05-06-2018, 02:21 PM | #76 |
Post Whore
Re: 1967 Chevelle
I'm on the fence on black wheels also...on some things they look good...a lot don't...at least from the angle of your pics it would look killer. ..there's a local truck (56furd) about the color of your chevelle with black wheels....it looks great...I'm using stock rims on my IH build and they only come in black....I can't make up my mind to leave em or pc em white....I'm going dark red....
05-07-2018, 09:08 PM | #77 |
6>8 Plugless........
Re: 1967 Chevelle
That looks so nice. It would be nice if some of these wheel places would start doing a black chrome on wheels IMO.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-13-2018, 07:17 PM | #78 |
Re: 1967 Chevelle
I managed to make some progress this weekend in spite of being busy with quite a few other things. I got the rear end under the car, and the rear suspension in, along with the Detroit Speed frame braces. I left the rear sway bar off for now, I may or may not even run it. The rear of the car is sitting about .75" higher than final ride height will be. I stuck the rear tire in there to see how it's going to look, and I really think I'm going to like the way it sits. I'm going to rent the wheel fitment tool tomorrow and hopefully have wheels ordered by the end of the week. With my shop being on the small side, I really need to get the car off blocks so I can move it around.
Here's a picture of the 9" and the Ridetech rear suspension. I'll get a few more later.
1970 SWB Build Last edited by jmking9; 05-13-2018 at 07:23 PM. |
05-13-2018, 07:34 PM | #79 |
Post Whore
Re: 1967 Chevelle
nice.....
and diesel...they do make wheels in the black chrome...I saw them on some wheel site ...and theres a new red chevy crewcab, thats lowered, here local that has a set of black chrome wheels...it looks killer...
05-13-2018, 07:42 PM | #80 |
Re: 1967 Chevelle
A few more
1970 SWB Build Last edited by jmking9; 05-13-2018 at 07:50 PM. |
05-22-2018, 02:40 PM | #81 |
Re: 1967 Chevelle
That suspension is killer! If places start doing black chrome on their wheels, my 71 Camaro and 40 Ford would be getting some. Your rear end came from not all that far from me.
05-23-2018, 11:21 PM | #82 |
Re: 1967 Chevelle
Thanks Ryan! You should check out the black chrome and black pearl finish that Forgeline has.
1970 SWB Build |
06-08-2018, 09:08 PM | #83 |
Re: 1967 Chevelle
Small update, I got wheels ordered and they should be done in 5 or 6 weeks. In the meantime I'm going to tackle a few small projects that I've been putting off. First is replacing the steering column with a tilt. Im learning that 67's have quite a few 1 year only parts on them. One of them is the steering column. So after looking for an oem tilt for a few months, I ended up just ordering an Ididit column. I think putting the original style levers on it, and painting it to match the dash will hide some of the aftermarket look. I ordered an installation kit for a power steering box with a 13/16" 36 spline input shaft. But of course it doesn't fit. Having the Jeep Grand Cherokee box requires ordering the kit for a .75" 30 spline input that is the same as the factory manual steering box. Oh the joys of car building Here's a picture of the column (still needs painted)
1970 SWB Build |
06-08-2018, 09:36 PM | #84 |
Re: 1967 Chevelle
One of the other projects I've been dreading was figuring out a clutch pedal and the hydraulic setup to make it all work. The best thing I found as far as fool proof alignment of the pedal and master cylinder was this kit from Mcleod. It includes the firewall bracket, and a new clutch pedal that is designed just for their bracket to keep everything in line. It also comes with the master cylinder, braided line, and the reservoir. I was pretty disappointed when I opened the box and seen the parts didn't look quite like they did in the picture. Much more plastic.
I mocked it up and got the firewall cut to allow the master to pass through. I also mocked up the new clutch pedal and everything looks like it lines up perfectly. So I guess I'm going to just live with the plastic master cylinder since this kit really seems to take the guess work out of the part of equation. I was also wrong in thinking that I could just modify the original auto brake pedal to work. So I need a pedal out of a manual transmission car, which is also hard to find. The only thing I can find is a repop kit that has a brake and clutch pedal. So it looks like I will have to buy the kit just to get the brake pedal. The other problem I've ran into is that the top studs on the pedal box are too short now that I have the added brackets from the clutch master, and the brake prop valve that bolt on using the studs. But that shouldn't be too difficult to solve. Here are a few pictures from trial fitting the brake and clutch masters. I was worried that the clutch master might interfere with where the brake lines need to run into the prop valve, but it looks like it will be fine
1970 SWB Build |
07-19-2018, 06:16 PM | #85 |
Re: 1967 Chevelle
I got the upper studs taken care of, and cleaned up the pedal box. I also had to modify the spacer in the McLeod clutch linkage to line up perfectly with the master. To stay on par with every other part that goes on this car that needs modified, the pushrod for the brake master had to be lengthened. So I now have all of the pedals and steering column figured out and mounted in the car. Next will be building some brake lines to got from the prop valve to the frame.
