#76 |
![]() Join Date: Jul 2012
Re: Great Grandads '53 3100
Nice progress, looking really good!
#77 |
![]() Join Date: Aug 2012
Did you need another u joint down by the rack or were you able to get away with the 2 pictured?
Thanks! |
#78 |
#79 |
Took a couple days off work and spent a long weekend on the truck. Got my fuel lines run, wiring harness finished up, new battery box mounted and most important of all. . .
http://vid469.photobucket.com/albums...01F12A51B4.mp4 Had a little help from Molly "the not so shop dog" ![]() |
#80 |
Congratulations, sounds good!
#81 |
![]() Join Date: May 2007
why is the video named "bent valves"? sounds healthy!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#82 |
that thing fired up in a hurry! very cool build!
#83 |
Ha! Well "20BentValves" is my username for Photobucket. It came from back in my VW days when I blew up my 20 valve turbo motor. That's just part of the URL i guess. From what I can tell the 5.3 is nice and healthy, but then again its so dang loud I cant hear anything. |
#84 |
#85 |
First update in several months. That being said I've still been working on the truck quite a bit. I've been keeping my instagram page current so feel free to request to follow me if you'd like to follow along. My username is stesone11
This is fairly abbreviated so forgive me. After I got the engine running, I got the the ECM and Throttle control box mounted under the dash. Managed to get it done reusing some parts from the fuel tank straps. ![]() From there i moved on to mocking up the bed. ![]() And discovered I would indeed need to add some tubs. ![]() Built the tubs from a trailer fender. It was a single fender I split in half and narrowed a bit and filled in with sheet metal. ![]() and got them welded into the bed ![]() From there I moved on to building the frame for the bed floor. The floor will tilt up to access the fuel tank and allow you to see into the chassis. One of my main objectives was to keep the floor near the stock height and I was able to come within 2 inches of that. ![]() From there I moved on to filling the stake pockets, plug welding all the holes in the bed and filling the ends of the bed rails ![]() ![]() That wrapped up the fab work on the bed so from there I moved onto repairing some rust on the front fenders. First the drivers side ![]() ![]() Then the passengers side. For this one I was able to drill out the spot welds and remove the inner piece ![]() Today I spent the better part of 9 hours stripping sheet metal hoping to have some primer on them here soon. ![]() |
#86 |
![]() Join Date: Mar 2011
Nice update, doing some great work...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#87 |
Nice progress!
#88 |
![]() Join Date: Mar 2010
Nice work....some big hurdles being over come here.
#89 |
updates?
#90 |
Lots of work completed since the last update. I'll let the pictures speak for themselves. Happy New Years guys!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Heres a little then and now with 2 years in between. ![]() |
#91 |
Nice update! Truck is looking good. Thanks for sharing.
#92 |
Wow great work! You've definitely made my new years resolution to finish my 50
My 1950 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=720858 |
#93 |
Looking super, nice job...Jim
#94 |
A320 Pilot/USAF Retired
Very nice!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#95 |
Nice work!
Looks awesome - I like the seat.
1949 - 3600 Update suspension, engine and drive it. http://67-72chevytrucks.com/vboard/s...d.php?t=691034 1953 - 3100 1955.1 - 3100 Bare Metal Build http://67-72chevytrucks.com/vboard/s...d.php?t=691261 1965 - Buick Special & 1965 Buick Skylark |
#96 |
looking very nice!
#97 |
![]() Join Date: Apr 2009
Can't wait to see this one finished , Nice work..
Desert |
#98 |
That thing is sick!! I spent too much time looking at pictures and didn't read it all. Did you have your Control Arms Powder coated?
#99 | |
![]() Join Date: Sep 2016
Curious to know about your front wheel and tire size? I have 18" Riddlers with 4.5" backspacing for the front. I haven't checked to see what tire size I need, but yours look pretty darn close.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
