Closed Thread
Old 10-01-2011, 01:07 AM   #1076
VA72C10
VA72C10
VA72C10's Avatar
Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
I am sure you can grind the small amount needed off with no issues. That's what everyone else has to do to get the rotors to fit properly...just do a little at a time and test fit until it fits correctly.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline
Old 10-01-2011, 02:05 AM   #1077
relaxedsierra
relaxedsierra's Avatar
Will have to ask my friend what he is running
relaxedsierra is offline
Old 10-01-2011, 02:09 AM   #1078
relaxedsierra
Originally Posted by relaxedsierra View Post
My buddies truck...
Old 10-01-2011, 07:51 AM   #1079
mcbassin
Still Learning
mcbassin's Avatar
My buddies truck...
Looks like your buddy is running Coys.
mcbassin is offline
Old 10-01-2011, 08:29 AM   #1080
Andy4639
Old member
Andy4639's Avatar
Question Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
Originally Posted by funkytechmonkey View Post
check page 41.
Back to my question... Is it safe for me to grind on this rotor or will I screw something up? whats my best option?
I would be ordering a new rotor!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 10-01-2011, 11:17 AM   #1081
big mike71
big mike71's Avatar
That's a sweet GMC.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline
Old 10-01-2011, 11:34 AM   #1082
dkauffman05
dkauffman05's Avatar
Has anyone put any 18x9.5 on the rear of a 67-70 step. Im bout to take the plunge and i know i will prob need a 1-1/14 spacer depending on tire. If so what tire size did you go with .
dkauffman05 is offline
Old 10-01-2011, 07:37 PM   #1083
dkauffman05
I was thinking 285-50-18
Old 10-01-2011, 11:12 PM   #1084
BossHogg69
motor exploder
BossHogg69's Avatar
Yes, and you don't need a spacer for the 18s. I have them on my 69 stepper. If you use 1.25" spacer, the outer edge our your tire will get shredded by your fender! If anything, maybe a .25" just to center up the wheel in the fender from side to side so they don't sit in too far, and that's only if you're really picky (like me). I actually used a .5" spacer and totally cut out the fender lip, but I'm going for a little different look, and what I did was not necessary to make the wheels fit.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline
Old 10-03-2011, 11:42 AM   #1085
nt30
Subscribing for updates.
nt30 is offline
Old 10-03-2011, 12:14 PM   #1086
brossow
Amateur Rust Fighter
brossow's Avatar
FYI, you can subscribe to a thread using the "Thread Tools" menu at the top of every page; you don't need to post just to subscribe. No harm done -- just mentioning it since a lot of people don't know this.
Welcome to the site!
Brent
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline
Old 10-19-2011, 02:21 PM   #1087
tattoed71
tattoed71's Avatar
check out the ridler 5 spoke wheel there similar to the 338s but they fit with no problem and come and gray center and black center i bought a set for my 71 love em and easier on the wallet then the 338s
tattoed71 is offline
Old 10-19-2011, 02:30 PM   #1088
brossow
brossow's Avatar
And they're made in China, not in the USA like the Boss wheels.
Brent
brossow is offline
Old 10-19-2011, 02:59 PM   #1089
1967wannabe
1967wannabe's Avatar
You beat me to the punch, I was gonna say "Hecho en?"
1967wannabe is offline
Old 10-28-2011, 06:45 PM   #1090
dkauffman05
I just dropped my 67 stepside 5-7 plan on buying some 338s this week you guys think i can run a 295-45-18 in the rear ? i do have a adj track bar.
Old 10-28-2011, 06:52 PM   #1091
funkytechmonkey
funkytechmonkey's Avatar
That's what I ordered at first then realized they were a little taller than I wanted so I decided to go with 295 40 20... Now they are on backorder for 3 weeks
Never wrenched a day in my life and now...
Im doing a frame off restoration on a 1968 C10
with a Porterbuilt Dropmember, Acuair E-Level kit,
Boyd Welds Gas tank and mild c-notch.
Click here to view my build
funkytechmonkey is offline
Old 10-29-2011, 05:51 PM   #1092
dkauffman05
Does the latest 18x9.5 have a 94.62 hub bore ? i hope so i had my stock axles redrilled today to 5x5 and tried some vett ralleys on but they would not go over my hub. from what i can find on the net the 5x5 338's are a 94.62 bore which will is about 3.725" and my axles are around 3.5 roughly using a tape. Just want someone to confirm before i have to put my axles in the lathe.
Old 10-29-2011, 06:54 PM   #1093
Andy4639
Old member
Andy4639's Avatar
Wink Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
Mine fit fine with no problems on the rear.
Andy4639 is offline
Old 10-29-2011, 07:05 PM   #1094
dkauffman05
so you have stock axles ? was your truck already 5 lug ?
Old 10-29-2011, 08:36 PM   #1095
lolife99
67-72 parts collector,…
lolife99's Avatar
Usually the center hub of the 6-lug axles needs to be turned down to the 5x5 dimension to allow the 71-72 style brake drum to fit.
Some after market rear disc brake kits require the axle to be turned down even more.
I would match the axle's center hub dimension, to the brake drum or disc brake hat,... which ever you are using.
Keith
Convert to disc brakes.
lolife99 is offline
Old 10-29-2011, 09:53 PM   #1096
dkauffman05
I am using stock drums that have been redrilled. I need to know if the wheel bore is big enough .94.62mm = 3.725" is what i read somewhere but the boss site dosen't list bore. if what i read is true it should work with no lathe work. I just don't want to do it if not needed
Old 01-18-2012, 02:32 PM   #1097
41willys
I'm thinking of replacing my old rims and I like the BOSS 338'S. I've got the 1.25" rotors and planning a 5" static drop front and back. Any thoughts on 18" vs. 20" rims? Wondering if BOSS made any changes to this model wheel in as far as the center caps not having a flush fit due to the rotor hat length?
41willys is offline
Old 01-18-2012, 07:25 PM   #1098
rob32472
I recently bought a set of these and the hub had to be clearanced only a little on the nose for the wheel to slide onto the rotor. I did it with a belt sander while still on the truck. It took all of five minutes per side and I had ZERO issues with the cap. IMHO they are the best bang for your buck when it comes to wheels....
rob32472 is offline
Old 01-18-2012, 07:47 PM   #1099
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Agreed.
Same thing here. But I used a grinder while the rotors were (also) still on the truck. 4-6 ECE stat. drop with shocks,
shock re-locators, etc. 20" X 8.5" up front, 20" x 10" in rear. I used 1" spacers in the rear for bed clearance and to balance up the track a little.
The rear wheels (10's) I have are probably earlier B/S at something like 3.24" or something like that...But I haven't heard anything definitive about
the wheels being deeper after they came out with the bigger inch back-spacing.
I would have liked the rear to have a wider (deeper) rim...But I'm happy.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 01-19-2012, 08:12 PM   #1100
piecesparts
Parts and more parts
piecesparts's Avatar
86 Chevy SWB with 18 X8.5 up front and 20 X 10s in the back. Using a wheel adapter to offset the rear to fit the fenders and a thin 1/4" spacer on the front hub with a longer wheel stud in the hubs. 1.25" brakes with the hub center smoothed for fitment.
Frank
piecesparts is offline
Closed Thread
