09-15-2020, 10:28 AM | #1051 |
Re: What did you do to your truck today part IV
Should look beastly.
09-15-2020, 04:07 PM | #1052 |
Gave mine a wash, and Cermanic Coat before Rod Run this weekend.
09-15-2020, 04:23 PM | #1053 |
09-15-2020, 05:28 PM | #1054 |
'New Age' version of polishing using chemicals.
09-16-2020, 08:35 AM | #1055 |
How does it hold up does it need to be recoated often
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
09-16-2020, 07:53 PM | #1056 |
Installed my gauge cluster and had to see what it looked like at night.
09-16-2020, 09:21 PM | #1057 |
There’s something about those original dashes. Looks really good
09-17-2020, 06:14 AM | #1058 |
Done whit the uppholstery of my -62 Panel. |
09-17-2020, 09:07 AM | #1059 |
Thanks Forest...I appreciate it.
09-17-2020, 09:13 AM | #1060 |
IDK. Never had anything nice enough to try it out on except my CC Dually which would be like paying to have a land yacht done.
09-17-2020, 09:48 AM | #1061 |
Moderator
09-17-2020, 09:57 AM | #1062 |
HAHAHAHA Was never a horror movie fan and I am glad I never saw that movie...I just know the reference. I won't tell my wife that though...haha
09-17-2020, 11:55 AM | #1063 | |
09-17-2020, 12:27 PM | #1064 |
Junior Member
09-19-2020, 02:02 PM | #1065 |
Finished the conversion to a dual master cylinder.
Took it out for a test drive and it worked nice. Except I found out that while my turn signals work, my brake lights & rear park lights do not. They did a few weeks back...damnit, what happened?
I'd like to propose a toast... to internal combustion and wind in the face. ~Michael Sarrazin "The Gumball Rally" |
09-20-2020, 02:35 AM | #1066 | |
How did you atatch the roof? |
09-21-2020, 09:50 AM | #1067 |
Finally got around to installing the side vents from CorvetteJim. Also installed door jamb switches and under dash courtesy lights.
09-21-2020, 09:53 AM | #1068 |
Looks good. I still have to install the door ham courtesy lights. Was it hard at all? Any pics of the switches in the door jamb or advice?
09-21-2020, 11:26 AM | #1069 |
Wasn't hard at all. If you look just to the left of the driver's ac vent in the door jamb, you'll see where I mounted the driver's side switch. The passenger side switch is mounted in the same place on the other side. I used 68 corvette door jamb switches that I picked up at the local parts store. Since I have no access to the back and wanted the switches to thread in, I drill a 1/4" pilot hole, then used a punch to enlarge it. This essentially rolled the metal inward giving me more material to tap. To give the wire a place to run through, I drilled a 3/8" hole 1/2" above the lower bolt that secured the dash to the A-pillar.
09-21-2020, 08:47 PM | #1070 | |
Who Changed This?
09-28-2020, 11:57 AM | #1071 |
I pulled my seat out to take to the upholstery shop. Just showing I still have the factory jack under the seat. I have no idea if it works or not. At least I think that is the factory jack.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
09-28-2020, 01:46 PM | #1072 |
Moderator
Looks like it to me. Even has the ceremonial hydraulic leak.
09-28-2020, 02:44 PM | #1073 |
That is pretty cool...leak or not. haha
09-30-2020, 02:20 PM | #1074 | |
Dan "Ratman" Ratcliffe Fourth generation Chevy truck guy, raising the fifth 1978 Scottsdale Big 10 "Bad Medicine" Daily Driver 28 yrs 1965 C10 Panel Truck "RWC" http://www.67-72chevytrucks.com/vboa...d.php?t=749003 |
10-04-2020, 11:23 PM | #1075 | |
