Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 05-31-2009, 01:50 PM   #1051
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Not all utility seats are created equal!!! There is a height difference caused by the rear bracket. Passenger side seat doesn't look to bad for being 37 years old. Recovering in the future if I can find the correct matrl.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-31-2009, 03:33 PM   #1052
69-72
69-72's Avatar
Re: PO has me PO'd
If you are looking for that exact material that is already on the seats SMS auto fabrics has it, I bought some fabric to do my regular buckets and they sent that stuff by mistake.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 05-31-2009, 04:56 PM   #1053
RED72blazer
urban fourwheelin
RED72blazer's Avatar
Re: PO has me PO'd
that's good to know. I've got a set of utilities that I'd like to recover.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 06-01-2009, 12:16 AM   #1054
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Great info., yes I have been looking for it, I would rather keep the seats original
SAFETY FIRST
AS usual, off topic
Jim
Old 06-02-2009, 12:39 AM   #1055
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks, sent the request off today for samples. Appreciate the heads up
SAFETY FIRST
AS usual, off topic
Jim
Old 06-02-2009, 01:11 AM   #1056
RED72blazer
urban fourwheelin
Re: PO has me PO'd
Can't wait to see how this turns out.
Old 06-02-2009, 01:49 PM   #1057
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks Red...Here's some pics of the last of the mechanical side problems solved on the cooling system. Someone really did their engineering on these three parts, tight fit but it all works. ARP came thru with the 3 1/2" studs (3/8" course,fine) 12 point flanged nuts w/ washers today. They also sent the bolts for my fuel pump
Now it's on to the relay, fuse,for the pump and controller for the fan
Modified my coil bracket for my fuel filter
SAFETY FIRST
AS usual, off topic
Jim
Old 06-02-2009, 01:53 PM   #1058
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Re: PO has me PO'd
Wow, that looks good! You're almost there!
Don't you love it when a plan comes together.?
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 06-02-2009, 01:55 PM   #1059
RED72blazer
urban fourwheelin
Re: PO has me PO'd
I may have missed the point of why you are putting all this cool stuff on the front of your engine....it's very High-techy or NASA-esque. either way I like it.
Old 06-02-2009, 01:57 PM   #1060
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Yes I do! Sorry I couldn't help you out on your leaf springs, what's your plan of attack
SAFETY FIRST
AS usual, off topic
Jim
Old 06-02-2009, 02:02 PM   #1061
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Is that a word? We may have to include it into the Webster
Reason being, return hose from the top of the heater core. Electric water pumps do not have an outlet/inlet for it
And I hate worm drive clamps LOL
SAFETY FIRST
AS usual, off topic
Jim
Old 06-02-2009, 02:06 PM   #1062
Chevyman63
Chevyman63's Avatar
Re: PO has me PO'd
No problem!
I called a company that does only suspensions today and they said it would be no problem to get a new leaf. $45 plus bolts, sounds good, but I'm still a little concerned about an uneven stance. On the other hand, it is the second to the shortest leaf, so it may not make a difference.
The price for a new leaf is much more economical than a new pair of springs.
So to answer your question...I still have no idea.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 06-02-2009, 02:07 PM   #1063
RED72blazer
urban fourwheelin
Re: PO has me PO'd
Ha ha ha. I don't think that's a word, But i like to make things up as I go.
any reason for the electric pump? other than cool factor
Old 06-02-2009, 02:13 PM   #1064
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
No, not really, just want to do something differant, still don't know if it will hold up on the street. Pro comp says it will, but we will see...plus the cool factor
SAFETY FIRST
AS usual, off topic
Jim
Old 06-07-2009, 12:30 PM   #1065
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Got todo a little work on the fuel pump the other day. Found out that paint stripper helps remove baked on 37 year old gaskets the PO never took down to bare metal. Also, seems like my fuel filter needed adapters that has o-rings in it, all the fittings I tried were sloppy, lucky for me the local hydraulic shop knows what he is talking about.