1970 SWB Build |
07-19-2018, 11:31 PM | #86 |
Re: 1967 Chevelle
Wheels showed up! Forgeline GA3C 18x8 and 18x10 centers are satin gunmetal with polished lips.
1970 SWB Build |
07-20-2018, 03:09 PM | #87 |
Re: 1967 Chevelle
Nice!!
"Fear makes the wolf look bigger" http://67-72chevytrucks.com/vboard/s...d.php?t=305629 |
07-20-2018, 04:44 PM | #88 |
Post Whore
Re: 1967 Chevelle
Very nice....those should look killer on the velle...
07-20-2018, 10:36 PM | #89 |
Re: 1967 Chevelle
Tires mounted and wheels on. Rolled it out of the shop for the first time in a while. It felt good to get it on wheels again.
1970 SWB Build |
07-29-2018, 09:03 PM | #90 |
Re: 1967 Chevelle
Beautiful car!! Great job!!
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
07-31-2018, 05:23 PM | #91 |
Re: 1967 Chevelle
Killer work and great job! Those wheels look sweet. Boy those babies aren't cheap are they? I was looking at that Mcloud kit for my Camaro and if I go with a 5 or 6 speed later on I might get it.
07-31-2018, 10:29 PM | #92 |
Re: 1967 Chevelle
Thank you! I appreciate it
Thanks Ryan. They are definitely not cheap. But I have to say, the quality and attention to detail on them is first class. But at their pricepoint, they should be.
1970 SWB Build |
08-21-2018, 09:50 PM | #93 |
Re: 1967 Chevelle
I took a couple weeks off working on the car to do a project on the house. Once that was out of the way, I went to work building the brake hard lines and getting flex lines. I got those wrapped up last weekend. I pushed the car out to clean the shop and took what I thought was a cool picture of my truck with the Chevelle in the background.
1970 SWB Build |
08-26-2018, 10:01 PM | #94 |
Re: 1967 Chevelle
Space is limited in my small shop, so I put the hood on just to lower the chances of it being damaged while sitting on the fender stand. It makes it look so close, but I know it's sooo far away
1970 SWB Build |
12-01-2018, 10:16 PM | #95 |
Re: 1967 Chevelle
Haven't posted anything here in a while, but i'm still slowly working on the Chevelle. I've been working on few house remodeling projects that has taken up my spare time. But I have still managed to get a few things here and there done to the car.
1970 SWB Build |
12-04-2018, 06:52 PM | #96 |
Re: 1967 Chevelle
It's a long journey to make them the way you want. Yours is coming out fantastic. I've owned my 66 SS since 1984. Still doing things to it.
12-17-2018, 07:35 PM | #97 |
Re: 1967 Chevelle
Looks great
Dwight |
06-16-2019, 11:07 PM | #98 |
Re: 1967 Chevelle
Wow, it's been a while since I updated this thread. For a variety of reasons that I won't bore any of you with, I haven't been working on the car much over the last several months. But I'm getting back on it. Last week I got the transmission In from Silver Sport. It's a tko600 with the .64 OD. A friend of mine had a 454 long block laying around and let me borrow it for mock up. Im going to instal all of it in the car so I'll know where, and how much of the transmission tunnel to cut. I'll post updates as I move along
1970 SWB Build |
06-17-2019, 07:52 AM | #99 |
Re: 1967 Chevelle
Looking good, keep plugging away at it....
Robert |
07-14-2019, 12:25 AM | #100 |
Re: 1967 Chevelle
I installed the engine and transmission and cut the tunnel to clear the tko600. I broke a piece of 18 gauge into a 2'x3' rectangle and bent it around an electrical pole to get the basic shape I needed. From there, I just slowly cut, and formed it into exactly what I needed. It's worth mentioning that while I was building the tunnel, the trans tail shaft about 2 or 3 degrees higher than where it should be. I did this just to make certain I had plenty of clearance.
1970 SWB Build |
