Old 03-31-2011, 02:33 PM   #101
VA72C10
VA72C10
VA72C10's Avatar
Re: 71 Cheyenne Super- A Combined Effort
Nice progress!!! Looking good!!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-01-2011, 01:06 AM   #102
BlackZ28
Very nice progress and build, Subscribed!
99 Camaro Z28 420hp/400tq
1998 Tahoe Z71 2dr 6" Rancho 35's DAILY
BlackZ28 is offline   Reply With Quote
Old 04-01-2011, 10:35 AM   #103
gcburdic
Restoration Virgin!
gcburdic's Avatar
Originally Posted by JJanzen View Post
You guys are doing a great job......I have the exact same project ahead of me in the near future! Looking forward to seeing the progress!
Originally Posted by mcbassin View Post
Serious progress! Man it looks great! Keep the pics coming!
Thanks folks....our next work weekend will be the end of April....hoping to get all the suspension and frame painted and have a roller by the end of the weekend!!!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-02-2011, 10:41 AM   #104
RCbowtie69
RCbowtie69's Avatar
Looking good,keep on truckin''
RCbowtie69 is offline   Reply With Quote
Old 04-02-2011, 10:56 AM   #105
leddzepp
Moderator
leddzepp's Avatar
lookin' tough!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 05-01-2011, 09:16 AM   #106
72chevy383
Originally Posted by brn agn View Post
I had some car ministry work on Saturday, but had a couple of hours afterwards to work on the Super. The kick panel on the driver's side is fitted and tacked in place as well as the front core support. Here are pictures:
I was looking at your inner rocker and wondering why it doesn't run up to the seam? looks to be short, I'm doing mine now and that area just doesn't seem to fit right. what your trick?
72chevy383 is offline   Reply With Quote
Old 05-01-2011, 11:45 AM   #107
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Truck is really comming along guys keep up the good work..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-01-2011, 02:45 PM   #108
red69ss
Burnouts are therapeutic
red69ss's Avatar
great work geoff and jesse , that cab and rust repair look very fimiliar to me!
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 05-01-2011, 05:30 PM   #109
brn agn
brn agn's Avatar
The inner rocker we used was too long for the space it is intended for, so we cut off the front of the rocker and welded it in. I'll be making a small patch panel to fill in the gap between the rocker and seam.
Since we are on the subject of cab repair, here are a few pictures of progress from this weekend.
The bracket that the lower door hinge bolts thread in to was missing from inside the a-pillar on the passenger side. sharpie1972 sent us a used one. I didn't get a before picture, but the bracket is L-shaped and has a thin sheet metal "cage" that is spot welded to the a-pillar in two place. The cage is designed so the bracket will not fall into the a-pillar, but it has enough play that the hinge can be adjusted. So, I drilled out the spot welds on the piece sharpie1972 sent us:
I guess I was making good progress, because I didn't think to take any pictures of the next steps!
I then used the old a-pillar as a template and marked the two holes on our cab, and drilled them out. I cut a square access panel to get to the inside of the a-pillar, slid the bracket and cage inside the a-pillar and spot welded it in place. In order to pull the bracket/cage close to the a-pillar, I inserted a 1/4-20 bolt with a large fender washer on the backside through the bracket and used a washer and nut on the outside to hold the bracket/cage in place.
In this picture you can see the top spot weld (I have already ground some of it down) and the access hole in the front:
...then it was just a matter of welding everything shut and putting primer on the exposed metal:
I also worked on fitting the driver's side cab corner today. I have a little more work to do on it before I weld it in place, but it is close.
While I was doing this, Geoff was working on the frame, suspension, steering, etc... More to come on that later!
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 05-01-2011, 10:56 PM   #110
mcbassin
Still Learning
mcbassin's Avatar
Very nice work guys! Awesome repair. Brings back fond memories
mcbassin is offline   Reply With Quote
Old 05-02-2011, 10:09 AM   #111
gcburdic
Restoration Virgin!
gcburdic's Avatar
So glad to be working with Jesse on this one, cuz I know I would of never been able to weld things up as well as he does.....Wanted to also post up some pictures of painting the chassis and suspension parts, and our progress on the assembly.....
Jesse built this "swing" for the parts to hang on for painting
and here's the rear end
and this is what we used....suggest getting 3 quarts, but maybe cheaper to just buy a gallon
and the chassis.....we lacked a lower control arm seal (stupid me forgot to check to make sure they were in there), and the 2-u-bolts for the rear end...it's amazing what 3 measly parts can railroad your weekend work but we forged ahead...many thanks to 1972SuperCheyenne for the trade on the tie rods/ adjusting sleeves....this is how she sits as I left yesterday afternoon....I'll be back in 2 weeks to hopefully make this one a roller
By the way....we ended up using MOOG Control arms, tie rods, and adjusting sleeves, and TRW ball joints
Geoff with a G
Old 05-02-2011, 10:50 AM   #112
67cheby
67cheby
67cheby's Avatar
Nice progress
67cheby is offline   Reply With Quote
Old 05-02-2011, 11:12 AM   #113
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looking really really good fellas. Nice work on the patch Jesse!
--Josh
Old 05-02-2011, 11:35 AM   #114
brn agn
brn agn's Avatar
I am proud of my redneck swingset. It is a shame that I have to disassemble it tonight.
Old 05-02-2011, 11:46 AM   #115
mcbassin
Still Learning
mcbassin's Avatar
Hey you guys are doing some nice work! Coming together fast. I like the swing set. very good idea.
Old 05-02-2011, 12:24 PM   #116
gcburdic
Restoration Virgin!
gcburdic's Avatar
Originally Posted by 67cheby View Post
Nice progress
Thanks!!
Thanks again Josh for the trade on the tie rods/ adjusting sleeves....hope that sway bar works for ya
Thanks Mike.....we actually released one side of the tie straps to paint the bottom side....
Geoff with a G
Old 05-02-2011, 12:27 PM   #117
gcburdic
Restoration Virgin!
gcburdic's Avatar
Jesse....maybe we should leave that up for the NEXT project
Geoff with a G
Old 05-02-2011, 01:29 PM   #118
VA72C10
VA72C10
VA72C10's Avatar
Nice work guys!!!
Old 05-02-2011, 07:15 PM   #119
brn agn
brn agn's Avatar
I will need to reinforce it before we hang a Suburban!
Old 05-02-2011, 08:33 PM   #120
RCbowtie69
RCbowtie69's Avatar
I've just got to say,that you have done some very nice work & love the welding you have done on the cab,keep up the hard work,love the pictures of the progress,hope to see more soon
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
Old 05-02-2011, 08:50 PM   #121
STOCKISH
STOCKISH's Avatar
I agree, very nice repair work. Great job fellas!
--Josh
Old 05-02-2011, 11:50 PM   #122
FRENCHBLUE72
PROJECT 7DEUCE
Nice work guys.
MEMBER #6377
Project "7DEUCE"
Old 05-03-2011, 09:03 AM   #123
gcburdic
Restoration Virgin!
gcburdic's Avatar
We're getting a burb?!?!?...
Geoff with a G
Old 05-03-2011, 10:15 AM   #124
brn agn
brn agn's Avatar
Yep, it is a 71 rust free survivor with original paint. It was owned by an older gentelman in Arizona and he only drove it on Sundays when it was not raining. It has 27,890 miles on it and some decent options: big block, bucket seats, factory tach. It is blue and white. It should be shipped to your house today. I hope your wife doesn't mind.
Old 05-03-2011, 05:18 PM   #125
RCbowtie69
RCbowtie69's Avatar
Cool,hope to see pictures of it soon,nice score
