Old 09-26-2015, 02:24 AM   #76
76stepside01
76stepside01's Avatar
Re: 1964 Sleeper | 5.3 | 75mm turbo | Caged | 4 Link
Started on the wiring for the truck. I decide to start from scratch and build a custom fuse block as their will be minimal circuits on the truck and it will be a lot cheaper than a painless or similar kit. I love the look of the panels this company does so I'm going to do something similar. http://www.ceautoelectricsupply.com/...laypanels.html
Started with the ignition switch panel. Because who doesn't love hitting several toggles to start their truck?
76stepside01 is offline   Reply With Quote
Old 09-26-2015, 12:33 PM   #77
Aaronoregon
Beautiful project here. Seriously!........but am I the only one not fooled here?? 17 my a**..................... You don't acquire skills like this at that age. Either you are BS'ing us on your age or you're getting a lot of help from someone else......
Aaronoregon is offline   Reply With Quote
Old 09-26-2015, 02:46 PM   #78
DaddyOh
DaddyOh's Avatar
Fuel pumps should never be wired to their own toggle switch for power (you never want to require a mechanical input from the driver to cut power to a fuel pump). Fuel pumps should be routed through your ECM, through a fuel pump safety switch or similar. The only time toggles come into play is if you are running a redundant (A/B) fuel system and require ability to switch over in case of blockage or a failed pump without stopping - such as in race conditions. You may already have something planned but food for thought.
'65 Tiki Sea 10: http://67-72chevytrucks.com/vboard/s...d.php?t=682356
DaddyOh is offline   Reply With Quote
Old 09-26-2015, 04:40 PM   #79
76stepside01
Interesting, The reason I was going to use switches to control the fuel pumps is I'm planning on using a holley pump which has two internal pumps that can be wired separately. One can be used for cruising around and both can be switched on when at the track. Just did some research and holley makes a low oil pressure fuel cut-off. This way if a roll over occurs and oil pressure drops power will be killed to the pumps.
Old 09-26-2015, 05:39 PM   #80
DaddyOh
DaddyOh's Avatar
Remember "12V switched power" is just 'activated' power to trip your relay... doesn't necessarily mean a toggle. Last thing you want is a fuel pump chugging along after you smack into something and are unable to get to the toggle switch - that would be no bueno!
Old 09-26-2015, 08:15 PM   #81
76stepside01
True, I looked on holleys website and the HP ecu will control the primary pump as well as an output that will activate the second pump on boost so I will wire it that way. Thanks for pointing that out!
Old 09-26-2015, 08:38 PM   #82
DaddyOh
DaddyOh's Avatar
Now you got the idea... many engine management systems will use a negative relay trigger for their pump(s).
Nice build by the way... keep keepin' on.
Old 09-26-2015, 09:22 PM   #83
76stepside01
Originally Posted by scuderia View Post
+1
Well I actually turned 18 a could months ago not trying to BS anyone. I learned to weld when when I was about ten and have been around tools and building things my whole life. I found a passion of mine and when you work at something nearly everyday you get good at it regardless of age!
Old 09-26-2015, 10:02 PM   #84
joey8383
joey8383's Avatar
Subscribed. Nice work!
joey8383 is offline   Reply With Quote
Old 09-27-2015, 11:05 AM   #85
chad64chevy
chad64chevy's Avatar
it's cool to see someone your age doing a project like this! an at the level of welding your doing is awesome, I didn't start really welding til I started on my project! I'm still learning things everyday, some people get it some never do! i'll be switching to a turbo ls, maybe twin turbo not sure just yet this next summer and i'll have a few question for you then, keep at it! I'm subscribed
chad64chevy is offline   Reply With Quote
Old 10-01-2015, 12:44 PM   #86
76stepside01
Thanks everyone! Been thinking about building some long tube headers that work on drop member/lowered c10's. Think there would be any interest in those?
Old 10-07-2015, 11:14 PM   #87
76stepside01
The relay and fuse panel is mostly wired. My OCD was in full effect while doing this
Old 10-07-2015, 11:21 PM   #88
argonaut
argonaut's Avatar
I like the way your mind works!
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 10-08-2015, 01:34 AM   #89
mjh1965
mjh1965's Avatar
Top job very neat . OCD when doing wiring is a good thing
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline   Reply With Quote
Old 10-08-2015, 09:57 AM   #90
Coach529
Coach529's Avatar
Beautiful.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 10-08-2015, 05:48 PM   #91
65sub
65sub's Avatar
Nice work
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 10-10-2015, 01:10 AM   #92
scum1
scum1's Avatar
this build is just stupid. You are one talented kid..
scum1 is offline   Reply With Quote
Old 10-13-2015, 09:46 PM   #93
64c10HotRodder
What fuel pump did you use?
64c10HotRodder is offline   Reply With Quote
Old 10-14-2015, 11:24 PM   #94
76stepside01
https://www.holley.com/products/fuel.../parts/12-1200
Old 10-14-2015, 11:29 PM   #95
76stepside01
I shaved the stock intake to make it look a little cleaner and less distracting. What it looked like stock
Bondo'd and a coat of primer
Old 10-18-2015, 09:42 PM   #96
amueller454
amueller454's Avatar
Dude this thing is NASTY! Killer work
1960 short bed fleetside factory 4x4
1960 panel 454 NV4500 Daily driver
1961 Short Bed BBW Fleetside 5.3 th400 swap in process
amueller454 is offline   Reply With Quote
Old 10-18-2015, 10:39 PM   #97
deejaaa1
great mod on the intake.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 10-20-2015, 08:00 PM   #98
picklito
Enjoying your amazing build. On your 4-link: Did you use equal length upper and lower arms? Are they exactly parallel or do you have some torque equalization built in?
picklito is offline   Reply With Quote
Old 10-20-2015, 11:44 PM   #99
Bomp
Bomp's Avatar
Better late than never.
I'm in
Killer detail work by the way
Bomp is offline   Reply With Quote
Old 10-21-2015, 11:49 PM   #100
76stepside01
The 4-link bars are equal length and can be set at three different angles, one of them being parallel.
