Old 05-17-2015, 08:44 PM   #1
Coach529
Coach529's Avatar
Danforth Cross Member Install
After weighing all my options, I have a Danforth Cross Member on the way. IMO it is the most cost efficient way to do a IFS in a AD truck while using the stock frame. Cost of the Cross Member is $500.00 plus freight.
There are some build threads on the interweb, but nothing yet I have seen from start to finish, and it took a lot of reading to find them.
I am planning on this install late fall, but have already started looking for donor parts.
The pictures below are some that I have saved from build threads and off Facebook.
The Cross Member is based on GM metric geometry, which is the 1978-1987 GM G-bodies, parts of the F bodies, and the S/T bodies which includes the S-10 and S-15.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 05-17-2015, 08:45 PM   #2
Coach529
Coach529's Avatar
Re: Danforth Cross Member Install
https://www.facebook.com/ADTruckBuilds
http://67-72chevytrucks.com/vboard/s...=569491&page=6
1949 Chevy 3600
Old 05-18-2015, 08:48 AM   #3
fine69
fine69's Avatar
Looks sweet. I will be looking for pictures of your upper A-arms installed.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 05-18-2015, 10:19 AM   #4
Coach529
Coach529's Avatar
At this time I am not sure if I will notch to clear the uppers, or just run Tubular A Arms.
1949 Chevy 3600
Old 05-18-2015, 07:21 PM   #5
Dan in Pasadena
Dan in Pasadena's Avatar
Danforth Crossmember? Okay, I'll say it: Never heard of them.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 05-18-2015, 09:32 PM   #6
ghettoluxury
ghettoluxury's Avatar
This kit was designed by Scott Danforth to use GM metric suspension on the 47-54 frames. He is an active member on Stove Bolt and The Hamb. He now builds them for others to use for a low dollar alternative to ifs / S10 swaps.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 05-18-2015, 10:54 PM   #7
ricott
I'm sure you know it, but you can use the 2WD 98 and up Blazer steering knuckle/sealed bearing spindle/ and duel piston brakes on the G Body setup. These are really cheap in the salvage yards (just bought a complete set to upgrade the brakes on an S10. If you really want to go all out, you can use the 2WD blazer steering knuckle and sealed bearing, buy an $85 bracket, and bolt 5th generation Corvette brakes and rotors on the front. Love your build, looking forward to your upgrades.
Ricky
ricott is offline   Reply With Quote
Old 05-19-2015, 07:54 AM   #8
Coach529
Coach529's Avatar
You have to kinda dig to find info. He does not advertise at all.
1949 Chevy 3600
Old 05-19-2015, 09:43 AM   #9
Coach529
Coach529's Avatar
Ricky
Great info.....I will have to do some digging. Finding a 2WD Blazer up here is going to be tough.
1949 Chevy 3600
Old 05-19-2015, 09:45 AM   #10
Coach529
Coach529's Avatar
http://www.stovebolt.com/ubbthreads/...1096035&page=1
1949 Chevy 3600
Old 05-25-2015, 08:49 PM   #11
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
That cross member looks nice, looking forward to seeing it installed!
ChuckDriver is offline   Reply With Quote
Old 05-26-2015, 08:49 AM   #12
Coach529
Coach529's Avatar
Thanks, I am super excited to install it.
I found a donor truck, I just need to find the time to strip the front suspension off it.
To get to my preferred ride height, Scott is suggesting drop spindles, so I need to order those as well.
1949 Chevy 3600
Old 05-26-2015, 05:28 PM   #13
T Hilde
Could you notch the bottom of the frame to raise the cross member and eliminate the need to notch for a arm clearance?
T Hilde is offline   Reply With Quote
Old 05-26-2015, 05:30 PM   #14
racer357
raising/ notching the cross member into the frame lowers the truck even more, it's discussed in the thread on stove bolt. Seem like the hard way when you can buy dropped springs and spindles or easily use air bags, but Mr. Danforth notched a frame to accomplish it.
racer357 is offline   Reply With Quote
Old 05-26-2015, 05:44 PM   #15
T Hilde
I guess it would have been better to say "I should have done this" instead of giving up on that unit in my truck.
Old 05-26-2015, 05:46 PM   #16
racer357
So you have a Danforth member and decided not to use it?
Old 05-26-2015, 10:54 PM   #17
T Hilde
Had one, installed it, got cheesed off because the steering wasn't completely developed and traded the chassis away to do a dakota swap.
Old 05-26-2015, 11:15 PM   #18
racer357
Right on. I am in the process of ordering one, if you had one to get rid of I was ready to drive north! LOL!
I will post photos of mine going together.
Old 05-27-2015, 02:09 PM   #19
Coach529
Coach529's Avatar
The location of the cross member determines ride height. My desired ride height is pretty much the same as I am running now. Scott suggests a 1-1/2" bottom notch and 2" drop spindles for me to achieve this. Once I get it mocked up I will see if I need to notch the frame to clear the stock upper A Arms.
The top notch is still avoidable with a tubular upper A arm, which are pretty affordable.
http://www.ubmachine.com/uppermetric.html
1949 Chevy 3600
Old 05-31-2015, 07:27 AM   #20
Coach529
Coach529's Avatar
Random Notes:
Donors-
Any 1982-2004 S-10, S-15, T-10, T-15, S-10 Blaser, Sonoma, Hombre, Bravada, Jimmy, Cyclone, Typhon, etc. Technically GMT-325 and GMT-330 chassis
These are the same stampings as any A/G body which is any 1978-1987 Malibu, Regal, Monte Carlo, Cutlass, El Camino, Gran National, etc.
1949 Chevy 3600
Old 05-31-2015, 07:30 AM   #21
Coach529
Coach529's Avatar
Rack and Pinion:
"the 1993-1997 Camaro or Firebird. in 1998, they changed the angle of the pinion and it hits the frame. simply cut off 4-1/8" off the inner tie rod ends and rethread.
however if you desire, a ford exploder or dodge durango/dakota rack and pinion can be used as well."
"The 87 Tbird rack I used goes stop to stop on stock S10 spindles. I haven't driven it yet but i'm expecting a turn radius about the same as a long bed S10"
1949 Chevy 3600
Old 06-01-2015, 09:41 PM   #22
dwcsr
Hollister Road Co.
dwcsr's Avatar
The 87 Tbird I used came up a bit short on turning once we have this on the ground and actually driving it was about 3/4" from the stop ,not bad Its just not where I want it. I have a 97/98 Mark Viii rack on the way that turns 6.88" lock to lock and should take care of that issue. The Tbird rack was 5.33" lock to lock. I believe it has the same mountings. I'll post what I find out when I get it
dwcsr is offline   Reply With Quote
Old 06-02-2015, 09:21 AM   #23
Coach529
Coach529's Avatar
That is good info to know. Do you have a resource that tells you the specs of the rack and pinion?
I am pulling parts from a 1995 Thunderbird (same as 1995 Mark Series) and have access to that rack.
1949 Chevy 3600
Old 06-02-2015, 03:39 PM   #24
racer357
I am going to use a Sweet power servo rack in mine from stock car racing.
Old 06-02-2015, 03:48 PM   #25
Coach529
Coach529's Avatar
How much do those run?
1949 Chevy 3600