The bend in the fuel hose is a little tight, just starting to collapse, so I plan to buy a spring to reinforce that. Weird thing is, my main fuel line is 5/16" and the fuel pump is 3/8"
Also, I found out that if you use assembly lube on the fuel pump drive shaft it will keep it up in the block while you install the fuel pump
Make sure your engine is at the proper rotation, so the shaft is as far up in the block as it will go, makes it easier to assemble the fuel pump
SAFETY FIRST
AS usual, off topic
Jim
Old 06-07-2009, 09:19 PM   #1066
msgross
msgross's Avatar
Re: PO has me PO'd
did you have all those fuel lines made at a hydraulic shop?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-08-2009, 12:21 AM   #1067
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
No, it's just standard industrial push on barb like all the rest, you can back it up with a worm drive clamp, if you don't trust the barb. It is a 3/8" fuel hose, which is AN -6. Once I figure it out in brass, then I order my aluminum pcs.
I've had 150psi shop air on the barbs and haven't had one come apart, so it should hold up to fuel pressure
SAFETY FIRST
AS usual, off topic
Jim
Old 06-12-2009, 01:13 AM   #1068
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Got a delivery from the brown truck
Oil pump primer
3/8" aluminum tubing and fittings
AN wrenches
Had to play with the parts rite away and found out you can't bend over 90 degrees w/o a spring to support the tubing, but this stuff bends really easy, cool stuff
Tech Dept. helped me find the adapter to the carb with a male AN-6, nuts and sleeves make this a super easy hook up. I couldn't justify spending 100 bucks for the flaring tool(using it only 3 times) so I called my local hydraulic hose shop and he said he would flare the tubing to 37 degrees. The lenght of the tubing at the carb is wrong, waiting to find out how much room he needs for his flaring tool
Oh yeah, SMS sent me samples of the grain, looks to be right on. Waiting for the samples of the mechanical embossing...thanks 69-72
SAFETY FIRST
AS usual, off topic
Jim
Old 06-12-2009, 05:23 AM   #1069
Chevyman63
Chevyman63's Avatar
Re: PO has me PO'd
Sweet! That's going to look great Jim!
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 06-12-2009, 10:34 AM   #1070
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks Tim...just got the samples in the mail from SMS, exact match on the embossing, about 50 bucks a yard was the quote for the material. Don't know if they charge more for the embossing
Anyway, headed up into the mountains for the youngest sons bachelor party(wedding next week) He wants, guns, clay pigeons, fishing, 4WD's, ATV's, and Dirt bikes for his party. Looks like I raised another one right Looks like I'll be the Safety Manager, since there will be beer there. I'll get a chance to drink my whiskey after the shooting stops!!!
SAFETY FIRST
AS usual, off topic
Jim
Old 06-12-2009, 12:35 PM   #1071
Chevyman63
Chevyman63's Avatar
Re: PO has me PO'd
Great news on the material.
Sounds like a good time...and it sounds like a safety manager may be needed.
Have fun and remember...never drink and shoot...always set your beer down first, you wouldn't want it to spill.
BTW Jim, did you go with the SS lines from inline or the regular steel? I think I'm going to order mine from them next week.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 06-14-2009, 07:32 PM   #1072
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I went with the SS, IIRC, it was only 10.00 more per line. Sounds like some progress from you will be coming to report
SAFETY FIRST
AS usual, off topic
Jim
Old 06-14-2009, 08:36 PM   #1073
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: PO has me PO'd
Jim, it is really coming along nicely. I am inerested as well to see if the water pump will do the job.
I hope you had a fun and safe weekend.
Doug
low'n slow is offline   Reply With Quote
Old 06-14-2009, 09:16 PM   #1074
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Doug
Thanks Doug, Well sorta safe...One of my sons friends, ex dirt bike rider in his mid 30's, flipped my other sons dirt bike on himself so we told him to ride the quad and he proceeded to flip that on himself
My batteries went dead in my camera so I have to wait until the other guy gives me a link
Unbelievable guy weekend and we decided to make it a yearly event, so anyone in the area is invited next year!
SAFETY FIRST
AS usual, off topic
Jim
Old 06-15-2009, 05:09 AM   #1075
Chevyman63
Chevyman63's Avatar
Re: PO has me PO'd
I sure hope so. It's about time!
Glad to hear your weekend went great!
I'm not sure if I'm going to go with the SS or plain steel. And I see that In-Line offers a 1/4" front to rear fuel return line, but I didn't have one on my Blazer?
1972 4x4 Blazer
RIP
- CLR 10/11/09
