Old 02-08-2013, 01:48 PM   #1076
85burb
85burb's Avatar
Re: 85 burb meets 6.0 lq4
Just ordered a new not reworked harness and ECM from psi conversions. Yay!!!
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-08-2013, 08:12 PM   #1077
85burb
85burb's Avatar
Fuel lines and fittings are also on there way! My poor paypal account. It is smoking!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-09-2013, 01:28 AM   #1078
y5mgisi
Second Chance Program
y5mgisi's Avatar
I bet! THats a pile of money!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 02-09-2013, 05:18 AM   #1079
watahyahknow
watahyahknow's Avatar
good way for youre paypall account to loose weight
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 02-09-2013, 11:03 AM   #1080
85burb
85burb's Avatar
That is funny ^^
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-10-2013, 08:55 PM   #1081
85burb
85burb's Avatar
Well I got the intake off the wife's truck and knock sensors and harness off her truck put on today. Just need a few more things to be running!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-11-2013, 12:02 AM   #1082
85burb
85burb's Avatar
Sorry for the sideways pic. But here are more.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-12-2013, 10:34 PM   #1083
85burb
85burb's Avatar
I got my hose and fittings from summit today. I ordered ptfe -6 hose and regular fittings. Long story short i have to send my ptfe hose back. So i put in a order for the correct hose and a 8k ppm speed adapter.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-13-2013, 11:29 PM   #1084
85burb
85burb's Avatar
My psi harness arived today. Looks great. Cant wait to install it. maybe this week end i can start it. My fuel line and intake should be here in the morning. As well as my throttle cable. Cant wait!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-14-2013, 12:11 AM   #1085
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
looks nice!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-14-2013, 12:16 AM   #1086
85burb
85burb's Avatar
Originally Posted by 68GMCCustom View Post
looks nice!
Thanks!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-14-2013, 10:39 PM   #1087
85burb
85burb's Avatar
Got the rest of my stuff in today. I got the correct fuel hose and speedo thing and cold air intake. More like just intake pipe. Does not work of any kinda cold air for me. I will get a better set up later on. Prob a build it your self type where you just order pipes and couplers. But i am happy for what i paid. The filter is really nice and big. Had to move my coolant tank. No big deal. flip it around and it fit like a glove. just had to drill 3 holes in my inner fender.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-15-2013, 08:14 PM   #1088
85burb
85burb's Avatar
Got my throttle cable on. I used a stock 01 silverado throttle cable for the throttle body. Still need the bracket on the intake the cable clips into but it will work for now. Other then sanding down the plastic where it clips into the fire wall it is a strait forward deal. Just need fuel lines and harness installe then it will be ready to run. Should have my throttle valve cable for trans next week.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-17-2013, 07:33 PM   #1089
85burb
85burb's Avatar
So i almost had a great day. I tryed to install my harness i just got. Brand new harness. The o2 sensor plugs are not correct for my o2 sensors. My maf sensor harness is on the wrong side of the motor and too short to connect to maf even if it was on the passenger side. The harness for the maf only goes about 3 inches past the alt. map sensor plug is not correct. Harness connectors are all labled incorrect. I called and pm'ed the seller with no answer. I called and asked him when i bought it if it will plug into all my factory sensors and he said yes. Clearly not the case so far. I am so upset i guess it is a good thing he did not answer.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-17-2013, 08:41 PM   #1090
85burb
85burb's Avatar
psi called me just now and we worked threw most of the complants. I found the map sensor plug. On the maf he is going to send me an extension. On the o2 sensors he told me the ones i have are for a drive by wire ecm. I have the square grey/white ones. I need the flat black connector type. So now i have to get two o2 sensors. Not a big deal i guess. One of the plugs on the o2 i have is broken anyways.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-18-2013, 12:05 AM   #1091
85burb
85burb's Avatar
I did sussesfully install my fuel lines and pump. Ran the lines between the rails and the intake. Looks pretty good to me.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-24-2013, 08:27 PM   #1092
85burb
85burb's Avatar
Two videos of efi running
http://www.youtube.com/watch?v=g78Mp...ature=youtu.be
http://www.youtube.com/watch?v=TkE3a...ature=youtu.be
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-24-2013, 08:33 PM   #1093
85burb
85burb's Avatar
Compleated my efi install under hood today. Got it running. Started up after about 5 seconds of cranking the first start. Only have 2 active codes in ecm. One for check engine light missing and one for crank not learned or something. Came out pretty clean under hood. No wires all over. Cant wait to get my tv cable in the mail and dirve the thing.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-26-2013, 07:55 PM   #1094
y5mgisi
y5mgisi's Avatar
Looks great! Sounds great! Good job!
Old 02-26-2013, 11:40 PM   #1095
85burb
85burb's Avatar
Thanks.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-03-2013, 07:31 PM   #1096
85burb
85burb's Avatar
Efi swap is compleat except the check engine light bulb and the trans cable. Can't wait to drive it.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-03-2013, 07:45 PM   #1097
mooseknuckles
mooseknuckles's Avatar
looks good man....congrats!
mooseknuckles is offline   Reply With Quote
Old 03-03-2013, 07:47 PM   #1098
85burb
85burb's Avatar
Thanks man!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-24-2013, 06:40 PM   #1099
85burb
85burb's Avatar
Woohoo! First test drive went pretty good. Stalls if you blip the throttle at idle sometimes. Other then that it needs a tune done I think for sure. But runs and drives nice. It is taking some adjustment of the new tv cable to get trans shifting correct. Think I have got it now tho. Inside of my trans was nice too.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-25-2013, 03:58 PM   #1100
y5mgisi
y5mgisi's Avatar
Good to hear! Is the ecm a manual trans tune?
