Old 02-17-2017, 08:15 PM   #76
chase@ridetech
chase@ridetech's Avatar
Re: Ridetech C-10 Street Grip... Should it be next on the list?
This 73-87 StreetGrip includes everything you need.
Chase Mundy
Direct Line: (812) 481-4736
Email: chase@ridetech.com
chase@ridetech is offline   Reply With Quote
Old 02-17-2017, 09:24 PM   #77
Advanced Design
Advanced Design's Avatar
Looks good Chase. What advantages are there for using the mono spring?
Is this applicable for a long bed?
Advanced Design is offline   Reply With Quote
Old 02-20-2017, 09:28 PM   #78
Bobby Pootz
Bobby Pootz's Avatar
Would the rear swaybar be recommended to complete this kit? I know it's a complete package but only comes with the front swaybar. Curious if this kit doesn't require it. Thanks in advance!
Rob
Bobby Pootz is offline   Reply With Quote
Old 02-22-2017, 09:21 AM   #79
chase@ridetech
The composite springs eliminate spring sag and reduce the unsprung weight by around 70lbs. They also provide a great ride quality and improve the handling.
We have not done any testing on long bed trucks but I don't foresee any issues. The ride height may end up being slightly lower due to the extra weight but I can't say for sure.
Chase Mundy
Old 02-22-2017, 09:24 AM   #80
chase@ridetech
Rob
In our testing, we didn't see the need to add in a rear sway bar. The new Composite leafs, Delrin bushings, and HQ Shocks do a great job keeping the rear of the truck planted.
Chase Mundy
Old 10-05-2018, 03:58 AM   #81
68ls1
68ls1's Avatar
Currently installing Stretgrip on my 72 SWB C10, and was wondering is there a suggested set of alignment specs?
68ls1 is offline   Reply With Quote
Old 10-09-2018, 09:04 AM   #82
JohnJ@RideTech
JohnJ@RideTech's Avatar
Shoot for 0.5-1 Deg Negative Camber. 3-5 deg of Positive Caster and keep the Toe around 1/16" to 1/8" toe in.
That should get you in a pretty good position.
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 10-11-2018, 02:20 AM   #83
68ls1
68ls1's Avatar
Thanks John
Old 10-16-2018, 02:51 AM   #84
68ls1
68ls1's Avatar
Do you see a need for bump stop, what is the preferred solution, as I cannot see in instructions?
thanks
Old 10-16-2018, 08:51 AM   #85
JohnJ@RideTech
thanks
I prefer to run a bumpstop just in case. Is it necessary? That only depends on the type of driving conditions that you have.
Most of the roads that I drive on are fairly smooth so its unlikely that I would ever see conditions that would cause my suspension to be under a full compression stroke BUT I like the peace of mind that its there if I need it.
John J.
Sales/Tech
Old 10-16-2018, 03:50 PM   #86
68ls1
68ls1's Avatar
Thanks John, I like peace of mind too. So having removed rear bump stops for C Notch, how do you suggest reinstating a bump stock? Factory one would give no travel room. thanks
Old 10-16-2018, 04:19 PM   #87
JohnJ@RideTech
I run our little 1/2" bump stop. Part # 90001082. Retail I think they are $4 a piece, good piece of mind when you think it could prevent tearing up a set of $700 coilovers.
Check out the link below.
https://www.ridetech.com/?subcats=Y&...0868cb89c3445c
If you need a pair, let me know. I can just drop ship them to you.
John J.
Sales/Tech
Old 10-20-2018, 12:32 AM   #88
smokehouse
Will the 73-87 kit fit on A suburban and could you tow with it?
smokehouse is offline   Reply With Quote
Old 10-24-2018, 12:31 AM   #89
68ls1
68ls1's Avatar
Back on the ground, need to alter one tail pipe, and tail shaft appears to be very tight for length (it was most likely like this already but this work has raised issue), but very happy how it sits
Name:  on the ground copy.jpg
Old 10-24-2018, 02:56 PM   #90
68ls1
68ls1's Avatar
Ridetech have had a staff change, trouble logging in here, asked me to ask if you would like to contact Greg Fuesler at Ridetech and he will answer any questions
812-481-4732 Direct Line
gfuesler@ridetech.com
