#76 | |
Re: Window felt weatherstrip (beltline weatherstrip)
#77 | |
Be it window belt or fender or rocker! I bet the people who sell this stuff read all our posts & sit back & laugh their ass off at us! ![]() |
#78 |
It might also have to with model years. A company that makes good ones for a 64 might not make good ones for a 62.
#79 |
So precision sent me a set of belt line fuzzies. I have not gotten a chance to instill them yet but the clips look just like the originals.
#80 |
![]() Join Date: Feb 2011
Hi all
just completed installing both door beltline weatherstripping. I must say after 2 prior attempts of installing products from OER, Steele, I have found Repops brand to be the the best quality. Pliable rubber, sturdy clips, and straight as an arrow. Minor trimming and shaving for good install. First time using Repops brand, was happy with quality.
Blackula72 |
#81 |
![]() Join Date: Jun 2016
Excellent news! Thanks for posting. I'll be ordering a set.
#82 |
So this thread is a couple of years old now. Wondering if the "Repop" brand of window fuzzies is still best?
#83 |
Just checked them out. Guess you have to call for prices and ordering?
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
#84 |
I found that all the ones that I tried did not work for me. I especially don’t recommend the Steel Rubber products version. I ended up removing the clips and raising them up to run flush with the window opening and using screws to attach them. I also removed the glass from the channel and ground off some excess metal and pinched the channel and used a glass setting material to install the glass in the channel. At the same time installing the glass in the channel a little higher in the channel than before. It all works vary well now and does not bulge out my sheet metal when I roll up my window. On the passenger side all I had to do is use screws on the fuzzies. I did not have the touch the channel and the glass.
#85 | |
#86 |
No I don't believe I have. When comparing all of the products I have bought, to the originals I have, I don't think even the originals would have fixed the problems that I was having.
#87 |
#88 |
Moderator
![]() ![]() Join Date: Aug 2011
The precision units worked for me. After I made sure the mounting flanges were bent outward.
#89 | |
#90 | |
