighten all the bolts and order front spindles and sway bars.
Aarik Gault
Old 02-04-2015, 03:31 PM   #94
chase@ridetech
Looks great! Being a GMC was your truck a Trailing arm truck from factory or a leaf sprung truck?
Old 02-04-2015, 03:58 PM   #95
Hugger67rsss
It was factory leaf springs, I called and talked to Josh when I was installing it. I only had 1 hole to line up the notch template. I got it figured out though.
Aarik Gault
Old 02-04-2015, 05:18 PM   #96
chase@ridetech
Good, We need to get a GMC in here to do an updated template. We have several customers with leaf sprung trucks converted over, but just haven't had one here to check the reference holes.
Old 02-04-2015, 08:11 PM   #97
aod92
aod92's Avatar
Not yet. I'm waiting on the powder coater right now. Soon as I get that back I'll start posting pics.
Old 03-17-2015, 10:01 AM   #98
dkauffman05
Plan to order tires for my build that has this ridetech kit. I'm have 18x9.5 in the front with 5.5 backspace. I'd like to run a 295-40-18 front and rear. What do you guys think ? I have stock inner fenders also.
Old 03-17-2015, 10:31 AM   #99
aod92
aod92's Avatar
I started installing mine this past weekend. Goes together very easy...this ridetech stuff is very nice!
Old 03-28-2015, 06:20 PM   #100
soundqdoug
soundqdoug's Avatar
Can the factory front sway bar be used with this kit, or do you have to buy the MuscleBar?
soundqdoug is offline   Reply With Quote
