Old 05-11-2010, 05:21 PM   #101
bjcaldwe
bjcaldwe's Avatar
Re: '50 5 window.....s10 swap
The column does look great. Nice work. More good ideas to soak up for when I get to that point.
My AD Truck Build Thread
52 GMC one day laying on the running boards
2004 Chevy Crewcab. 3/5 and notched
bjcaldwe is offline   Reply With Quote
Old 05-23-2010, 08:39 PM   #102
rhodog77
rhodog77's Avatar
Finally got the pedals mocked up. I need to get another s10 brake pedal assembly/bracket. I cut the other one down way to far. I was thinking about welding in a piece up to the dash to help support it but I called my local junkyard to see what the would charge me to pull another one.....5 bucks, so I think I will be getting another one. Still have to run the linkage to the gas pedal but everything lined up really well. Next up is the wiring kit from EZ Wiring. I am not looking forward to that part at all.
"Get Busy Living or Get Busy Dying"
1970 P10 Stepvan
rhodog77 is offline   Reply With Quote
Old 06-08-2010, 08:20 PM   #103
rhodog77
rhodog77's Avatar
Got a little work done this weekend. Mounted the EZ wiring fuse box and started to do some wiring. Not near as bad as I thought. Got the motor side all wired up. The motor is turning over but Im not getting any spark to the plugs. I picked up a new distributor,cap, rotor. I should have it in this weekend. It was great to hear the motor turn over but I cant wait to hear in fire up and run for a second. I also got my steering linkage (lokar aca-1800). It looks like a very straight forward install. Will post some pix of that once I get into it.
1970 P10 Stepvan
Old 06-08-2010, 08:37 PM   #104
4DSEVEN
4DSEVEN's Avatar
Coming together nicely congrats!
I purchased an EZ Wiring kit also but not at that stage just yet. Good to hear the install is going smoothly.
4DSEVEN is offline   Reply With Quote
Old 06-27-2010, 01:39 PM   #105
rhodog77
rhodog77's Avatar
Got the Lokar shifting linkage installed. I highly recommend this kit to anyone who is wanting to retain the column shifter instead of a floor mount setup. The only issue I ran into was the stock shift arm. Once the linkage was hooked up I couldnt clear the firewall. The stock shifting arm came off the column the bent back towards the firewall. I cut it, flipped it around and welded back. ( dont laugh at the rookie welding skills) but it works like a charm. The shifting action is very smooth. It was the best 50.00 bucks Ive spent on the project.
1970 P10 Stepvan
Old 06-27-2010, 01:53 PM   #106
chevy49
chevy49's Avatar
that does look good just like you said.i did buy that 5 window gmc cab.
chevy49 is offline   Reply With Quote
Old 06-28-2010, 07:04 PM   #107
rhodog77
rhodog77's Avatar
Hey Jim,
Would love to see the new cab!! Send me some pix of post them up on your build. Im sure others would like to see your new score.
Got some work done over the weekend and today. Got the speaker cover and glove box door cleaned up, painted, polished and put back together. I also got my radiator core support all mocked up with the radiator installed. I still have to sand it down a primer it up but everything came together perfectly. Im on vacation all week so Im hoping to get some things marked off the checklist!!
1970 P10 Stepvan
Old 06-28-2010, 11:42 PM   #108
jeffs51chevy
jeffs51chevy's Avatar
Brian,
That dash looks very good. I might have too get you polishing secretes. Keep up the nice work.
Jeff
jeffs51chevy is offline   Reply With Quote
Old 06-29-2010, 06:48 PM   #109
rhodog77
rhodog77's Avatar
Hey Jeff,
Nice to hear from you again. I couldnt believe how good the trim shined up. Its literally sparkling. Looks brand new or maybe even better.
Got the radiator core support sanded down and primed up. It came out really good. I left the legs a little long. I think I will end up cutting another 2-3 inches off the bottom. Sorry for all the pix and updates but keeping this thread going seems to help keep my project moving along as well.
1970 P10 Stepvan
Old 06-29-2010, 09:16 PM   #110
T Hilde
You only need to apologize for NOT updating.
T Hilde is offline   Reply With Quote
Old 06-29-2010, 11:43 PM   #111
nomas54
I am new here an thank all of yall that post up your AD builds. Keep those pic's coming!
nomas54 is offline   Reply With Quote
Old 07-10-2010, 09:12 PM   #112
rhodog77
rhodog77's Avatar
Just got back for the Goodguys Show in Columbus OH. There must have been 7000 cars and trucks. I decided to splurge a bit and picked up a new gauge set and a 12volt head light switch. I installed them when I got home. Still have to wire them up but just wanted to see how they fit and looked. Now I have to clean up the steering wheel/column, the nice and shiney gauges makes the column look ratty.
