02-11-2016, 07:46 PM | #76 |
A320 Pilot/USAF Retired
Re: 1958 GMC Memorial Build
Did you get the headers sorted out yet? Looking forward to seeing your progress!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
02-15-2016, 03:49 PM | #77 |
Hey ChuckDriver - I went with some Patriot Clippster Headers. Haven't tried fitting them yet. Hoping to try them out this week. I will post back with the results.
Build Thread: 1958 GMC Memorial Build |
02-16-2016, 07:10 PM | #78 |
First rate!!! Love the frame and the fact that you painted in mint. Subscribed.
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
02-16-2016, 10:16 PM | #79 |
Nice, hopefully you've found a set that fit!
02-17-2016, 12:12 PM | #80 |
Looks like the Patriot Headers will fit! Very slight trimming necessary on driver side near the frame rail. No trimming on the passenger side!
Did run into a fitment problem with the 4l80 transmission though. Have to build a small tunnel in the cab floor. Nothing too major. Firewall is done and in primer.
02-17-2016, 12:22 PM | #81 |
Here is a full pic. Everything will get a nice layer of black epoxy primer before it rolls out of the shop.
Still have a bit to go.
02-17-2016, 01:04 PM | #82 | |
Good luck with the build!
My Build: 57 Chevy Pro-Street |
02-17-2016, 09:48 PM | #83 |
Would you please post some pic's and part number for the headers!!
02-18-2016, 10:41 AM | #84 | |
In the meantime...here is the part#: PTE-H8073
02-20-2016, 11:31 AM | #85 |
Did the cab fit down on the frame ok with the transmission cover removed?
"Fear makes the wolf look bigger" http://67-72chevytrucks.com/vboard/s...d.php?t=305629 |
02-20-2016, 10:30 PM | #86 | |
I'll get some pictures up this week of the results. Posted via Mobile Device |
02-25-2016, 12:52 PM | #87 |
Here are some pics of the headers mounted. The driver side header took a couple taps with a hammer to dent one pipe to clear the frame rail. The passenger side had to have the collector moved back 1-2" since it dumped right at the frame rail. All-in-all a really good option for trucks running an LS engine and Porterbuilt suspension.
02-25-2016, 02:23 PM | #88 |
Gonna be a 'tight' fit for a steering shaft ..... They didnt have a rear exit type header you could go with to get them out of your way?
Heres a set from BBK - they make some nice stuff for LS engines.
02-25-2016, 02:34 PM | #89 | |
I looked around and had a hard time finding any info on what worked for headers on these trucks with the LS/Porterbuilt combo. Even PB couldn't give any recommendations. I saw Delmo use a corvette manifold but I wasn't super keen on the way that looked.
02-25-2016, 05:07 PM | #90 |
Very Nice!
02-25-2016, 09:47 PM | #91 |
Thanks for the pic's, hope the steering linkage is not a problem.
02-25-2016, 11:06 PM | #92 |
Looks like they should work out.
Kim |
02-26-2016, 01:29 PM | #93 | |
If PB is gonna stay in this 'build world' I would think that they would either start finding suppliers that fit their systems or start building their own headers and anything else that needs to fit their kits and provide supplemental kits to their product line.... you cant just leave people hanging.... in this "want it now type of world". Cant wait to see you driving this thing!!!!
02-27-2016, 01:58 AM | #94 |
In my wandering the net I came across information that for the 55-59 TF trucks with BBC's, that a Hooker or Headman Super Comp long tube heads will fit. When I come across any nuggets I take notes. My notes on headers don't list where or who furnished the info, only the suggestion. I bought Mark VI 454 block that I was assuranced that it ran. Not with 5 of the jugs full of water and bore to +.40, now I have a mock up block. Purely by luck the 454 seller threw in a set of long tubes. No ID anywhere on the headers. With the guts out of the block, and the heads and headers on I did a test fit, and it did with about 3/4 clearance on both sides. So I going to order the Hooker Super Comps when the time comes and cross my fingers. Gook Luck Nut Case
Been there, wrecked that |
02-27-2016, 02:14 AM | #95 |
Look for the Headers that fit a 70 Chevelle, sorry left the important information out.
It's late I should turn out the lights and go to sleep. Maybe I'm in a dream and sleep typing. Nut Case
02-27-2016, 02:15 AM | #96 |
Big Block 70 Chevelle. Doe
it only took 3 posts. I'm outa here Nut Case
02-27-2016, 11:51 AM | #97 |
Because the PB front clip is narrowed a bit it does lack header space...I'm looking forward to pictures of how the steering linkage ( firewall to unisteer ) is installed. Love this build and the truck..oh yeah, Shanes a nice guy too
02-27-2016, 03:13 PM | #98 |
Nate has developed a newer version for the TF truck that has more room for headers.
02-28-2016, 10:23 PM | #99 |
I will try to get some pics once the steering linkage is all installed.
@ptc - I will definitely get some pics up of it driving! @greystoke - thanks buddy, appreciate the kind words! @ChuckDriver - of course they come out with something new before I even get mine on the road, haha. That's good though that he modified the front drop member to make more room for the headers.
03-04-2016, 04:00 PM | #100 |
The shop hasn't done the final steering shaft assembly but they assured me again it would work out slick. Fingers crossed.
Wiring is in full swing. Here are a couple pics. They also sprayed the front clip and bed with black epoxy.
