#1051 |
Post Whore
![]() Join Date: Mar 2013
Re: What did you do to your truck today part III
Reset the points on crustine's dizzy today. .016 is the recommended gap...I think I had them at some .024. lol Might be why she idle a little rough sometimes. New dizzy on its way though.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#1052 |
Like the dash insert? More info please?
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
#1053 |
Here's what I did!
Started with the first picture. Ended with the last two pictures. Believe it or not, progress was made. I probably have one more treatment before all the old paint is gone, then some primer to keep it from flashing over before the raptor liner goes on. Now I gotta figure out what holes to keep! ![]()
#1054 |
It's not my truck, but it's going to free up some space and get tons of use. .. old Island out of kitchen who know...
#1055 | |
I bought a bunch of the plastic plugs that are used to hold the OEM style pad in place. I plan to use the plugs until I figure out (like you) which ones are keepers. Needless to say, it's a slow process. I can shoot you some pics of my 1965 firewall in different stages of reassembly so you can tell what goes where. Just shoot me a PM with your email. Why do you have a BIG square hole where the "through the firewall" main connection goes?
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. Last edited by Lugnutz65; 05-25-2015 at 06:38 PM. |
#1056 |
Installed traction control to the bed
#1057 |
Thanks I appreciate that! Ahhh, yes, the awesome PO Mod hole that you are referring to is a special option that was only available on one truck. So I have a rare truck indeed. Not really, the po cut a ginormous hole to fit some fuse panel there. The wiring on this truck looked like a monkey on crack did it.
#1058 | |
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
#1059 |
thanks alot but another member here sent me a section of firewall for me to weld in. Pretty cool deal actually.
PM on the way.
#1060 |
![]() Join Date: Sep 2006
I only kept a few holes. Since I used a different gas pedal I used the old linkage hole to feed my wires to the engine.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#1061 |
Post Whore
Pictures of the P/b booster offset mount for Lugnutz. No that's not a brake fluid leak. lol
#1062 |
NOT all today but getting more done on 63 GMC V6 to 350 swap and a few updates like headlight relays, daytime running headlights (low beam on with key and switches to park lights when light switch is pulled on) (relays are so nice) built my own engine wiring harness, found a nice flex line for the HYD.clutch, installed horn relay, horns from a 80 Oldsmobile (behind headlights/grill)
#1063 |
![]() Join Date: Aug 2013
welded and ground down my original worn out clutch bits
#1064 |
Post Whore
Looks like the throttle shaft from here. lol
#1065 |
Good for another 200,000 miles...... nice job
#1066 |
Picked up a set of 462 heads to go with the short block from last week.
#1067 |
I'm such a freekin cheapskate that I dismantled 2 fuel tank senders and made 1 that worked!
They were both in a junk pile, but one had a broken fitting, and the other had a rusty resistor assembly. 10 minutes later---Tah-Dah!! ![]() |
#1068 |
You cant do that with the junk they build today LOL
#1069 |
#1070 |
#1071 |
I ordered these knock offs and tried them on today. I just don't like them. They look a little better with the trim ring but still not that much. Back they go.
#1072 |
after 5 long months my truck past an m.o.t,this is what we have to have in England, so after sorting out the turn signals,horn ,front lights,new hand brake to go with the power brakes,it is on the road,now im gonna driver the arse off it
#1073 |
Agreed. I think if they didn't stick out so far they'd look much better. But I have always wondered how they'd look on our trucks.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#1074 |
Post Whore
New parts in! Yeehaw!
#1075 |
![]() Join Date: Feb 2014
Congrats! how about some pics of that first ride?
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400 1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver John 3:16 |