1970 P10 Stepvan
Old 07-10-2010, 10:27 PM   #113
britnjc
britnjc's Avatar
coming along very nicely. looking good. reminds me of about a year ago
britnjc is offline   Reply With Quote
Old 07-11-2010, 12:04 AM   #114
ozzie50
I used your steering column set up at the floor board. Total cost 3 dollars thanks for the idea.
ozzie50 is offline   Reply With Quote
Old 07-11-2010, 01:27 AM   #115
av8tr33337
av8tr33337's Avatar
Really enjoying all the updates. Going to be doing the same thing to my 51.
av8tr33337
AKA Bartman Email av8tr33337@yahoo.com
Bartman's Ad-S10 Chassis Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=415418
My First Youtube Video
http://www.youtube.com/watch?v=B6hSt...eature=channel
More Pics of the 51 Project
http://s668.photobucket.com/albums/v...hassis%20Swap/
1951 3100 Pickup
av8tr33337 is offline   Reply With Quote
Old 07-11-2010, 08:41 AM   #116
rhodog77
rhodog77's Avatar
britnjc,
keeping up with your build. love the new console you made. I think Im going to do something along the same lines. do you have any pix of the finished console installed in the truck?? I didnt see any on your build thread.
Ozzie,
Glad it worked out on the cheap!!!
1970 P10 Stepvan
Old 07-11-2010, 02:52 PM   #117
BlueJeep
BlueJeep's Avatar
How did you mount the gauges, did you buy rings or cut up the stock ones?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 07-11-2010, 03:51 PM   #118
britnjc
britnjc's Avatar
no pics as of yet. I got the interior in shambles from working on the AC. Once I get it all back together I will get some pics on the thread..
Old 07-11-2010, 10:24 PM   #119
rhodog77
rhodog77's Avatar
britnjc,
thanks.... look forward to seeing some pix.
Bluejeep,
I splurged and bought the rings. I wish I would have bought the gauges a long time ago. I would have made my own gauge tubs and recessed them into the dash. I already had the dash worked over and mounted so I figured it was best to get the rings and install the gauges. Im glad that I got them though. I had the gauges installed in about 15 minutes. I wired them up today, it took about 45 minutes. Very easy and straight forward. I would recommend them to anyone. Best value that I have found.
1970 P10 Stepvan
Old 07-12-2010, 01:40 PM   #120
britnjc
britnjc's Avatar
what brand of guages are they?
Old 07-12-2010, 05:27 PM   #121
rhodog77
rhodog77's Avatar
britnjc,
they are from TPI Tech. I was looking at Dolphins gauges but I just didnt like the face of the gauges, mainly the huge picture of a dolphin right in the middle of the gauge face. They were very nice but just not my style. The TPI set came with everything you need, including all new sending units. I had a question about the gauges, spoke with their customer service today, very nice and very helpful.
1970 P10 Stepvan
Old 07-12-2010, 06:29 PM   #122
britnjc
britnjc's Avatar
I am wishing I went another direction with mine. Plus they dont seem that accurate, and I also think the speedo is broken can't seem to get it to work
Old 07-12-2010, 06:31 PM   #123
BlueJeep
BlueJeep's Avatar
Which rings did you get?
I looked at gauges pretty hard at the Des Moines GoodGuys, but didn't like any of them more than I like the New Vintage ones. Just trying to decide whether or not to fork over the $$$ for the custom ones with turn indicators, hi-beam, check engine, etc.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 07-13-2010, 09:39 PM   #124
rhodog77
rhodog77's Avatar
Bluejeep,
I got the gauges from a company called luxford autoparts (www.luxfordautoparts.com). I looked at the box that the trim rings came in but there was no info on them at all. The guy I got them from said that the trim rings were designed specifically for the TPI set. The fit is awesome, nice and tight and the install was very easy. The new vintage gauges are sweet but just way out of my budget.
1970 P10 Stepvan
Old 07-17-2010, 05:09 PM   #125
rhodog77
rhodog77's Avatar
Got some work done today. I wasn't happy with the way that I fabbed up the steering linkage so I took another crack at it today. Before I had a ton of slop and play in the linkage, I intended to install a heim end but decided to go a different route. I picked up another stock s10 steering column linkage for 5 bucks!! Here is what I came up with. Its rock solid strong now.
I basically made a DD shaft coupler. Drilled 3/16 holes thru the shaft and the spline and connected them together. Had to leave some travel room for the spline or else I couldnt get it connected to the column or the steering knuckle.
Im really happy how it turned out. I still have to clean it up and throw some paint on it but installed it to see how it worked.
1970 P10 Stepvan
