Old 08-22-2018, 11:04 AM   #76
19SIKtySix
19SIKtySix's Avatar
Re: Speed Engineering LS Swap Headers Findings
Originally Posted by gringoloco View Post
They are the C10 specific (same part number as Chevelle) LS swap long tubes. The reason they work so well is due to the dropmember raising the engine. Stock engine location, I think the collectors will hang down 1.5” or so, too much for a heavily lowered or bagged truck, in my opinion.
I just noticed that you're running a coilover drop member, am I right? If your truck was bagged running a PB crossmember, do you think your headers would work?
I'm thinking to prevent for future clearance issues, the shorty headers would be a better option for me.
Thanks for your response and help on this!
Chuck
Instagram: c_lo_garage
Check out my 1966 C10 project "El Viejito" here:
http://67-72chevytrucks.com/vboard/s...d.php?t=674614
19SIKtySix is offline   Reply With Quote
Old 08-22-2018, 08:28 PM   #77
gringoloco
A guy with a truck
gringoloco's Avatar
No worries, this is why we post, to help each other out
Yes, the bagged Dropmember uses the same geometry as the coilover version, so they would fit with the same magic as mine, probably better, due to the absence of the upper coilover mounts.
For me, shorty headers are are not worth the pain that comes with them (blown gaskets, burnt wires, etc). There are a few nice mid-length options out there that will fit the bill and will not lose too much in translation. Hedman comes to mind with their C10 specific mid-lengths—thick head flanges, heavy gauge tubing, and ball/socket collectors. Uncoated I think are under $300
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-23-2018, 10:55 AM   #78
rgrhoward
rgrhoward's Avatar
Out of curiosity, has anyone measured the flange thickness on these headers?
I do not see it listed on the web site.
Also, any idea where they are made?
rgrhoward is offline   Reply With Quote
Old 08-23-2018, 08:47 PM   #79
NC_John
NC_John's Avatar
They are thick. A friend that is with ECR (their corvette racing side) looked at mine yesterday and thought they were actually kooks (high $$$). He was amazed when I told him they were cheap-o chinese specials.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 08-24-2018, 08:37 AM   #80
gringoloco
A guy with a truck
gringoloco's Avatar
Eyeballing, they look like 3/8” flanges. I imagine they are Asia-built, but very nicely done
-Chris
Old 08-24-2018, 09:28 PM   #81
slowcpe
slowcpe's Avatar
Looks like I may have to order a set for my Level 1 DM truck. For once I don’t have to buy the most expensive piece out there.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 08-26-2018, 02:32 PM   #82
RockhoundII
Here they are in my 79 Blazer. They clear the frame just fine, but require cutting on the passenger side of the 4l80E bellhousing. I had the same packaging issues some other people have mentioned, my driver side collector is damaged. I've had them bolted up to an LS3 with a 6L80E in the same truck and had no clearance issues whatsoever.
RockhoundII is offline   Reply With Quote
Old 08-26-2018, 02:34 PM   #83
RockhoundII
They are 3/8" flanges.
Old 08-27-2018, 10:18 AM   #84
rgrhoward
rgrhoward's Avatar
Awesome! Thanks!
Old 08-27-2018, 06:12 PM   #85
michael bustamante
michael bustamante's Avatar
update. installed mine last weekend in my 67 with a 4-6 drop, 5.3 dbw with 4l60. fit perfect, no trimming, no cutting no fabbing. nada... cleared the tranny and the starter no problem.
only part that sucked was I had to remove my brake master cylinder and booster to get the driver side in, now I gotta re bleed em again.
1967custom
michael bustamante is offline   Reply With Quote
Old 08-28-2018, 05:19 PM   #86
bs46488
I bought a set of the long tube 1 3/4 based on this thread.
5.3 with 4l65e and 3/5 drop in the truck.
The box showed up a little banged up but I just grabbed a crescent wrench and straighten things out.
The headers fit with no issues. I reused the factory trans cooler hard lines, so I needed to make some "adjustments" to the line to get them not to touch.
I installed the passenger side from the top. Drivers side from the bottom.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 09-14-2018, 04:50 PM   #87
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I purchased the upgraded gaskets with mine, but not sure which gasket goes against the block and which one goes against the header. Haven't looked at them that closely, but it dawned on me while looking through this thread. Anyone have a pic or explanation on how I should install them? Thanks,
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 09-17-2018, 09:19 AM   #88
aggie91
I'm just glad to be here!
aggie91's Avatar
You should not have 2 gaskets between the head and the header flange.
If you got sent 4 gaskets, then the upgraded ones should be the multi-layer steel versions. Without seeing what you have, The multi-layer gaskets should not have a specific side that goes against the head or the header flange...Just use one multi-layer gasket between the head and the header flange.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 09-17-2018, 09:55 AM   #89
1971Stepside
Almost Satisfied
Thanks aggie. I hadn't seen a two gasket set up, so I was confused. I guess they just sent the standard ones and the upgraded ones.
Old 09-17-2018, 04:46 PM   #90
aggie91
aggie91's Avatar
That was my guess that they sent the standard ones and the upgraded ones too.
Karl
The LST Challenge:
Old 09-21-2018, 01:22 AM   #91
62chevy302
hillbilly
62chevy302's Avatar
Are the upgraded gaskets gm stock manifold mls gaskets?
-1962 C-10
62chevy302 is offline   Reply With Quote
Old 09-28-2018, 09:52 AM   #92
cornerstone
cornerstone's Avatar
I am wondering the same thing. I ordered a set last night and added on the "upgraded gaskets". When they arrive I will post pics of theirs VS. stock GM.gaskets, although I am running a 5.3 LT from a 2014 truck, so they may be different than yours anyway... I dont know what setup you are going with.
Brian
cornerstone is offline   Reply With Quote
Old 09-29-2018, 08:26 PM   #93
62chevy302
hillbilly
62chevy302's Avatar
Ok i will be waiting on your reply
-1962 C-10
Old 09-29-2018, 09:24 PM   #94
62chevy302
hillbilly
62chevy302's Avatar
I have a 04 6.0 truck block
-1962 C-10
Old 10-01-2018, 01:08 PM   #95
19SIKtySix
19SIKtySix's Avatar
I don't have them installed yet, but for those asking about the gaskets I have a set of the shorty headers from Speed Engineering. Overall they look like quality headers for the price of them. They come with the standard "paper" gaskets and the upgraded gaskets are similar to the OEM style.
Chuck
Old 10-01-2018, 01:11 PM   #96
19SIKtySix
19SIKtySix's Avatar
Here's a couple more pics to show the quality of the shorty headers.
Chuck
Old 10-05-2018, 08:01 PM   #97
cornerstone
So the multi layer steel gaskets are a gm product.
Also my headers arrived like the rest...
Did y’all receive header bolts with your purchase? I’m guessing mine fell out of the box if they were in there in the first place.
Old 10-05-2018, 08:05 PM   #98
cornerstone
They do fit quite well though.
Old 10-07-2018, 06:59 PM   #99
Bobbed72
Bobbed72's Avatar
Attachment 1825665
Attachment 1825666
Attachment 1825667
Attachment 1825668
Attachment 1825669
I got the shorty's on mine also and I notice in your pics different exhaust gaskets. Are those some you threw in the box for safekeeping or did they send those? All I got where the style in the first pic with the clamps.
Bobbed72 is offline   Reply With Quote
Old 10-09-2018, 02:12 PM   #100
crakarjax
crakarjax's Avatar
Has anyone used the f-body long tube speed engineering headers on a C10? I have an fbody oil pan and want to find longtubes that don't have below the pan much if at all.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
