Old 11-26-2012, 10:34 PM   #101
Skunksmash
Skunksmash's Avatar
Re: Tachometer , any cool ideas?
Originally Posted by slugish View Post
4 in autometer in dash where fuel guage was.
Originally Posted by Restrorob View Post
That looks like a slick trick.... But, Where's the gas gauge now ?
I did the same thing sluggish did. You have to be VERY careful when you're wallerin' out the hole in the back for the deeper RPM gauge. It sits deeper than the fuel gauge did. But, it does fit perfectly. Autometer brand. Pro comp IIRC. You just put the fuel gauge where the clock was. Notice the hole in the lens for that clock knob. Or if you're lucky your lens has no hole cause you never had a clock. I'll be plugging the hole. Digital water gauge cause I was tired of the stock junk lying to me. Sorry about the low quality pics my camera sucks at night.
Hey sluggish. Does your RPM gauge seem like the needle doesn't go above 2k RPM's much? I was expecting it to act more like a normal tach but its a 10k RPM tach so its like the needle doesn't move around a whole lot. Or something. Did you notice this? I have tbi 350 with 700R4 and 2:73 rearend. lol. So maybe unless you really beat on it, it just doesn't go about 2k much. I can get it to go about 2500 rpm but it immediately shifts.
Skunksmash is offline   Reply With Quote
Old 11-26-2012, 10:47 PM   #102
INSIDIOUS '86
INSIDIOUS '86's Avatar
I'm getting some sunpros in a couple days via summit along with my iroc tach and fuel gauge. I will do a write up on a performance dash for the cheap
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-28-2012, 02:06 PM   #103
Hoppedup85
I like the idea of the camaro fuel gauge + tach! could you possibly do a write up? mines a 85' gmc.
85' Gmc Sierra 350 sbc lots of Eldelbrock top end more to come!
Hoppedup85 is offline   Reply With Quote
Old 11-28-2012, 03:13 PM   #104
carboncrew
carboncrew's Avatar
I went for the factory look...I'm happy with the way it turned out.
carboncrew is offline   Reply With Quote
Old 11-28-2012, 03:49 PM   #105
motornut
78K & 79C Jimmys
motornut's Avatar
nice,you would think it was born that way!
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 11-28-2012, 04:00 PM   #106
motornut
78K & 79C Jimmys
motornut's Avatar
Originally Posted by motornut View Post
well i went with my top right tach idea
worked out cept the tac quit after running for about a day
bout 18 years old lol time for a new one
found a short inside works fine now
Hmm things have changed for me
John
Old 11-28-2012, 04:07 PM   #107
JRANGER
JRANGER's Avatar
Ive got a different cluster so mine will be a little different but im adding a digital tach to the clock spot...Ill take pics of that when i hopefully do this weekened
JRANGER is offline   Reply With Quote
Old 11-28-2012, 06:48 PM   #108
Chevrolado
Chevrolado's Avatar
Wow. That looks SUPER clean.. Can you provide any information on that? So far the little SunPro attached to the column is my favorite for what I want to do with my 77 K10, but now you've changed my mind. How can I do this? Thanks for any additional information you can provide.
Dave
- 1977 Chevy K10
Chevrolado is offline   Reply With Quote
Old 11-29-2012, 09:36 AM   #109
carboncrew
carboncrew's Avatar
I ordered the tach from GMsportssalvage. Since then I've noticed LMC started caring tach's, but I'm not sure how they look and operate.
You need to do some trimming to the cluster housing but other than that it plugs right in.
The only thing I would check is that the lettering match your speedo...I know the website lists 1973-1986 but the text on the guages changed sometime in early 80's I think. Hope that helps. Thanks
Old 11-29-2012, 12:26 PM   #110
Chevrolado
Chevrolado's Avatar
Sweet. Thank you!
Dave
- 1977 Chevy K10
Old 12-28-2012, 11:52 PM   #111
JRANGER
JRANGER's Avatar
Ok so for $20 I bought a Dragon Digital Gauge off Ebay....
