11-03-2012, 09:47 PM | #976 |
A guy with a truck
Re: How to: Ruin a perfectly good C10
Again, really nice stuff. Everything bolted right up, no problems. Nice to have a product that performs as advertised and not have to worry about having sent them out for powder before mock-up. I painted the rotors and calipers the same scheme as the front brakes--I think they turned out well. Part of me wants to paint the calipers red, but I think the subtle grey fits this truck better...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
11-03-2012, 09:52 PM | #977 |
A guy with a truck
Still have to re-flare the axle hard-lines to mate up with the Kore3 braided lines--if that doesn't work, I'll just bend up some new. I like the end result; looks almost factory
In final assembly, I did find that I will need longer wheel studs and that the pad slightly contacts the rotor hub when rolling. Studs are cheap and I should be able to modify the pad backing plate to clear...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 11-03-2012 at 09:59 PM. |
11-03-2012, 10:14 PM | #978 |
67-72 parts collector,…
Great work as always!
Is there any braking advantage to placing the caliper on the front side of the axle vs the rear side? I would also be interested in the "longer wheel stud" part number you use.
11-04-2012, 12:27 AM | #979 | |
A guy with a truck
11-04-2012, 01:13 AM | #980 |
A guy with a truck
A little research found this:
Stock rear stud: Dorman 610-138 Knurl Diameter 0.535 Package Quantity 10 Quick-Start Nose No Shoulder Length 0.3125 Stud Material Steel Thread Handling Right Hand Thread Thread Size 1/2-20 Under Head Length 1.53125 Wheel Stud Style Serrated Stud Potential replacement: Dorman 610-258 Knurl Diameter 0.536 Package Quantity 10 Quick-Start Nose No Shoulder Length 0.25 Stud Material Steel Thread Handling Right Hand Thread Thread Size 1/2-20 Under Head Length 1.71875 Wheel Stud Style Serrated Stud So, approx 4 more threads engaged which should be 9.5-10, using the "engage the same depth as diameter" rule, on a 1/2-20 stud- this is just about perfect. Posted via Mobile Device
11-04-2012, 05:17 AM | #981 |
Thanks for the Dorman parts numbers.
11-04-2012, 10:10 AM | #982 |
A guy with a truck
NP! FYI, I checked the application on those studs and its what GM used on the Cadillac rear discs in the late '70s, so I think we have a winner
11-04-2012, 10:45 AM | #983 |
Truck and auto performance nut
nice work as always. I couldn't tell for sure from the pics...but it looked like there's no inner or outer parking brake. Are you running w/o, did I miss something, or do you have something else in mind?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
11-04-2012, 01:57 PM | #984 |
Looking good, nice work!
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac |
11-04-2012, 06:57 PM | #985 | |
A guy with a truck
Thanks! Chipping away... In related news, I picked up a 610-258 at the LAPS-- doesn't look like they will be long enough, so on to the next plan, whatever that is... Posted via Mobile Device
11-04-2012, 07:24 PM | #986 |
Just curious. There are trans tailshaft and rear axle pinion type p-brakes that attach to the d-shaft.
11-04-2012, 08:54 PM | #987 |
A guy with a truck
I've had that thought, too. Hard to find an affordable pinion option. Who makes those you posted? What's the cost like? I can upgrade to the Eldo calipers for a couple hun.
11-04-2012, 09:04 PM | #988 |
A guy with a truck
Ok, studs. The stockers are too short for the discs, the other replacements aren't much longer, so the third option is a F*rd part.
Dorman 610-298 Type : Serrated Stud Thread : 1/2-20 Knurl Dia. : .547" Length : 2" Shoulder Length : 11/16" I grabbed one of each from the LAPS for comparison:
11-04-2012, 09:10 PM | #989 |
A guy with a truck
Length comparisons. I will have to slightly enlarge the axle holes to fit the .547 knurl of the longer studs, but I can live with that. Also may have to use long lug nuts or trim the speed-start tips...
11-04-2012, 09:19 PM | #990 |
Couldn't say...just did a few keyword searches.
Seems the 9" has the most options. I'm guessing captainfab could come up with something for our 12 bolts tho!
11-04-2012, 10:00 PM | #991 |
nice job !!! i personally like the calipers on that gray on your truck !!!!!
check out my build thread 71 c/10 step side 5.3 twin turbo http://67-72chevytrucks.com/vboard/s...d.php?t=485320 raul |
11-04-2012, 11:10 PM | #992 |
Nice build man. I may be late but never to late to subscribe.
11-04-2012, 11:32 PM | #993 | |
A guy with a truck
Thanks! Welcome aboard Posted via Mobile Device
11-18-2012, 09:19 PM | #994 |
A guy with a truck
Okey-doke. Finally wrapped up the brake install. Got the '70 Corvette master cylinder and combo valve mounted. The new studs also worked out perfectly for the rear; I didn't even have to drill, they pressed right in and give 13-14 turns of the lugnut before they're snug.
Boring pic sorry, but after my wife helping bleed the lines and bedding-in the rear pads, this beast STOPS! Calling this part of the project done Next up, lower control arms and steering linkage...
11-18-2012, 09:30 PM | #995 |
where's the pix of the master and valve ?
11-23-2012, 08:48 PM | #996 |
A guy with a truck
Sorry I missed your comment--been doing the family thing and spending time chasing down a possible new project--I need a 67-72 that I can haul the family in
Shot some pics just for you So, after installing my expensive, custom 1" bore master cylinder and having basically no pedal feel and loooooong travel, combined with poor stopping, I swapped to a '70 Corvette power brakes 1.125" deep bore style I picked up at the LAPS. Painted 'er up with the same Eastwood grey I used on the calipers; it bolted right up to the booster and my existing lines screwed right in. Works like a charm--pedal feel returned and it locks 'em up no problem. The combination valve is a CPP unit that I picked up on eBay for cheap. All the lines screwed right into it as well, thanks to GM standardization. Crappy, night-time, cell-phone pics- sorry, it doesn't like to focus at night...
11-24-2012, 12:31 AM | #997 |
[QUOTE=gringoloco;5718943]Sorry I missed your comment--been doing the family thing and spending time chasing down a possible new project--I need a 67-72 that I can haul the family in
cool , so i take it we are looking for a sub then !!!!
11-24-2012, 10:07 AM | #998 |
PROJECT 7DEUCE
I vote for a blazer for the family project...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-24-2012, 11:23 AM | #999 |
A guy with a truck
Well, you're both right, kinda. I started out looking for a Sub, since its the logical family hauler choice. I like the look of them slammed, but while looking around some, I showed a few to my wife, who made a face like she smelled something awful. When I showed her a Blazer, it was "ooh, that's nice". She also told me she knows how much I miss my old Blazer (I tell her so every time I come across a picture of it, or see a nice one at a show), so we're leaning more towards a Blazer at this point. I'd like to find a nice 2wd, but will settle for the right 4wd that I can later convert
More to come Posted via Mobile Device
11-24-2012, 12:37 PM | #1000 |
Just cant get the Blazer out of the memory bank EY!!!!! I know of a couple that are decent.
67- 72 Parts collecter |
