Old 12-16-2016, 09:29 AM   #76
LT7A
Re: Project "Candy Apple"
Originally Posted by ultrahd4me View Post
I can get you an exact measurement if needed, but the front is lower than the rear shock brackets.
Thanks, no measurement necessary. I'd like to use stock length shocks but didn't want to smash them all the time. I assume it's the crossmember in front that is lower?
BTW, I'm enjoying following your progress.
Old 12-31-2016, 12:48 PM   #77
UKNOWME
UKNOWME's Avatar
How's the truck coming?
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 01-03-2017, 12:31 PM   #78
ultrahd4me
ultrahd4me's Avatar
I took a short vacation from work and the truck for the holidays, but I did get a little bit done. I trimmed the engine covers and got them mounted, finished the air intake fab work but it still needs painted. Now here's where this project went south. When I changed the cooling system back to the mechanical fan I no longer needed the fan relays or wiring for the old electric fans. In the process of removing that stuff I found some other wiring that I wasn't happy with. As usual with me, the more I dug the more I found. So that led to basically a rewire from the firewall forward with proper wiring techniques and terminals. I built a new relay panel with the correct relays, fuse blocks, OBDll port, and check engine light. I still need to put a few more wires in loom, and waiting on a 18" maf extension harness.
Follow me on Instagram: @midtennc10
Youtube channel: Midtennc10
ultrahd4me is offline   Reply With Quote
Old 01-03-2017, 02:31 PM   #79
UKNOWME
UKNOWME's Avatar
Did you know you can remove that oil fill tube and the cap will screw straight into the valve cover?
1964 Chevy c10
Old 01-03-2017, 02:38 PM   #80
ultrahd4me
ultrahd4me's Avatar
Yeah, I had to trim the covers anyway because of the high mount A/C brackets so I just left the filler neck alone.
Old 01-03-2017, 02:39 PM   #81
UKNOWME
UKNOWME's Avatar
Sounds good
1964 Chevy c10
Old 01-04-2017, 05:37 PM   #82
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
looks great
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 01-04-2017, 11:00 PM   #83
nitram
nitram's Avatar
Truck is looking great... I'm interested in seeing how your 285/50 rear tires work out since I've got a set ordered myself. If you need a narrower spacer, dmvmotorsports sells a 1" hubcentric spacer on ebay for $40/pair. However, they have metric studs so you would need new lugnuts as well.
nitram is offline   Reply With Quote
Old 01-05-2017, 04:50 PM   #84
ultrahd4me
ultrahd4me's Avatar
Thanks. I'll check them out.
Old 01-15-2017, 08:58 PM   #85
68basket
Great looking truck!
68basket is offline   Reply With Quote
Old 01-16-2017, 08:46 AM   #86
ultrahd4me
ultrahd4me's Avatar
I can finally say I'm finished with the truck and spent the weekend detailing and driving this thing. It's not to the level I originally hoped for, but given my time and budget, it turned out real nice and far better than what I started with. I have the exhaust scheduled for later this week, then I'm officially done.
Old 01-16-2017, 08:48 AM   #87
ultrahd4me
ultrahd4me's Avatar
A few more.
Old 01-16-2017, 05:36 PM   #88
Desert1957
Desert1957's Avatar
Well done, another beautiful creation.
Desert
Desert1957 is offline   Reply With Quote
Old 01-16-2017, 08:44 PM   #89
ultrahd4me
ultrahd4me's Avatar
Thank you sir.
Old 01-16-2017, 11:09 PM   #90
UKNOWME
UKNOWME's Avatar
Do you have any info on the air intake setup? I need a better setup that goes to the drivers side like that.
1964 Chevy c10
Old 01-17-2017, 08:35 AM   #91
ultrahd4me
ultrahd4me's Avatar
UKNOWME I modified a 2003 Silverado air intake by cutting off and rewelding the stock mounting brackets. Then added a 90` elbow and coupling to get it to the fresh air opening on the core support. I also had a 24" MAF sensor extension harness made, and added a 4" cone filter.
Old 01-17-2017, 09:20 AM   #92
maxx442
maxx442's Avatar
Unless I missed it, do you happen to know the paint code for the red? Or the paint manufacturer? Awesome truck by the way!
maxx442 is offline   Reply With Quote
Old 01-17-2017, 10:14 AM   #93
ultrahd4me
ultrahd4me's Avatar
The red is PPG Vibrance line called "Cherry Bomb" and its a true 3 stage base/candy/clear. Paint code: Gold base 908347 & mid candy coat 908347/2
Old 01-17-2017, 10:34 AM   #94
N2TRUX
Happy to be here
N2TRUX's Avatar
Yet another beautiful build rolls out of your shop. You are the King of quick when it comes to transforming these trucks.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-17-2017, 11:22 AM   #95
ultrahd4me
ultrahd4me's Avatar
Ken you mentioned quick... How about finalizing a deal now for the truck to head to Houston.
Old 01-17-2017, 12:44 PM   #96
aggie91
I'm just glad to be here!
aggie91's Avatar
Truck came out nice. The bigger rear tire looks good.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-17-2017, 12:49 PM   #97
ultrahd4me
ultrahd4me's Avatar
Thank you sir
Old 01-17-2017, 02:33 PM   #98
maxx442
maxx442's Avatar
Thank you for the quick response. I have an '84 K30 4x4 SRW that I am just starting to round up parts for. I plan on a two-tone paint job that is basically the opposite of yours. I'm thinking your red in the middle with a gun metal gray top and bottom. If I do a cowl induction hood then maybe two SS style stripes down the hood.
Old 01-18-2017, 09:47 AM   #99
Desert1957
Desert1957's Avatar
Bobby, Did you already sell this one?
Man I didn't even get a shot, LOL.
Desert
Old 01-18-2017, 10:03 AM   #100
ultrahd4me
ultrahd4me's Avatar
Truck sale is pending, but Desert1957 I'm trying to close a deal on your next truck. SWB, solid black, gray & black interior, my drop and wheel & tire package.
