Old 01-01-2007, 06:43 PM   #101
1969k10stepside
Re: Its the shortbed's turn "Project Junkyard Resurrection"
Yeah,primered,painted,and will clear coat it when I get the lift done.Cant wait to see pics of your truck frame,it might look better than mines as mine was very rusty.
1969k10stepside is offline   Reply With Quote
Old 01-01-2007, 08:16 PM   #102
msgross
msgross's Avatar
I hope it wasn't rustier than mine!
msgross is offline   Reply With Quote
Old 01-01-2007, 09:53 PM   #103
1969C/10
Unskilled Labor
1969C/10's Avatar
Looks great Dustin! Lots of progress since I talked to you last! Have you made any progress on the motor yet?
1986 K/20, 350/TH400, My First 4x4.......
1969C/10 is offline   Reply With Quote
Old 01-01-2007, 10:35 PM   #104
arkracing
Weekend Warrior
looks good.
were you ever able to notice if that tab was welded onto the shift rail?
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 01-01-2007, 10:45 PM   #105
1969k10stepside
1969C/10,No motor work yet,supposed to get a whole different motor but I dont have it yet.Have alot of parts waiting for it though.
Arkracing,I didnt even look at the t case today.Spent the day cleaning up a major tranny leak mess spanning about 15x20 feet of the shop floor.I will look tomorrow and see if it is.
Msgross,scroll back to the first or second page to see pics of the frame before I blasted it,it was pretty bad.
Old 01-01-2007, 10:55 PM   #106
msgross
msgross's Avatar
true, it was pretty rusty... Mine had been undercoated back in the day so I get to fight with that...What product did you say you blasted with? I have heard that basic play sand from Lowes is a cheap route to go, I plan on doing it outside like you did and not recovering any media...
Mike
Old 01-01-2007, 11:06 PM   #107
1969k10stepside
I dont remember what kind it was.I have had it a few years sitting in the back of the shop.I think I threw the bag away when I put the sand in buckets because the bag ripped and was spilling it out.I will look and see if I still have a bag left.
Old 01-02-2007, 06:27 PM   #108
1969k10stepside
Ok,arkracing...Nothing was welded on the shift rails on my np205.Everything was riveted together by the looks of it
OK...I managed to get the rear axle out and painted.The u bolts were stubborn so I decided to cut them off and managed to burn myself thanks to some slagI then cleaned and painted the rear axle.It is drying now and as soon as I get whats left of the rear springs off the new ones can go on it.
When I removed the rear axle the passenger side springs came in 2!I did know they needed replacing but the set of springs splitting in two is bad.
Will not have anymore pics except the crappy ones I take in the shop till this weekend most likely because my time off has came to an end.Will still get work done on this though
Old 01-04-2007, 07:31 PM   #109
1969k10stepside
Looked and inspected my axles to find new gears in the rear and 3 broken teeth on the frontI guess I will be out lookin for a truck to bring home w/ good gears(save the truck for fun later) or buy a new set.I am not gonna worry much about it now.Just something to adress before Im done.Will probably change it while its getting painted.
Old 01-04-2007, 08:19 PM   #110
msgross
msgross's Avatar
what gears are you looking for?
Old 01-04-2007, 08:59 PM   #111
1969k10stepside
3:73s
Old 01-05-2007, 10:54 PM   #112
1969k10stepside
Took the 2 trannys to be rebuilt and made be made into one good one today.Should have it done and back next week.Tomorrow I will have some pics of the motor(hopefully)
Old 01-07-2007, 01:00 AM   #113
krue
Designated A-hole!
krue's Avatar
That sucks.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 01-07-2007, 01:17 AM   #114
1969k10stepside
Ok,well....I took some pics of the lift kit.Last ones you will see of it as its coming back off to hopefully be replaced with the right ones.Didnt get the motor today but will tomorrow.Atleast that will be a good thing for the weekend truck wise
towhooks will be going here:
Name:  lift kit-done.jpg
Pic shows tire to frame,big lift kit for sure
Old 01-07-2007, 02:01 AM   #115
krue
Designated A-hole!
krue's Avatar
Maybe you just need a little weight on it.
www.daveramsey.com
Old 01-07-2007, 11:23 PM   #116
1969k10stepside
Look at them new gears in the rear.Still havent looked to see the ratio.Pushed it outside to take a few pics showing its lift kit.I am calling the company to tell them about it tomorrow.One way or another Im getting the right lift kit
Name:  truck frame.jpg
Old 01-07-2007, 11:41 PM   #117
msgross
msgross's Avatar
what are the numbers on the ring gear?
Here's your secret decoder ring!
Ratio 2.56:1 - Tooth Combination 41,16
Ratio 2.73:1 - Tooth Combination 41,15
Ratio 3.07:1 - Tooth Combination 43,14
Ratio 3.08:1 - Tooth Combination 40,13
Ratio 3.08:1 - Tooth Combination 37,12
Ratio 3.31:1 - Tooth Combination 43,13
Ratio 3.36:1 - Tooth Combination 37,11
Ratio 3.42:1 - Tooth Combination 41,12
Ratio 3.55:1 - Tooth Combination 39,11
Ratio 3.73:1 - Tooth Combination 41,11
Ratio 4.10:1 - Tooth Combination 41,10
Ratio 4.11:1 - Tooth Combination 37,9
Old 01-08-2007, 09:05 PM   #118
1969k10stepside
.....I must be bored.I didnt like the quality of my painting on the rear axle so I pulled it out and repainted it.Its drying now...
Old 01-09-2007, 06:29 PM   #119
1969k10stepside
Well,I looked and found out it has 3:73s in it.Thats a good ratio for this truck since it will be a DD but still turn 35's
Old 01-09-2007, 07:44 PM   #120
msgross
msgross's Avatar
I have 3.73's in mine too. Now I need to swap the gears over to the newer dana 44 with discs though...have you done that before?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
Old 01-11-2007, 12:10 AM   #121
1969k10stepside
I pulled the rotors and all the related stuff off the front axle of the swb 4x4 to find the axle had been rebuilt and had new brakes.Still needs a new ring gear though.Looks good other then the gear.I have a few wheel studs to replace though.The lift kit turned out to supposively be the right one.They said it will go down alot with the body on it so Im gonna put the bed on and maybe the cab this weekend and see what happens.Should have the rebuilt tranny back by Saturday too.
Old 01-11-2007, 10:38 PM   #122
1969k10stepside
Well,got some parts today.I got both diff cover gaskets,u joints for the axles,a few wheel studs,seals for the axle/hub, new drag link,and tire rod covers.Gonna clean the axle tomorrow and get it mostly reassembled.I am gettting ready to buy new WARN lockouts for it too.
Old 01-13-2007, 01:03 AM   #123
1969k10stepside
Lockouts will be in sometime next week...Spent the evening tearing the front axle all apart.Its a bare axle housing now.I cleaned all the internals and threw away the old 3:73s in the front.The ball joints are bad in the knuckles so they will have to be replaced on one side.Waiting on a few seals,lockouts and the new ring gear and the axle will be done.Hoping to test fit the body on frame this weekend to let the spings settle in abit.Stay tuned!
Old 01-13-2007, 01:30 AM   #124
skchevota
skchevota's Avatar
Just makeing sure, you know you have to replace the ring and pinion as a set right....
skchevota is offline   Reply With Quote
Old 01-13-2007, 01:35 AM   #125
1969k10stepside
Yeah,Im buying both together.Just didnt feel like typing all that out
