Closed Thread
Old 06-15-2013, 08:33 PM   #101
_Ogre
_Ogre's Avatar
Re: Roadkill's 58 Chevy Stepside
not sure about the measurement
but i moved my centerline forward 3/4 inch to center the lowered wheel in the wheel well
shop air compressor timer
_Ogre is offline
Old 06-16-2013, 12:11 AM   #102
Kim57
Kim57's Avatar
Originally Posted by Roadkill58 View Post
Before I tack weld the TCI IFS crossmember did everyone use the 20 7/8"
measurement or did you make an adjustment to center the wheel?
I would check with TCI. It's possible they took that into account with their measurements.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline
Old 06-16-2013, 02:10 AM   #103
Roadkill58
Roadkill58's Avatar
Thanks Ogre, and Kim57.
I gues the best way for me is to tack the crossmember in and one top hat and install the a-arms and spindle and bolt on a wheel, hang one fender and see if I like it.
Not sure what wheel or size I'm going to run.
I have 15's on it now and I have some 16's I can try.
Should be able to get close.
I will make note of what ever the measurement is so the next one will be a no brainer.
Regardless of the measurement I will still make sure I have the same distance from center of axel front to rear on both sides.
I don't want the truck going down the road crooked.
Rust Never Sleeps
Roadkill's 58 Chevy Stepside build
Roadkill's 69 Custom C20
Roadkill58 is offline
Old 06-17-2013, 09:52 PM   #104
Roadkill58
Roadkill58's Avatar
Ok guys and gals how does this look?
I'm not talking about the incredibly ugly fender.
I'm talking about the wheel being centered in the wheel well.
Rust Never Sleeps
Old 06-17-2013, 10:09 PM   #105
dubie
dubie's Avatar
Looks good man, right where it's supposed to be
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline
Old 06-17-2013, 10:55 PM   #106
papastrk
Did you use the 20 7/8" measurement?
papastrk is offline
Old 06-17-2013, 11:03 PM   #107
Roadkill58
Roadkill58's Avatar
Thanks Dubie.
Do you think it should be moved forward an inch?
Rust Never Sleeps
Old 06-17-2013, 11:04 PM   #108
Roadkill58
Roadkill58's Avatar
Yes I did.
Rust Never Sleeps
Old 06-17-2013, 11:37 PM   #109
Roadkill58
Roadkill58's Avatar
The crossmember is only tack welded. It can be moved easily.
Rust Never Sleeps
Old 06-17-2013, 11:45 PM   #110
Kabwe
Certified Car Nut
Kabwe's Avatar
Looks good to me also. Is that your ride height for the rear also? If not I would put the rear at ride height also.
Kabwe is offline
Old 06-18-2013, 12:10 AM   #111
Kim57
Kim57's Avatar
Looks good.
Kim
My build thread
Kim57 is offline
Old 06-18-2013, 12:34 AM   #112
Roadkill58
Roadkill58's Avatar
Not sure if the jack was still up back there when I took pic. Guess I should mock it up again and make sure.
The bed isn't on so it will sit a little higher in the rear than it should.
Rust Never Sleeps
Old 06-18-2013, 12:50 AM   #113
Roadkill58
Roadkill58's Avatar
Originally Posted by Kim57 View Post
Looks good.
Kim
Thanks Kim.
Rust Never Sleeps
Old 06-18-2013, 08:47 AM   #114
papastrk
I'm measuring from the center of the front spring shackle hole back to get my axle centerline. Is this correct?
papastrk is offline
Old 06-18-2013, 09:10 AM   #115
dubie
dubie's Avatar
how far down are you lowering it?
dubie is offline
Old 06-18-2013, 09:51 AM   #116
Roadkill58
Roadkill58's Avatar
Yes from the center of the front spring shackle hole.
Rust Never Sleeps
Old 06-18-2013, 09:56 AM   #117
Roadkill58
Roadkill58's Avatar
I haven't measured ride height. Just want it to be low and mean.
It should a at least 2" or 3" lower than it is now once the engine, trans, and hood and fenders are on.
Rust Never Sleeps
Old 06-18-2013, 02:11 PM   #118
_Ogre
_Ogre's Avatar
if you have your lower a arm installed, level it and look again
your lower a arm should be level at ride height
me thinks if your going 2-3'' lower it will look a bit to the rear of the wheel well
_Ogre is offline
Old 06-18-2013, 02:26 PM   #119
OrrieG
OrrieG's Avatar
Looking at the top horizontal part of the wheel well it looks a little back to me too. I would weight down the front to check it, about three or four big friends will do for temp ballast.
OrrieG is offline
Old 06-18-2013, 03:04 PM   #120
Roadkill58
Roadkill58's Avatar
Same truck. Same ugly fender. 15" wheel on rear with no bed.
16" wheel on front with strut (solid pipe) and bottom A-arm horizontal.
Rust Never Sleeps
Old 06-18-2013, 06:09 PM   #121
OrrieG
OrrieG's Avatar
That looks ok to me, I may have to backtrack on my previous post. I was looking a Denee post and her front tire (stock axle) lays in about the same place as your first picture, so you are close to stock.
OrrieG is offline
Old 06-18-2013, 09:06 PM   #122
Roadkill58
Roadkill58's Avatar
Lets settle this measurement thing logicaly.
There is only so much space of the wheel opening that is usable.
Let's say that number is 22 inches. Divide that in half is 11 inches.
Ogre the difference between this center and the recomended center is
3/4 of an inch to the front of the truck.
What do you guys and gals think?
I made the strut per Kabwe's suggestion. 2 pieces of pipe, 4 fender washers, two bolts. Simple. You can add washers to the top to fine tune.
Should have at least primed that ugly fender so my calculation would be more legible.
Rust Never Sleeps
Old 06-18-2013, 10:31 PM   #123
_Ogre
_Ogre's Avatar
math doesn't lie
ride height is set right
center is 3/4'' forward
_Ogre is offline
Old 06-18-2013, 11:42 PM   #124
Roadkill58
Roadkill58's Avatar
Don't know if this applies to 55 thru 57. It may just be a 58 thru 59 thing.
Now I have to cut out the tack welds and move it forward 3/4".
If I had listened to Ogre I would be done!
Rust Never Sleeps
Old 06-19-2013, 12:05 PM   #125
_Ogre
_Ogre's Avatar
what is the outside size of your tires?
i run 15'' rims with a 28 tire
your 16'' tires look small in there
maybe its all the light behind it, no inner fender
_Ogre is offline
Closed Thread
