Old 06-12-2012, 09:19 PM   #101
boat
boat's Avatar
Re: 63 rebuild
Originally Posted by 62 Barnfind View Post
Window frames looks great! Getting ready to do mine soon. What paint did you use?
man this job took awile to get all the weather striping out, and remove some of the rivets, i hand sanded eveything then used etching primer ,then primer sealer and mixed up some gloss black and shot two coats on it ,now it will sit for awile until i get the weather strip and glass thanks steve
STEVES 63 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=412554 GIBSON63 YouTube channel https://www.youtube.com/user/1gibsonl4
boat is offline   Reply With Quote
Old 06-12-2012, 09:28 PM   #102
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Re: 63 rebuild
Very nice work, nice attention to detail.
It will all be very well worth the patience!
A very good start at an awesome truck!
Modges'66 is offline   Reply With Quote
Old 06-12-2012, 09:34 PM   #103
boat
boat's Avatar
Re: 63 rebuild
Starting on the grill,this would be the before shots. trying to find a way to make this baby shine
Old 06-12-2012, 09:35 PM   #104
boat
boat's Avatar
Re: 63 rebuild
pic
Old 06-12-2012, 09:37 PM   #105
boat
boat's Avatar
Re: 63 rebuild
thanks Modges 66
Old 06-25-2012, 09:09 PM   #106
boat
boat's Avatar
Re: 63 rebuild
sprayed the grill down with oven cleaner it striped the anodizing, then done three different grits of sanding and hand buffing with Mothers .so far this is what it looks like
Old 06-25-2012, 09:11 PM   #107
boat
boat's Avatar
Re: 63 rebuild
more pic[ATTACH]Name:  DSC05610.jpg
Size:  60.6 KB[/ATTACH]
Old 06-25-2012, 09:13 PM   #108
boat
boat's Avatar
Re: 63 rebuild
pic
Old 06-26-2012, 07:52 AM   #109
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: 63 rebuild
DDrroooolll....wow, that turned out awesome..I love it
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 06-26-2012, 08:05 AM   #110
losthope
losthope's Avatar
Re: 63 rebuild
Wow looks brand new! May I ask how does the process go( sand first with three grits then polish?) and what grit paper do you use??or tips on doing it....
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 06-28-2012, 12:49 AM   #111
boat
boat's Avatar
Re: 63 rebuild
Started with washing with soap and water then sprayed oven cleaner with sodium hydroxide in it let sit for 15 min washed off then done it one more time.started wet sanding with 320 /600/1000/2000 then hand polished with mothers until it shined and polished some more .this took me about 14 hours in all
Old 06-28-2012, 01:04 AM   #112
losthope
losthope's Avatar
Re: 63 rebuild
Right on! thank you for explaining that ive never done something like that and have a bumper id like to try it on...Once again it looks amazing !
Timmy D.
Old 06-28-2012, 01:16 AM   #113
boat
boat's Avatar
Re: 63 rebuild
Thanks Timmy I've never tryed it on a bummer my grill is aluminum still have to do all the side trim and the rings around the headlights Thanks Steve
Old 07-29-2012, 11:06 PM   #114
CRGRS 66
CRGRS 66's Avatar
Re: 63 rebuild
great looking project, subscribed, need to go back and read through the entire build
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 10-17-2012, 10:22 PM   #115
4dranch
Shloooooong bed member #2
4dranch's Avatar
Re: 63 rebuild
Super Job. Subscribed
And your close too.
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 10-18-2012, 08:33 AM   #116
CRGRS 66
CRGRS 66's Avatar
Re: 63 rebuild
What do you plan to do to preserve the shine. The aluminum will dull and corrode won't it?
Craigerrr
Old 10-18-2012, 11:50 AM   #117
boat
boat's Avatar
Re: 63 rebuild
Haven't found any info on keeping the shine on it besides a little wax every now and then
Old 10-31-2012, 01:28 PM   #118
boat
boat's Avatar
Re: 63 rebuild
havent wax it yet or found anything to keep it from dulling out on me got it stored up until i get paint on the truck
Old 11-01-2012, 12:07 AM   #119
boat
boat's Avatar
Re: 63 rebuild
been doing some rust repair on door bottoms
Old 11-01-2012, 12:14 AM   #120
boat
boat's Avatar
Re: 63 rebuild
patch
Old 11-01-2012, 12:18 AM   #121
boat
boat's Avatar
Re: 63 rebuild
more pic
Old 11-01-2012, 12:21 AM   #122
boat
boat's Avatar
Re: 63 rebuild
pic
Old 11-01-2012, 12:39 AM   #123
boat
boat's Avatar
Re: 63 rebuild
been doing some floor repair
Old 11-01-2012, 12:41 AM   #124
boat
boat's Avatar
Re: 63 rebuild
cab corner went in pretty smooth
Old 11-01-2012, 12:43 AM   #125
boat
boat's Avatar
Re: 63 rebuild
pic
