05-29-2015, 03:51 PM | #1076 |
Re: What did you do to your truck today part III
cleaned and did invetory on my burbans storage unit, ugg at least i know what i have and havenot!!!
05-29-2015, 04:00 PM | #1077 |
one less NOS rear brakeline out there!!!
05-29-2015, 04:24 PM | #1078 |
Didn't do anything to it directly, but ordered my Vintage Air AC setup .
05-29-2015, 08:53 PM | #1079 | |
05-29-2015, 10:15 PM | #1080 |
Put the new drivers fender on. Easy job and it fit great! Now on to the new door then wheel opening replacement and metal work is done!
66 shorty |
05-30-2015, 12:14 AM | #1081 |
Post Whore
Tore some more of it apart this evening in prep to pull the cab off tomorrow.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
05-30-2015, 01:07 AM | #1082 | |
see video clip below http://youtu.be/vfTC9wyQKK0
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=611614 |
05-30-2015, 11:57 AM | #1083 |
Went on an awesome pic today, put the smack down on a 64 suburban with 4 sliders. One bit of bad news i got too excited and I killed a flawless PPG original windshield. I was cutting the gasket out and pulling, then I pulled a bit too far without cutting and it put too much stress on the glass. If I didn't get so many awesome parts if jump off a bridge, I still may that glass was like brand new!!!
05-30-2015, 11:58 AM | #1084 |
The carnage!!!!
05-30-2015, 12:02 PM | #1085 |
Only an hr away
05-30-2015, 12:03 PM | #1086 |
Better times, this pic was taken before the glass murder happened!!!
05-30-2015, 12:24 PM | #1087 |
another pic before the death of my dreams of a PPG glass. breaking this glass is gonna haunt me for a very long time!!!
05-30-2015, 01:30 PM | #1088 |
i will use the rip free covers as templates and the foam is in great shape
05-30-2015, 01:33 PM | #1089 |
why yes that is the almost impossible to find middle rubber floor mat, i will graph the other 2 front mats i have to make a new middle one
05-30-2015, 01:40 PM | #1090 |
i also got a dome light with wiring and yes those are the 4 count em 4 slider locks and clam shell arms both top and bottom. i was able to get the back glass without breaking it, 4 section antenna, gas tank door, windshield trim(needs some tweeking thou)... SCORE!!!! ps some parts will find their way to the sale section hint hint!!!
05-30-2015, 04:56 PM | #1091 |
Done a little sanding and priming on the cowl piece and one upper fender corner. Got on the phone and landed a decent 62 grill assembly.
05-30-2015, 09:21 PM | #1092 |
After doing a lot of prep work on my original PS door shell, the PS got a new full door skin today. Let's just say that this was A LOT OF HARD WORK! I envy the guys who can afford a brand new door.I still need to tweek a few areas and skim some body filler in a few places.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
05-30-2015, 09:26 PM | #1093 | |
05-30-2015, 11:50 PM | #1094 |
Turned up the country station & went cruzin with my daughter. Coffee shop, horseback lessons, out to lunch. Just enjoyed my truck today.
Posted via Mobile Device |
05-31-2015, 12:22 PM | #1095 |
Found this little guy at a small flea market. Anybody know anything about it? I couldn't really find any info on it online. Everything I did find was on vw bug sites though.
05-31-2015, 02:04 PM | #1096 |
So far ,primed the cowl piece again. Got the last two exhaust hangers loose. Got the trans linkages loose,speedo cable loose and the rear mounts loose. Got all wiring loose from the starter,choke cable loose. Motor is just sitting now ready to come out. Hopefully got somebody coming to get it tomorrow. Then I can get the cab off and make some real progress.
05-31-2015, 08:55 PM | #1097 |
I quickly removed all paint right down to the bare metal using a HF poly carbide disc on my grinder. I did the front side of this door panel in 20 minutes. I'll use a wire sheel to get the thin flange around the edge and the screw holes. The tailgate was next. I have an original patch piece to repair the bottom right section where the trunion goes.
05-31-2015, 08:58 PM | #1098 | |
05-31-2015, 09:57 PM | #1099 |
I paint some parts getting ready for my ls swap. .. also cleaned intake. .
05-31-2015, 10:04 PM | #1100 |
Moderator
I envy the guys who can weld
