Old 11-29-2013, 12:21 AM   #101
truckzilla
truckzilla's Avatar
Re: LS factory cruise control hook up
Can't wait to see if I can do this with my 2008 Pontiac G8GT conversion!
truckzilla is offline   Reply With Quote
Old 11-30-2013, 03:31 AM   #102
Daaaanz67
Yoooooou caaaaaaan doooooooo itttttttttttt!!!!!!!!!!!
Daaaanz67 is offline   Reply With Quote
Old 12-06-2013, 04:10 PM   #103
socorob
This was a great writeup, thank you so much. I have a question about using rocker/toggle/pushbutton switches instead of the GM stalk. My LS is going into a Datsun so I don't have a place to mount a stalk.I drew a photo of the wiring diagram I think is correct. Could someone verify it please? Thanks!
socorob is offline   Reply With Quote
Old 12-06-2013, 04:14 PM   #104
socorob
Forgot to attach the drawing. Sorry for it being so sloppy, I just did it quickly.
Old 12-06-2013, 07:09 PM   #105
ls1nova71
ls1nova71's Avatar
That looks correct to me. Nice drawing by the way!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-06-2013, 07:16 PM   #106
socorob
Thanks! Couldn't have done it without you. Now to start wiring.
Old 12-23-2013, 08:53 AM   #107
socorob
I may have missed it, but what size fuse did GM use on the cruise control circuit?
Old 12-24-2013, 12:49 AM   #108
ls1nova71
ls1nova71's Avatar
I probably should have included this info in the first post. If I can figure out how, I will go back and edit it. But to answer your question, there should be two 10 amp fuses, one on the wire going to D and one on the wire going to G on the cruise module.
Old 12-24-2013, 10:44 AM   #109
JJH Jimmy
JJH Jimmy's Avatar
ls1nova, what fuses should be used on a DBW application and where should they go? Thanks.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 12-24-2013, 11:38 AM   #110
solidaxel
solidaxel's Avatar
Thanks, I need to follow that one as mine is a piece together rocker style on- off switch and push button stalk only with DBW 2003 5.3
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-24-2013, 11:57 AM   #111
ls1nova71
ls1nova71's Avatar
10 amp fuse on the wire powering up the switches. The light blue wire going to pin C1-6 on the TAC module is also fused with a 15 amp fuse, but since you will be tapping power off your brake switch, it would already be fused through the original brake light fuse, so you don't need to add another one.
Old 12-24-2013, 12:25 PM   #112
socorob
Would this be correct?
Old 12-24-2013, 12:27 PM   #113
JJH Jimmy
JJH Jimmy's Avatar
Thank you!
1985 Chevy K20
1994 GMC Yukon
Old 12-24-2013, 12:45 PM   #114
ls1nova71
ls1nova71's Avatar
Actually the wire going to "G" wouldn't need a dedicated fuse since it would be fused at the original brake light fuse before the switch.
Old 12-24-2013, 01:43 PM   #115
socorob
Thanks, I just thought you were being redundant for extra protection.
Old 04-24-2014, 09:47 AM   #116
1965Impala
ls1nova71, in your hand drawn diagram in your first post, you indicate that the "J" is not necessary for the cruise to work. Does that mean it is optional or that it should not be connected? Just out of curisosity, what does the "cruise engagment signal" do? I assume that it is the Cruise Module telling the PCM that the cruise is engaged, but what is the PCM doing with that information? Thanks for all of the great information.
1965Impala is offline   Reply With Quote
Old 04-24-2014, 10:42 AM   #117
ls1nova71
ls1nova71's Avatar
I've heard that there are different shift tables for when the cruise is engaged, however, I hooked that wire up on both my truck and my car, and couldn't tell any difference what so ever. I suspect it also sends a signal to the instrument cluster, which is a module it's self, and is what will disengage the cruise when the shift lever is moved into neutral while driving with the cruise on. I have the factory 5.3 NSS mounted on the transmission, and all the wires are hooked up, and it does not disengage when shifted into neutral. Not a big deal since it seems totally unnatural to do that anyway, but I've tested it and it's the same on both of my cars, it will rev until it hits the rev limiter if you don't shut it down first. Also, as far as I know, all aftermarket cruise controls will do the same thing.
Old 04-24-2014, 12:12 PM   #118
1965Impala
Got it. Thanks for the quick reply!
Old 04-30-2014, 09:21 AM   #119
chipflyer
chipflyer's Avatar
Great thread with lots of great info! I have a new wrinkle though and I will say that after looking at lots of info about adding this cruise control I have worked myself into a state of confusion.
I am adding a 2002 5.3 to my truck. I hadn't originally planned to add cruise but it seems pretty simple, I have it and its now part of the build. I have built the relay circuit shown that Brendan shows on lt1swap.com to send 12v to the PCM (TCC) when I hit the brakes, simple enough.
Now my question is can I use this same circuit for the cruise solution by tying (pin G) into the cold side stop lamp between relay post 85 (circled in red)? Relay post 30 (12v to TCC) could then also be tied into terminal D on the cruise harness for power until the brake pedal is pushed, correct?
It would seem to me I can do this with the original 2-terminal brake switch with little modification and keep things fairly clean and both the TCC and cruise would get what they both need to work correctly.
Am I missing something though? thoughts?
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 04-30-2014, 10:10 AM   #120
ls1nova71
ls1nova71's Avatar
^^^ Yes, that should work fine. You worded your second paragraph backwards, it cuts power to the TCC when brakes are applied, but we get the idea.
Old 04-30-2014, 02:47 PM   #121
chipflyer
chipflyer's Avatar
Yep, I got that wrong. Should have been:
"when I hit the brakes, no power to TCC or Pin D, simple enough".
Thanks for replying ls1nova71, I was hoping you would take a look and chime in.
Jeff
Old 05-13-2014, 10:00 PM   #122
atltd4x4
Do you have any more of the cruise levers? I have 05 Gen 3 DBW.
atltd4x4 is offline   Reply With Quote
Old 05-18-2014, 10:27 PM   #123
atltd4x4
Did you get my PM ?
Old 05-18-2014, 11:16 PM   #124
ls1nova71
ls1nova71's Avatar
Originally Posted by atltd4x4 View Post
Did you get my PM ?
PM sent
Old 07-06-2014, 05:57 PM   #125
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
My cruise control quit working. Everything seems to be getting power and wired correctly by using a test light. 1 question, the yellow vss wire, should that have 12v power when using a test light?
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