I cut and opening in the plastic lens and metal to fit it..
Then I sanded down the backside of the gauge bezel so it sat flush
I also used a couple 4 pin connectors to make a harness so it is easily disconnected with the cluster
Hindsight I probably could of cut away the lens area and mounted it on the top of metal and not had to sand the bezel at least as much
Old 02-09-2013, 04:27 PM   #112
owner 84
owner 84's Avatar
I did mine last month. I bought my tach from LMC truck with the fuel gauge.
email me @ nasser_060@hotmail.com
and Check out my flicker @
http://www.flickr.com/photos/0060/
owner 84 is offline   Reply With Quote
Old 02-09-2013, 04:34 PM   #113
Duster
Duster's Avatar
Originally Posted by carloscanales View Post
hey guys
i wan to get a tach for my truck
im looking for something little , maybe something i can install on the ashtray compartment o maybe on the steering column
i want a clean look
any ideas??
good tach brand??
here are some interior pics
That has a canadian cluster in it? That is cool. I have never seen one of those.
Duster is offline   Reply With Quote
Old 02-11-2013, 08:30 AM   #114
motornut
78K & 79C Jimmys
motornut's Avatar
nope, i think it 's Mexican
check bottom left in gauges,fuel gauge F/E
John
Old 02-11-2013, 11:07 AM   #115
Telecasterjoey
Definitely Mexican! I really like that interior tho.
Telecasterjoey is offline   Reply With Quote
Old 02-11-2013, 11:07 AM   #116
Telecasterjoey
Old 02-11-2013, 02:33 PM   #117
ivorton74
ivorton74's Avatar
I want to get those white face gauges and blue led bulbs...is it hard getting the cluster out? how do u get the speedo cable off? also does the HVAC controls use the same 194 bulbs as the cluster?
ivorton74 is offline   Reply With Quote
Old 02-11-2013, 03:03 PM   #118
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Its pretty easy, the hardest part is just getting the gauge pod out of the dash because the bottom you kinda have to persuade out from behind the lip of the dash. There is a round clip on the cluster that surrounds the cable, you just have to push the bottom of the tab back towards the cluster then pull the cable out. Yes HVAC controls use the same bulb and holder.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 02-11-2013, 03:44 PM   #119
ivorton74
ivorton74's Avatar
cool thank u
Old 02-12-2013, 01:07 AM   #120
Dylan86
Dylan86's Avatar
For mine I just cut out the un-used hole in the cluster, bought a generic tach, painted to match and stole a needle from another cluster to make it look close to something from factory...
Dylan86 is offline   Reply With Quote
Old 02-12-2013, 09:51 AM   #121
motornut
78K & 79C Jimmys
motornut's Avatar
cool the font is very close,it blends in well
John
Old 02-12-2013, 11:26 PM   #122
Emmaschevy
Emmaschevy's Avatar
I found a factory tach and small gas gauge on Craigslist for $40. Is it easy to install in a non factory housing? Iv never had one apart.
Emmaschevy is offline   Reply With Quote
Old 02-13-2013, 12:36 AM   #123
motornut
78K & 79C Jimmys
motornut's Avatar
sounds like a score,
as long as it's not an idiot cluster, it should work with some wireing changes
but it's gona need support behind it.
normally there is a cut out,and a piece added to hold the tach
have a look
John
Old 02-13-2013, 02:47 AM   #124
cmax87v3500
cmax87v3500's Avatar
i always buy a autometer street tach, then hang it from the dash pad right in between the speed and gas gauges. it cuts off a little of your speedo and gas guage, but not enough to make it matter, like above 70 on the speedo and below a 1/8th tanks on the gas (depending on how you are sitting) and i think, its the cleanest looking way to do a aftermarket tach.
1987 GMC V3500 Sierra Classic
cmax87v3500 is offline   Reply With Quote
Old 02-13-2013, 03:45 AM   #125
INSIDIOUS '86
Don't think I posted my sunpro's.
