06-17-2018, 07:37 PM | #1126 |
Re: What did you do with your truck today, Part 3
Finished the battery mount. Side post to the rear. Cables run down the back and down the firewall.
06-17-2018, 07:42 PM | #1127 | |
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
06-17-2018, 07:47 PM | #1128 |
06-17-2018, 07:51 PM | #1129 | |
Brian
06-17-2018, 07:52 PM | #1130 |
06-17-2018, 11:24 PM | #1131 |
drove the death rattle all day. I fall more in love every time I drive it. I didn't get any work on the truck done. I did clean out the garage which will lead to better work later on. well I guess I did a tiny bit of work if you count prep/research. I took the new a/c bracket out and held it in place and went over the directions while looking at the motor. I already knew I was going to have to move the fuel line over a couple of inches but I will also have to cut the alternator bracket spacer to allow the a/c compressor bracket AND the alternator bracket occupy the same mounting hole the on the head. that means im going to have to get a bolt that matches all of the a/c compressor bracket bolts for the alternator. I believe I found a winner though. its supposed to rain all week here so maybe I will get some work done during the week.
06-18-2018, 02:28 AM | #1132 |
I went to an antique swap meet and even though it was a non-automotive event I miraculously found a set of inside door and window handles for my AD, and a pair of tail lights.
1951 Chevy Panel Truck Last edited by MiraclePieCo; 06-18-2018 at 02:39 AM. |
06-18-2018, 10:09 AM | #1133 | |
Brian
06-18-2018, 11:45 PM | #1134 |
Tested all my gauges for proper operation, installed a rheostat behind the dash for final brightness configurations.
06-18-2018, 11:46 PM | #1135 |
okay.. I got out to start on my compressor bracket. I didn't get as far as wanted. mistakes were made along with messes. I had to lay my alternator to the side. easy. then I started following the installation instructions. the first step is to grind a small area. did it. install the cradle on the top water pump bolt. done. remove 1st manifold bolt. done. here is where it gets messy. I needed to remove the heater hoses from the manifold and water pump just to have some room to move. coolant everywhere. its a disaster in my garage. got that handled. the bracket sits just about right but I have some more work to do. I need to make 2 spacers and make sure my belt lines up. the good news is that the bracket will work on top of my alternator bracket. im stoked about that.
06-19-2018, 12:39 AM | #1136 |
I was BEAT today at work, fell asleep in the lunch room! And I love my five minute a day plan, that's all I was going to do, clamp the seat riser in to place, that was it. Well, I got it all welded and ground and the front brackets welded in, it's done!
I then went out for a 2+ mile walk! Brian
06-19-2018, 04:57 AM | #1137 |
Raised my truck on jackstands and had my wife step on the brake pedal while I spun the wheels. My brakes are now fully functional!
Between the faulty proportioning valve, adapting GM hoses to Ford calipers, and the inevitable leaks, what an ordeal these brakes have been!
1951 Chevy Panel Truck Last edited by MiraclePieCo; 06-19-2018 at 05:42 AM. |
06-19-2018, 12:50 PM | #1138 |
First drive after the new paint.
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
06-19-2018, 12:59 PM | #1139 |
06-19-2018, 01:13 PM | #1140 |
So cool!
I remember reading an article in the old "Rod Action" magazine back in the seventies about taking that first drive and how all the busted knuckles are forgotten. I wish I had a copy of it, it was really well done. Brian
06-19-2018, 01:22 PM | #1141 |
It was said that if you cut off one hydra head, two more grow back. -Lernaean Hydra Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=743246 |
06-19-2018, 01:51 PM | #1142 | |
Also my first ride in this truck was as a newborn, my parents brought me home from the hospital in it back in '78. It did feel pretty good taking it out on Father's day.
06-19-2018, 01:56 PM | #1143 |
Thanks, I'll be in your neighborhood this weekend. There's a vintage trailer rally up at Riverbend Campground. The whole campground will be full of vintage trailers and there's an open house on Saturday if you're interested.
I'll have my truck and camper there.
06-19-2018, 02:10 PM | #1144 | |
Brian
06-19-2018, 11:21 PM | #1145 |
jweb, cool truck and great story...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
06-20-2018, 01:38 AM | #1146 |
I had a meeting for work 50 miles away that was 3 hours of mind numbing crap, got home after 10 pm and got out to the garage for my five minutes! I punched and drilled holes in the cab and in the panels I am welding in at the cowl at the bottom of the hinge pillars. WHOOO HOOOO!
Brian
06-20-2018, 09:56 AM | #1147 |
Looking very nice, great color and story.
1950 3100 5 window |
06-20-2018, 09:11 PM | #1148 |
Started my wiring tonight, guess this counts as my 5 minutes.
06-20-2018, 09:22 PM | #1149 |
My 5 minutes was to go pay for the PPG paint, over $1000/with tax for a gallon of paint and nothing else.... and I need 1 1/2 gallons minimum!
06-20-2018, 10:08 PM | #1150 |
You work pretty fast!
