Old 02-16-2011, 03:33 PM   #101
jltait
Re: 85 GMC Sierra Classic 1 Ton Crew Cab
Matt,
sounds like a good plan!
JLT
jltait is offline   Reply With Quote
Old 02-17-2011, 12:59 AM   #102
Mattman2010
Mattman2010's Avatar
So I got the axles all back together and decided to put them under the frame, and put the drive shaft in there to check the angle. I dont have an angle finder but i think that i probably need to find a shim to put under the rear axle. The next thing i am going to do is put the front ubolts on and then drop the engine/tranny/t-case and see what i have for stuff. I dont have rear ubolts yet as I need to figure out what kinda shim i need.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 02-17-2011, 05:30 PM   #103
jltait
Matt,
I am sure you are correct about needing a shim. By the looks of the pictures the front mount of the Rear leaf springs was moved down some while the rear mount stayed in the stock location albeit the 4x4 mount in lieu of the 2wd mount. However both the front and rear of the rear leaf springs have been changed to 4x4 mounts so the difference (or the amount of shim) should be equal to the angle that the rear leaf front mount moved down. The springs should be 56" so if it moved down 2" you should be able to calculate the angel the RR leaf spring changed and get a shim from DIY4x to shim up the pinion that amount. If you have an email address send it to me, I have a driveshaft setup guide in pdf I can send to you.
JLT
Old 02-17-2011, 05:50 PM   #104
Mattman2010
pm sent
Build Thread
Build Thread
Thread
Old 02-18-2011, 03:19 PM   #105
Mattman2010
So this morning I got the engine/tranny all mounted up into the frame. And i set the driveshaft in there to see what it would kind of look like.
Rear
Carrier Bearing
Tranny
And Tranny Mount
I am afraid to put bushings between the transfercase mount because i think it would be to high. Does anyone know if someones makes doughnut bushings that would fit around a bolt that i could smash between the transfercase and the mount?
Matt
Build Thread
Build Thread
Thread
Old 02-18-2011, 11:30 PM   #106
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Nope Its not going to work, You need a NV4500!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 02-18-2011, 11:52 PM   #107
Mattman2010
Im trying to find one!
Build Thread
Build Thread
Thread
Old 02-23-2011, 01:02 PM   #108
Mattman2010
I started to paint the frame on sunday and got a coat of paint on the frame and rear axle, I then ran out of paint. I am hoping to get another coat of paint on stuff tomorrow and start to get the frame all bolted back together and get everything figured out.
As for the transmission I had a hard time figuring out what I wanted to go with. The TH400 is going to cost me more than I want to to get it behind that 6.2, so I decided that I was going to go manual, but couldnt find a NV4500 that kept me in budget. I will be getting a SM465/NP205 to put into this truck. Hoping to go pick it up this weekend.
I plan on running a hydro clutch in this truck so that later down the road when I cant afford a NV4500 i just have to adapt it to the slave cylinder on the nv4500. The SM465 is not a hydro bell housing, but I got an idea from this and so I think I am going to try to make something like this.
Matt
Build Thread
Build Thread
Thread
Old 02-23-2011, 07:33 PM   #109
jltait
Matt,
That looks like a really good Idea, I have also seen kit that replace the front bearing retainer with one similar to what is on the nv4500's with internal slave. Not sure I have seen them for a SM465 though? I think the the one's I saw were for Muncie's and pricey to boot.
JLT
Old 02-23-2011, 08:30 PM   #110
Mattman2010
I like the idea of having an external slave and just using stock SM465 parts. The idea of the bracket is a good one, but i want to make one stronger so that i know it wont bend and cause me to loose my clutch.
Build Thread
Build Thread
Thread
Old 02-23-2011, 11:44 PM   #111
Mattman2010
Got a second coat of paint on some stuff. Still need to sand blast some stuff and then start mounting the axles and figure out the rest of the drive train.
Front axle
Front Springs
Rear Srings
Rear Axle
Frame
Build Thread
Build Thread
Thread
Old 02-24-2011, 07:06 AM   #112
justpball
justpball's Avatar
frame looks great!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 02-24-2011, 09:39 AM   #113
Mattman2010
Thanks Justpball!
Well today it is raining so I am not sure that i will be able to sand blast anything, I am going to wire wheel some things to kind of keep me going. So not much more before I get the axles underneath the frame. once the axles are under the frame and I have the engine/tranny/tcase in i need to figure out what kind of shims i need and then I should basically just start putting things back together, but with some modifications!
