Old 02-11-2016, 07:13 PM   #76
Hampshire
Hampshire's Avatar
Re: Danforth Cross Member Install
Be careful with those specs from Borgeson & BTW, DWCSR has it right - the fractional spec, etc. is where it is at.
My first rack (2.5 "sport") with the Borgeson recuced pressure pump, hoses and metric hose adaptors (their spec) leaked at the rack - though possibly due to Borgeson sending me the wrong washers.
When I went with the 3 turn rack, I went with fractional adaptors and white O-rings from an outfit in California (similar to what Speedway sells). Works great.
Bottom line, Borgenson pump & hoses are fine, but don't follow their advice or use their adaptors - everyone but them has gone fractional.
Hampshire is offline   Reply With Quote
Old 02-11-2016, 07:51 PM   #77
Coach529
Coach529's Avatar
Another pressure adjustment method....
http://www.speedwaymotors.com/Heidts...FU4YHwodIuoBbw
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 02-11-2016, 08:06 PM   #78
dwcsr
Hollister Road Co.
dwcsr's Avatar
Originally Posted by Coach529 View Post
What did you do for hoses?
I used the Borgeson 925102 Ford 79-97 rack to GM Type II pump and the speedway imperial fittings. -AN fittings are still imperial so the hose ends were ok. You will have to use the brass ferrule from the kit in the pump
dwcsr is offline   Reply With Quote
Old 02-11-2016, 09:47 PM   #79
Coach529
Coach529's Avatar
So I need the hose kit and an adapter that goes from 9/16-18 to 14mm-1.5 for the pressure and 5/8-18 to 16mm-1.5 for the return?
1949 Chevy 3600
Old 02-11-2016, 11:04 PM   #80
dwcsr
Hollister Road Co.
dwcsr's Avatar
The hose kit is correct length and angle on the hose ends with the wrong fittings for our rack
I used a the Borgeson hose kit and the rack fittings from speedway 9104047
The hose ends on the hoses are AN and will fit the speedway fittings.
fittings 9/16-18 to -6an and 5/8-18 to-6AN fittings.
You can get a ford pump or add the reducer into a GM pump. I don't now what ford pump you would need
Old 02-11-2016, 11:12 PM   #81
dwcsr
Hollister Road Co.
dwcsr's Avatar
Yes you were the one that put me on the trail for the 3 turn rack, I had forgotten your user name so I couldn't give you your due credit
Old 02-25-2016, 10:43 AM   #82
Coach529
Coach529's Avatar
I have a rack and pinion and tie rod ends on the way, hopefull they will arrive tomorrow!!
1949 Chevy 3600
Old 03-14-2016, 11:39 AM   #83
Coach529
Coach529's Avatar
Still plugging away on this install.
Threw the motor in to mock up the rack and pinion set up.
The mounting on this rack was offset to the drivers side which makes mounting a bit more troublesome. I picked up some 4" x 4" x 3/16" tubing to make some mounts out of.
Scott suggests a 3" notch to clear the rack. This WILL NOT work with a Ford rack. I had to open up my notch to almost 6" to clear the Ford rack. Frustrating to cut apart something that was finished.
I had to remove some material on the passenger side of the crossmember to clear the rack. I got a little overzealous with the skinny wheel and sawzall.
mock up
Making brackets
Tacked in
Fit test. I did end up opening up the notch after this.
Both side welded in and the relief boxed in. I just need to rebox the bottom of the notch!!
1949 Chevy 3600
Old 03-14-2016, 12:24 PM   #84
dwcsr
Hollister Road Co.
dwcsr's Avatar
That's just what I did on my install. In fact I would almost think I was looking at the one I did.
Old 03-14-2016, 12:27 PM   #85
Coach529
Coach529's Avatar
I had studied your install a lot before I started mine. Thanks for the tips!!
1949 Chevy 3600
Old 03-14-2016, 12:41 PM   #86
Coach529
Coach529's Avatar
Has your customer had a chance to put any miles on?
Curious about his feedback on the front suspension.
1949 Chevy 3600
Old 03-14-2016, 12:50 PM   #87
dwcsr
Hollister Road Co.
dwcsr's Avatar
Yes, with the new rack (3 turn) it drives great. I like it and he likes it which is the important parts. Thanks to the input of all the guys here that helped get it figured out I think this is the go to cross member for me in the future for AD trucks.
The truck with the Danforth front end and the 67-72 trailing arm rear makes it ride nice and handle like a newer truck similar to a 2000 up Silverado but smoother on the Interstate. I think with bags it should ride like a Cadillac
Turning radius is also very good
Old 03-14-2016, 12:52 PM   #88
Coach529
Coach529's Avatar
one last question. No bumpsteer issues?
1949 Chevy 3600
Old 03-14-2016, 12:55 PM   #89
dwcsr
Hollister Road Co.
dwcsr's Avatar
none at all and I was afraid it may have but like I said it drives great.
Old 03-14-2016, 12:59 PM   #90
Coach529
Coach529's Avatar
Thanks for putting my mind at ease.
1949 Chevy 3600
Old 03-14-2016, 01:04 PM   #91
dwcsr
Hollister Road Co.
dwcsr's Avatar
You'll be happy with it I'm sure.
Old 03-14-2016, 02:58 PM   #92
Elder Rogue
Elder Rogue's Avatar
I am right behind you on starting my Danforth install, so I am watching very carefully each step.
I may have to talk my son into bring his plasma cutter over when I need to notch the cross member for the R&P.
I am not going with bags so mine will be closer to what dwcsr build.
Elder Rogue is offline   Reply With Quote
Old 03-14-2016, 03:53 PM   #93
Coach529
Coach529's Avatar
A plasma will definitely shorten up your build time......I should have NEVER started this project without one.
1949 Chevy 3600
Old 03-15-2016, 12:23 PM   #94
Coach529
Coach529's Avatar
Dave, when you tap the tie rod ends to 9/16 did you have to drill them as well? Or just run the tap through?
Thanks,
Mike
1949 Chevy 3600
Old 03-15-2016, 01:30 PM   #95
dwcsr
Hollister Road Co.
dwcsr's Avatar
Thanks,
Mike
just ran the tap through
Old 03-15-2016, 02:23 PM   #96
Coach529
Coach529's Avatar
Great. Picked up a tap last night.
1949 Chevy 3600
Old 03-19-2016, 10:22 AM   #97
Coach529
Coach529's Avatar
I am trying to buy some u-joints, but do not have access to my rack right now. Is the rack a 3/4"-36 spline?
1949 Chevy 3600
Old 03-19-2016, 11:47 AM   #98
dwcsr
Hollister Road Co.
dwcsr's Avatar
Yes 3/4-36
Old 03-27-2016, 05:47 AM   #99
Coach529
Coach529's Avatar
Frame is painted and the rack is in.
I screwed the tie rod ends on until they bottomed out and checked the toe in. Looks like I am about 1-1/2 too wide in the front.
I need to verify again tomorrow, but looks like I will need to trim the rack a bit.
1949 Chevy 3600
Old 03-27-2016, 10:40 AM   #100
dwcsr
Hollister Road Co.
dwcsr's Avatar
As I recall I did as well but there is more than enough threads to do it
