Old 09-24-2012, 10:24 AM   #1126
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Finally starting my Longhorn 4x4 conversion
Originally Posted by Dieselwrencher View Post
No pics, but I did manage to get the new to me weather stripping on the cab. If anyone wants an upgrade from the glue on factory crap, use door seals from a 87-96 (before they changed the body style) Dodge Dakota. You will need to cut off about 3" or so, but the stuff holds it self on because it has a metal clamp inside it. You go to a junk yard and find 2 good used seals, clean them up, re crimp the channel and install on to your cab. Works so much nicer than taping and gluing the factory stuff!
Good to know for us cheap, broke folks!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 09-24-2012, 11:47 AM   #1127
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
They're doing good Nate! Nope, he was born April 11th this year. He's doing pretty good. How about your family?
Hey cool, that's my birthday!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 09-24-2012, 12:01 PM   #1128
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Yep. I got 3 door seals from a u pull it yard for $16.85.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 09-24-2012, 12:02 PM   #1129
Dieselwrencher
Well cool deal and Happy Late Birthday!
Ryan
Old 09-24-2012, 02:15 PM   #1130
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Wow.... time is getting away from me.
We've been doing good if we can get of this crud we've had for two weeks now. Have to meet up with you in 2013 and see the expanding family.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-24-2012, 11:52 PM   #1131
mosesburb
I had a V-8
mosesburb's Avatar
I did this and went back to the glue on stuff. I laid mine out so the seam ended up at the bottom of the door opening. That put some of the areas that the Dakota door "squished" in areas on my doors that didn't "squish" as much leaving small gaps that flowed air at high speed, but more importantly water--even when sitting still. Not saying yours will, but it is something to check out so you don't end up with wet shorts on a rainy day. Your weatherstrip may be better than what we get out here because it hasn't been on the surface of the sun its whole life.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 09-25-2012, 12:05 AM   #1132
ryanroo
ryanroo's Avatar
ain't that the truth. you guys have it even worse, and im not sure how thats possible!
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 09-25-2012, 12:50 AM   #1133
72-c20
Packrat
72-c20's Avatar
one thing to bear in mind with using the Dodge weather strip, is that you actually switch sides. dodge drivers side to Chevy pass side...
Chevy has rounded door rear corner and sharp point at A pillar. Dodge is opposite.
I've done this on mine with good luck... after 4 years, the JY weatherstrip finally started getting some bad spots so I got another...
gone: --'07 Tahoe LTZ 4WD
--'68 Firebird 400 Convertible
gone: --'72 Chevy K20
72-c20 is offline   Reply With Quote
Old 09-25-2012, 12:54 AM   #1134
SS Tim
SS Tim's Avatar
The only advantage (other than cost) of used w strips is the fact that they have shrunk. If you do buy new strips make sure you put them in long. By this I mean really compress it in along the bottom lengthwise to make up for the inch or so that is going to shrink out. The advantage with the self retaining strip is it can be repositioned to make up for radius bridging by shrinkage over time if you allow for it.
SS Tim is offline   Reply With Quote
Old 09-25-2012, 02:29 PM   #1135
fakerwade
fakerwade's Avatar
Brilliant!!!
Wade
JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!!
Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570
Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro
fakerwade is offline   Reply With Quote
Old 09-25-2012, 07:00 PM   #1136
Dieselwrencher
Huh, I used the same side from the Dakota to the Chevy with no issue. I'll have to take pics and post it up.
Ryan
Old 09-26-2012, 02:53 AM   #1137
Dieselwrencher
Here is the weather stripping.
Ventshade
Gauge Pod fitment
Ryan
Old 09-26-2012, 09:25 AM   #1138
72-c20
Packrat
72-c20's Avatar
it will work for whichever side fine, but it seemed to lay better if you could match up the sharp corners...
Old 09-26-2012, 02:14 PM   #1139
woodwright
Enjoying left field
woodwright's Avatar
Rockauto has new Dakota weather stripping for $19 per side.
They've also got the 67-72 chev ones for $34 for both.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 09-26-2012, 05:57 PM   #1140
Dieselwrencher
Here is a little progress on the truck box. 90% of the bolts are in the bed and I got the gap at the tail gate opening pretty decent. The floor patch doesn't match the bed floor, so it is really interesting to get the pieces lined up and welded. It isn't going to be perfect, but it will be a 8' 6" steel floor.
Ryan
Old 09-26-2012, 08:40 PM   #1141
ryanroo
ryanroo's Avatar
that looks fun!
72 K20 12v build
Old 09-26-2012, 10:29 PM   #1142
jbclassix
Junk Yartist
jbclassix's Avatar
Hey Ryan,
What spline input is your 205?
-Jeremy
Rebuilding an NP205
Old 09-26-2012, 11:01 PM   #1143
Dieselwrencher
Originally Posted by ryanroo View Post
that looks fun!
You know it!
Hey Ryan,
Dodge Diesel NV4500 4x4 and Getrag G360 4x4 output shafts are 29 spline. The manual NP205 used in the first gens are 29 spline. I'm using a NP241DHD which is 29 spline as well.
Ryan
Old 09-27-2012, 12:50 AM   #1144
woodwright
Enjoying left field
woodwright's Avatar
Didn't mean to sound like a Rockauto salesman. Sorry
Clint
Old 09-27-2012, 10:01 AM   #1145
Dieselwrencher
That's quite alright. Thanks for the heads up. If I like the dakota seals I'll purchase new ones. I have 2 sets of the chevy style right now. I really didn't want to mess with glueing it on and wanted to give the dakota seals a shot.
Ryan
Old 10-04-2012, 05:08 PM   #1146
Rabrantes2011
What turbos are you running on your truck? Your twin setup looks really similar to the ATS Aurura Twin Turbo Kit, is that where you got the idea?
Rabrantes2011 is offline   Reply With Quote
Old 10-10-2012, 09:06 PM   #1147
Midgets50
Midgets50's Avatar
hi all,
Ryan, i heard you were the diesel guy of this forum and ive seen all the impressive work you've done on this build. ive got a question but i might not have all the needed details. ive got a k2500 79 GMC and i want to put a diesel in it. swapping out the motor and tranny but still keeping it 4x4 would i be able to use my current chevy axles or would i have to swap them out also?
Midgets50 is offline   Reply With Quote
Old 10-10-2012, 09:34 PM   #1148
ryanroo
ryanroo's Avatar
you could keep them, and depending on what you are doing with the truck the front d44 may be ok. with a similar sized I6 diesel in a 73 K20 my dad has wiped the front R&P in his at least twice. with all the added weight it will wear out the ball joints sooner as well. i would try to find a dana 60 for the front if i was you.
72 K20 12v build
Old 10-10-2012, 09:43 PM   #1149
Midgets50
Midgets50's Avatar
ok thanks for the advice ill have to see what i can find on that
Old 10-12-2012, 02:26 PM   #1150
Dieselwrencher
That pretty much sums it up. You can run a big hub D44, but eventually you will want to upgrade to a D60. What trans do you plan on running? Auto or manual?
Ryan