Build Thread
Build Thread
Thread
Old 02-25-2011, 12:32 AM   #114
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Everything looks good matt! I guess you use a camera phone also.
Tony
Old 02-25-2011, 12:36 AM   #115
Mattman2010
Yes I do, the mother does not want me to get her camera dirty! haha
Build Thread
Build Thread
Thread
Old 02-25-2011, 10:34 AM   #116
jltait
Matt,
Looking good!!
Old 02-25-2011, 11:27 AM   #117
Mattman2010
Thanks JLT!
The paint is not drying, I painted it in 60 degree weather, and that night it got down to about 30 and has been 30 or below sense. Sucks because i was hoping to get my front axle under the frame for the last time.
Build Thread
Build Thread
Thread
Old 02-27-2011, 12:13 AM   #118
Mattman2010
Paint is still drying. I just got home with a SM465/NP205 so that should do for the tranny for now!
Build Thread
Build Thread
Thread
Old 02-27-2011, 09:36 AM   #119
jltait
Congrats on scoring the SM465/np205! should be a great combo for you.
JLT
Old 02-27-2011, 11:29 AM   #120
Mattman2010
The thing that sucks about having to buy this one is the fact that I already have that combo but 2nd gear is messed up on it and the guy I bought this new one from wouldn't seperate the combo!
Build Thread
Build Thread
Thread
Old 02-27-2011, 02:28 PM   #121
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
so the Dana 44 would work with the 70? what about the hubs? i want to convert mine to 4x4 but its not easy to find a Dana 60 front axle
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 02-27-2011, 02:38 PM   #122
Mattman2010
As long as the gear ratio and tire diameter are the same you and run any combo of axles you want. I will just be running 3/4 ton wheels on the front, I will not have the dually wheels on the dana 44. My dually wheels are 16" and my 3/4 ton wheels are 16" as well so I will just buy the same tire and it will work.
I am running a Dana 44 because I can pick them up for about $100 where as a Dana 60 is about $500+ and I'm on a budget! At some point I might upgrade to a Dana 60, but I have seen 1 ton trucks with Dana 44's under them with just regular 3/4 ton wheels and I didn't think they looked bad.
Build Thread
Build Thread
Thread
Old 02-27-2011, 08:15 PM   #123
Mattman2010
Well i got the rest of the suspension brackets painted and took my SM465/NP205 combo apart and then bolted my NP205 from my k20 and my bell housing from my k20 to the new transmission. Need to power wash that and then get it painted. Should be getting a hydro clutch this week so that I can also try to make up a bracket to get that all hooked up. I still need to figure out what shims I need for the rear to get my axle at the right angle.
Matt
Build Thread
Build Thread
Thread
Old 03-02-2011, 12:08 PM   #124
Mattman2010
So yesterday was a really nice day and so I put as much stuff back together as I could. I got the front axle and rear axle installed (Need to replace the rear ubots) and also got the 6.2/SM465/NP205 into the frame and started looking at options for mounting the SM465/NP205 to the frame. I am going to go with the cross member out of my k20 that mounts to the bottom of the frame, I am mounting it to the bottom of the frame to drop the transmission/tcase down about 2 inches to get a better angle for the drive line. I am also going to be dropping the carrier bearing down 2 inches which I think gets rid of my pinion angle problem. I plan on taking the frame up to the local drive line shop and see if they think that will work, and also have them cut down the first part of the 2 piece rear drive shaft.
Build Thread
Build Thread
Thread
Old 03-06-2011, 10:51 AM   #125
Mattman2010
Friday I got the rear drive shaft cut down, i also ordered some new rear ubolts so I can get the rear axle fully installed. Droping the Transmission 2 inches and the carrier bearing 2.5 inches did the trick of fixing all of my angles in the drive line. I removed the 6.2/SM465/NP205 for hopefully the last time! I got the tranny/tcase ready to paint. I need to install new front steel lines and mount the engine cross member and then the drive train will be ready to go back in. I need to get the gas out of the tanks and clean and paint them and then finish up a few things on the frame and then it will be time for body!
I am having a hard time finding ujoint straps for my dana 44, I took the dana 44 out of my k20 about 3 months ago and have lost my straps and its hard to find some new ones.
Build Thread
Build Thread
Thread
