#1151 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
Do it yourself with a grinder.
#1152 |
These are pics from this thread.
Before and after,...
#1153 |
Here's a set of rotors that were machined for a set of 18's,...
#1154 |
boy, that pic sure looks familiar. yes, im thinking I had them done for $25
#1155 | |
I Googled "machining rotors for Boss 338 wheels",... and yours came up. Much faster than looking at every page of this thread.
#1156 |
I'm with mrhino. When you see a set of these on a truck, you know the guy is resourceful.
And brossow is right about the hub of the wheel being thick. My 20x10 rears are so thick the lug nuts are down inside the wheel. (post 1131 on page 46 shows this) |
#1157 | |
Amateur Rust Fighter
Brent '72 Chevy SWB stepside - [ Build Thread ] '79 ChevMC SWB fleetside - [ Build Thread ] '64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...) |
#1158 |
#1160 |
OK, with the help from this thread, I got the front wheels on today. A little machining on the rotors and the fronts went on - no problem with the grease caps on the rotors. The rears went on with no spacers. 18x8 with 255/55/18 fronts and 20x10 295/45/20 rears. Might have been able to get a 305 or 315 on the rear but might have needed to mini tub it.
I'm gonna try to post before and after pics that show the effort was worth it. |
#1161 |
P.S. I did not put the goofy chrome wheels on...they were on it when I picked it up a few weeks ago and I'm currently in the process of brnging te truck up to standards.
#1162 |
WOW!
A hundred times better. Very nice truck!
#1163 | |
#1164 |
VA72C10
![]() Join Date: Mar 2008
Nice work on the truck! Major transformation with not only the wheels but also the rear! Love the change on the gate/bumper/trim!!!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#1165 |
very nice! Worth the effort
#1166 |
Need some help. A real nube to the forum and I've read this thread from the beginning.
I have a 72 Short Step that I would like to put these wheels on. Although I like the 20" look, I think I want to keep 18's all the way around. So, is this the spec I need for this truck? Currently the truck has not been dropped and not sure if I will drop it. Front: 18 x 8" Offset: +2mm, Backspace: 4.5" AEWC part# 3382-9850-3AA Rear: 18 x 9.5" Offset: -5mm, Backspace: 5" AEWC part# 3382-9950-3A Looking to feel the wheel wells up a bit and I'm considering 255/18/55 tires all the way around. Does this look right? Thanks,
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
#1167 |
The front combo will be exactly the same as what I used and my truck has about 3.5" drop in front and they fill the wheelwells. I would go with a little bigger tire in the rear. As for the backspacing, I don't think you can choose - they only have 4.5 on the 18x8 and 5 on the 18x9.5
Be ready to machine your rotors if you have disc brakes as was discussed here. |
#1168 |
Thanks BB454,
What tires did you end up using? Looking at Nitto NT55 in Rear 265/50/18 Height 28.43 Width 10.83 Front 255/45/18 26.97 10.16
#1169 | |
You can go to this site and compare different tire widths as well as diameters and sidewall height: http://www.discounttire.com/dtcs/infoTireMath.dos |
#1170 | |
yep! thats the exact combo I used on my truck. 245/45 up front 255/55 in the rear ![]() ![]() |
#1171 |
Nice truck Mike,
What brand of tires are you using?
#1172 |
Thank you.
I was running Federal Tyres. I didnt put a lot of miles on them before selling the truck, but I was very pleased with the tires. They handled great, no road noise and they did very well in the wet. Plus they have a bad ass tread pattern as u can see in the photos. I would certainly buy them again when the time comes again |
#1173 |
Has anyone ordered 20x8.5" Boss 338 wheels in the last few months?
Just wondering if the current part numbers have the 3AA designator, at the end of the part number? Or if there is a new part number for the "current revision" of these wheels?
#1174 |
I'll look when I get to the shop. I ordered some for my brothers 65 GMC about 3 months ago.
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
#1175 |
'85 Stepside
![]() Join Date: Jan 2006
ordered two this morning....... then we compare!
