Old 01-31-2012, 03:50 AM   #1101
Jvsapp
Jvsapp's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Originally Posted by Frizzle Fry View Post
Why I felt the need to raise the bar (see right orig vs. left raised)
dang FF! yet again look so clean! BTW do you buy POR15 by the case? i see the box sitting there on the floor!
Jvsapp is offline   Reply With Quote
Old 01-31-2012, 04:46 AM   #1102
Frizzle Fry
Frizzle Fry's Avatar
Hah, no. That's a fuel tank sealer kit
Frizzle Fry is offline   Reply With Quote
Old 01-31-2012, 02:58 PM   #1103
thor
thor's Avatar
Nice work FF! I was curious how you like the Rigid flaring tool? I have one I bought from Sears and it does not grip the tube tight enough for flaring. When I turn the handle to plunge the flaring tip, the tube gets pushed out.
And if ya find it, a pic from the inside of the car of the adjustable proportioning valve would be cool.
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 01-31-2012, 04:07 PM   #1104
Frizzle Fry
You're right, on the 3/16 tube I have to tighten it down ultra f'n tight using a cheater handle! Seems like it may be due to the fact that the 3/16 slot is the only one that's smooth/no ridges. I was considering removing a tiny bit of material from the inside surface of the jaws. But so far it's working with the cheater bar. Just hope I don't break it... I'll take another pic of the prop valve tonight.
Old 01-31-2012, 05:08 PM   #1105
watahyahknow
watahyahknow's Avatar
when you remove some material you dont have to tighten it so mush , i think its the better solution it keeps the device intact and doesnt ruin the tread over time
it prolly be hardened material though
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 02-01-2012, 05:15 AM   #1106
Frizzle Fry
I took a little off the inside surface of one of the jaws on the disc sander. Might be a little better. I'll do the other side next (we're talkin thou's at a time).
And now this-
Prop valve location:
The diff brake line plan hit a snag... I put the rear back in place to locate the hard-line/flex line bracket and found some clearance issues. So I ran them in a more conventional route. Still made sure they stay below the top of the pumpkin since it will be coming close to the trunk floor under compression.
Here's a shot of the rear-end in place:
Flex line bracket locating:
New hard-line set up on rear.
A little trick for locating a bend:
These have American on one end and Metric on the other
Other side:
Old 02-01-2012, 09:29 AM   #1107
spudz
spudz's Avatar
This same kit is a essential tool that was sent to our dealership. Its the best flaring tool I have ever used, its expensive but worth it in my opinion... You can find it cheaper but it has less stuff in the kit usually. just search ebay for hyraulic flaring tool and you can get the same kit for way less. I even seen a kit that just does the brake lines and it was only $60 http://www.classictube.com/shop-onli...tegory_id=1866
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 02-01-2012, 01:19 PM   #1108
dammitmitchell
the pollock
dammitmitchell's Avatar
i hate you so much right now... in a envious little brother sorta way.
every damn time i bend brake lines it looks like a two year old drew the layout in crayons..
i can never ever ever ever find a good bender when im doing lines.. and im allllllwwwwaaaayyyysss tweaking..
im jealous.. i no like you right now because it's so pretttttyy
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 02-01-2012, 03:14 PM   #1109
thor
thor's Avatar
I'll give this a try. Thanks for the tip!
Old 02-01-2012, 03:22 PM   #1110
VA72C10
VA72C10
VA72C10's Avatar
looking good!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-01-2012, 03:33 PM   #1111
65Pickup
65Pickup's Avatar
Thumbs up Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Great tips and illustrations as usual.
65Pickup is offline   Reply With Quote
Old 02-01-2012, 05:00 PM   #1112
watahyahknow
i heared people using belt pulleys of different sizes to bend brakeline in the right radius
Old 02-01-2012, 09:50 PM   #1113
Frizzle Fry
If it makes you feel better, I tried bending up some 5/16" fuel line today and it wanted to kink every time. I had to do iterations and it still doesn't look great. I might just run this the whole way...
NP
Originally Posted by VA72C10 View Post
looking good!!!
Nice, I'll have to try that on the fuel line!
Old 02-02-2012, 11:33 AM   #1114
OLDIRON69
The Aeroquip stuff is nice, they make some of the best hydraulic hoses in the industry. They even sell some that are non-crimp fittings which makes it nice. I will check my catalog to see if they show fuel line like this, if so I can buy it cheaper..
Not in my catalog but the dealer says he can order it, let me know if you want to go with it and I will get pricing for you.
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 02-02-2012, 04:44 PM   #1115
Mil-Spec
Mil-Spec's Avatar
As always FF, that's some major talent.
SEMPER FORTIS
U.S. NAVY 97-05
USAF 94-97
Mil-Spec is offline   Reply With Quote
Old 02-02-2012, 07:25 PM   #1116
Frizzle Fry
Wow, thanks for the offer! I'll pm you if I do go that route.
Thanks, but I have to admit those lines are so easy to bend they make me look good
Old 02-03-2012, 01:13 PM   #1117
Jvsapp
Jvsapp's Avatar
ok let's see....road test checklist....
engine............... check
trans................. check
wheels............... check
suspension.......... check
brakes................ check
interior................ Milk crate!
so when should i book my ticket?
glad to see it's coming along.
Old 02-03-2012, 02:07 PM   #1118
dammitmitchell
the pollock
I did the milk rate a few months ago in the maro frizzle.. stepped on the gas and the motor had a little more kick then i was epecting in the car.. it put me on my ass behind the milk crate was very humorous..
make sure the ebrake works..
Army vet 02-08
Old 02-03-2012, 04:02 PM   #1119
Frizzle Fry
Seats and interior.............. check
Shootin for spring!!!
ebrake............... check
Old 02-03-2012, 04:39 PM   #1120
watahyahknow
makes me think of my yougth i was putting togethr a motorcycle and hadnt bolted down the buddyseat when i whent out to try to drive it .
the motor was going down the road a few feet before falling over i was left behind with the seat between my legs
Old 02-06-2012, 10:03 PM   #1121
Frizzle Fry
Had an "oh crap" moment looking at the pics. This one:
In particular the relationship of the prop valve to the trans x-member bolt holes ...yeh
Solution:
...I'll pay for my mistake in the form of having to re-powdercoat it now
On to the fuel lines. I had attempted to re-use the S2000 lines with no luck. On one of my bazillion trips to NAPA this week I checked out their Poly Armor line selection to see if they had 5/16" for the fuel supply and 1/4 for the return: Yep! Picked up 2ea 60" sticks and some fittings. Here's that:
Old 02-06-2012, 10:15 PM   #1122
VA72C10
VA72C10
VA72C10's Avatar
nice work as usual!
Old 02-06-2012, 11:55 PM   #1123
67cheby
67cheby
67cheby's Avatar
looks FACTORY !
67cheby is offline   Reply With Quote
Old 02-07-2012, 09:07 AM   #1124
OLDIRON69
Originally Posted by 67cheby View Post
looks factory !
x2
05 2500HD 6.0 excab
Old 02-07-2012, 02:15 PM   #1125
dhaymaker
dhaymaker's Avatar
x2
x3 - And, maybe better than factory!
don
"The DRBMan"
2014 Audi A4 (The Wife's Daily Driver)
2017 HD Ultra (The Cruiser)
2003 HD Fatboy (The Ride)
2001 Chevy Suburban (Another back up!!)
For the first time in forever, not a single 67-72 Chevy truck, Blazer, or Suburban on the property! Basically retired and getting the new Motorhome ready for some traveling. Doing a bit of work on the house getting it ready to sell! LOL!!
dhaymaker is offline   Reply With Quote
