Old 04-05-2014, 07:40 PM   #101
tbrown5079
Re: 56 Cameo build
Fired it up the other night. It sputtered and stalled twice but then smoothed out and runs. No leaks, but the bad news is no throttle. I've searched for loose wires and bent pins but no luck yet. Hooked up the OBD2 port and check engine light. No codes and the light goes out after it starts. You can rev it up manually but just runs at fast idle on its own. Not recognizing a component somewhere or I'm missing a ground.
Cut, bent and installed the last piece of brakeline so if I had the throttle figured out I could drive it around the block.
tbrown's 56 Cameo Build
tbrown5079 is offline   Reply With Quote
Old 04-05-2014, 10:49 PM   #102
Spblack
Spblack's Avatar
Re: 56 Cameo build
sounds like the pedal.
1959 Chevy Apache (sold)
1958 Fleetside Current
My builds:
http://67-72chevytrucks.com/vboard/s...d.php?t=606412
http://67-72chevytrucks.com/vboard/s...=1#post7560906
Spblack is offline   Reply With Quote
Old 05-23-2014, 10:56 PM   #103
tbrown5079
Re: 56 Cameo build
Some pictures I promised of the mirror install.
Old 06-24-2014, 08:58 AM   #104
tbrown5079
Re: 56 Cameo build
Started on a new project. One of the other builders cut a fiberglass cap for a 59 fleetside bed so I figured it was worth a try. I found one on craigslist and got it for $300 so I won't be out a fortune if it doesn't work. I needed something to finish off the top of the bedsides anyway.
My goal is to get it as low as possible so I can take out the blocks you see in the pictures.
Old 06-24-2014, 09:24 AM   #105
Baldeagle SR
Re: 56 Cameo build
Good idea. looks like it will work.
Rich
my build http://67-72chevytrucks.com/vboard/s...d.php?t=576185
Baldeagle SR is offline   Reply With Quote
Old 06-24-2014, 10:09 AM   #106
Kim57
Kim57's Avatar
Re: 56 Cameo build
That should look pretty good on there.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 06-24-2014, 11:08 AM   #107
tbrown5079
Re: 56 Cameo build
It is heavier than I thought it would be. Should help the ride.
Old 06-25-2014, 08:37 AM   #108
tbrown5079
Re: 56 Cameo build
Got it down a little lower last night by trimming the front side edges. Should be about right.
A friend scored on a set of hinges that will move the front edge back when you lift the top. Should help with front edge to cab issues.
Old 06-25-2014, 09:18 AM   #109
dubie
dubie's Avatar
Re: 56 Cameo build
I can in all honesty that the cameo has never really appealed to me. But yours gas really caught my attention
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 06-25-2014, 09:56 AM   #110
Kim57
Kim57's Avatar
Re: 56 Cameo build
That should look real nice when done.
Kim
My build thread
Old 06-25-2014, 10:27 AM   #111
ricott
Re: 56 Cameo build
Love your build. Thanks for the pictures on the Porsche side mirror install - that sure looks slick. I plan to steal this idea when I get to that part of mine - but maybe using the teardrop style 968 mirrors.
Ricky
ricott is offline   Reply With Quote
Old 07-08-2014, 08:29 PM   #112
tbrown5079
Re: 56 Cameo build
I didn't have a good cameo endgate but had a rusted out one with decent latches in ( they worked anyway ) so I cut out the latches, welded them into a regular endgate, then we glued a piece of aluminum on the inside to cover the chevrolet stamping. I have the endgate cover that I bought new and will put it on tomorrow night when the primer is dry. I need to have it done to see how I am going to do the back of the cap.
Old 08-14-2014, 09:20 AM   #113
tbrown5079
Re: 56 Cameo build
Moving forward on the cap. Scribed and cut it to match the back of the cab, reinforced under the hinges, cut front pieces to finish the front, put in a 4" piece of plywood the length of the cap and screwed in place before we finish the center seam.
Old 10-15-2014, 10:44 AM   #114
tbrown5079
Re: 56 Cameo build
Picked the truck up from the paintshop last week. He was to take it in April, but just got it into his schedule last month. It was worth the wait! I had welded all the seams on the inside so he filled all of them and did a super job on the interior and jams. The door fit is awesome. Now to put everything together for the final time without too many marks. It's very intimidating! I want to insulate the firewall, put in the wiring harness, then solve all the issues with gauges, charging, etc. before we set the front on. Sorry, I posted this before but wanted it on my buildsite.
Old 10-15-2014, 11:27 AM   #115
Kim57
Kim57's Avatar
Re: 56 Cameo build
Looks really sharp.
Kim
My build thread
Old 10-15-2014, 05:59 PM   #116
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: 56 Cameo build
Nice!
ChuckDriver is offline   Reply With Quote
Old 10-30-2014, 08:22 PM   #117
tbrown5079
Re: 56 Cameo build
Got the firewall insulation glued in. This time I used Weldwood contact cement and brushed it on. Personally I liked it better than the spray on. I have a heavy rubber mat with insulation glued to it to go over the silver insulation on the firewall. Then I can start wiring .
Old 10-30-2014, 09:44 PM   #118
Kim57
Kim57's Avatar
Re: 56 Cameo build
Looks real nice.
Kim
My build thread
Old 10-30-2014, 11:29 PM   #119
oldman3
oldman3's Avatar
Re: 56 Cameo build
Nice job...Jim
oldman3 is offline   Reply With Quote
Old 10-31-2014, 06:26 PM   #120
ChuckDriver
Re: 56 Cameo build
Nice install!
Old 11-18-2014, 12:16 AM   #121
Spaztikjohns
Re: 56 Cameo build
A few months ago I ran across this build. Just about a hour ago I found some seats very similar, 3rd row out of a Denali for $100. I am building a 59 Chevy fleetside with airbags.
Any Chance you could post more about the seat sliders you built?
Joe
Spaztikjohns is offline   Reply With Quote
Old 11-18-2014, 06:42 PM   #122
tbrown5079
Re: 56 Cameo build
Well Spaztikjohns, not too difficult. I got the seat adjusters at a swap meet so I don't have any info on them. When I got the plates cut and sized for the seats, I turned the seats upside down and made slots big enough so the latches fit in with no clearance issues. Then I put 1/2" bolts in the latches like they would be when locked. Then I marked their positions and welded them to the plate. That way you can take the seats out anytime you need to. I also sloped the angle iron we welded to the ribs in the cab so it would bring the seats up for a shorter person. Not perfect but I think it will be fine for what I wanted. Hard to find a seat that doesn't go up into the back window and has the seat belt and shoulder harness built in. Hope this helps.
tbrown
Old 11-19-2014, 03:06 PM   #123
Lokin4AReason
Lokin4AReason's Avatar
Re: 56 Cameo build
looking good =0)
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 11-29-2014, 09:12 PM   #124
tbrown5079
Re: 56 Cameo build
Started to put the wiring harness back in, but got frustrated after a while and decided to do the mirrors. All of the research paid off, I really like them!
Had Wait-For -Me Performance do my harness a couple of years ago and after countless hours and a few phone calls we realized they sent me the wrong wiring diagram. Then they told me they were done and wouldn't send me the right diagram. Told me to just get one for that vehicle on my own. I'm going to get on the LSX site for some guidance.
Old 11-30-2014, 01:47 AM   #125
Kim57
Kim57's Avatar
Re: 56 Cameo build
The mirror looks real nice.
Kim
My build thread
