Old 04-15-2012, 09:26 AM   #1051
mooseknuckles
mooseknuckles's Avatar
Re: My 86 build
a manual switch......
mooseknuckles is offline   Reply With Quote
Old 04-15-2012, 09:36 AM   #1052
motornut
78K & 79C Jimmys
motornut's Avatar
Re: My 86 build
Originally Posted by mooseknuckles View Post
started building the trans tunnel, got the front of the hump welded in....may finnish it up tomorrow.....
awesome...
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 04-15-2012, 10:25 AM   #1053
kikkegek
kikkegek's Avatar
Re: My 86 build
oke, thanks. but how do you know when you have to turn it on? do you have a temp-gauge for the trannycooler?
kikkegek is offline   Reply With Quote
Old 04-15-2012, 02:58 PM   #1054
Matt R
Matt R's Avatar
Re: My 86 build
I haven't checked ur thread in a while. Looking great man!!!!!
My build thread http://www.67-72chevytrucks.com/vboa...d.php?t=494247
Matt R is offline   Reply With Quote
Old 04-15-2012, 03:13 PM   #1055
mooseknuckles
Re: My 86 build
no...the switch is made to come on at 180* and off at 160*
Old 04-15-2012, 03:36 PM   #1056
mooseknuckles
Re: My 86 build
lucky me got to some more cutting, grinding, and welding today.....finnished the notch for the driveshaft and still need to finish the middle part, but I'm waiting on fittings for the tranny lines....figure it's easier to do them now when I can reach them....gonna run -6 an lines back to the cooler, thats prob gonna be mounted under the bed....
Old 04-15-2012, 03:40 PM   #1057
mooseknuckles
Re: My 86 build
also ran the wiring for the stand alone harness, got most of it hooked up....and bolted the intake on....still have to run the trucks harness and wire it in......soon!
Old 04-16-2012, 09:38 AM   #1058
dgreen
Re: My 86 build
Lookin good!
dgreen is offline   Reply With Quote
Old 04-16-2012, 05:59 PM   #1059
mooseknuckles
Re: My 86 build
thanks.
Old 04-19-2012, 08:39 PM   #1060
mooseknuckles
Re: My 86 build
gotta make a parts run tomorrow, but I'm hoping to get this thing ready to fire up this weekend...
Old 04-20-2012, 10:26 AM   #1061
truckzilla
truckzilla's Avatar
Thumbs up Re: My 86 build
That would be awesome John! Good luck and I hope you can post a video and let us know what it sounds like!
truckzilla is offline   Reply With Quote
Old 04-20-2012, 05:42 PM   #1062
mooseknuckles
Re: My 86 build
I'm still waiting on my tranny fittings, so that prob aint gonna happen now...
Old 04-20-2012, 05:43 PM   #1063
mooseknuckles
Re: My 86 build
picked up my trans dipstick thi morn and got that in...
Old 04-20-2012, 05:45 PM   #1064
mooseknuckles
Re: My 86 build
also made up some hoses, and mounted the trans cooler under the bed...
Old 04-20-2012, 05:54 PM   #1065
mooseknuckles
Re: My 86 build
messing around with the trucks wiring, and got some of it ran, trying to clean it up some, got rid of that distribution block thingy, and ran the starter wires and alt wire...
Old 04-21-2012, 07:04 PM   #1066
mooseknuckles
Re: My 86 build
did some more wiring today.....filled the motor up with oil and gave it a few cranks....still have more to do.....
Old 04-21-2012, 11:46 PM   #1067
CuRtdOgG
CuRtdOgG's Avatar
Re: My 86 build
Awesome dude!! Can't wait till I'm as close to starting mine as you are ! Looks good too!! Get that baby on the road and give us a video!!
CuRtdOgG is offline   Reply With Quote
Old 04-22-2012, 02:31 PM   #1068
83_shortwide
Re: My 86 build
What type of AN hoses did you run with the tranny cooler? Build is looking good.
Bo
'83 C10, LQ4, 4L80E
83_shortwide is offline   Reply With Quote
Old 04-22-2012, 04:29 PM   #1069
mooseknuckles
Re: My 86 build
these....but I still don't have 'em yet.........and there holdin' me up...
Old 04-22-2012, 05:35 PM   #1070
mooseknuckles
Re: My 86 build
more wiring!....got the tranny cooler wired up with the t-start and relay, fuel pump wired up and working, oil pressure sending unit wired up...I still have a few more things to wire up like the brake switch and neutral safety switch, also the radiator fans as soon as I get the front ned back on...hopefully the tranny fittings will show this week so I can finnish the cooler lines and add some fluid...I had the motor cranking over and getting very excited to hear this thing run....
Old 04-23-2012, 06:14 PM   #1071
mooseknuckles
Re: My 86 build
the tranny fittings came in the mail today!!...also had a "snow day" so I took advantage of it and got the cooler lines done and hooked up, and filled the tranny with fluid......
Old 04-23-2012, 06:21 PM   #1072
mooseknuckles
Re: My 86 build
here's a pic just after I shut it off!....yeah it runs!!...so effin excited!.....I just primed the pump and was checking for leaks, and hit the key just to "see", and it fired right up and idled away....still need to get a MAF, and I'm waiting on the water pump...but I'll get the front end back on, and drop the rad in, and wire the fans up, and hopefully run it some more to get the bugs out....
Old 04-25-2012, 12:56 AM   #1073
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Re: My 86 build
Very cool!!
Post a video once you run it for a bit!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 04-25-2012, 06:06 AM   #1074
dgreen
Re: My 86 build
sooo sick!
Old 04-25-2012, 06:48 PM   #1075
mooseknuckles
Re: My 86 build
Originally Posted by Gordonr1973 View Post
Very cool!!
will do...
Originally Posted by dgreen View Post
sooo sick!
thanks.
