06-27-2014, 11:02 PM | #101 |
Re: static dropped square bodies with 15s
Here's mine 6/8 3" spindles 1.5 cut coils flip and 2 in drop shackles out back. More pics later. Ps. T56 4.10 posi
08-06-2016, 01:43 AM | #102 |
1983, 4/6, cut 2 coils, and flip out back.
12-29-2016, 01:41 PM | #103 |
12-29-2016, 06:49 PM | #104 |
Stock manifolds.
12-29-2016, 11:44 PM | #105 |
12-31-2016, 02:53 PM | #106 |
01-01-2017, 09:39 PM | #107 |
My 73 3in coils frnt flip kit rear 245-60-15 on 8in rallies
01-01-2017, 11:24 PM | #108 |
2/4 drop (springs and shackles) w/ 275/60/15 all around. I think I need to put OG springs back on and get 3" spindles.
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532 |
01-02-2017, 12:18 AM | #109 |
Post Whore
Good lookin truck Ben.
01-02-2017, 10:14 PM | #110 |
Thanks!
01-03-2017, 08:13 AM | #111 |
Flip kit in the rear. 3" spindles and 1" coils in the front. All belltech.
15 x7 factory alloys with 235/75/15s. The front needs to come down some more. |
01-05-2017, 07:08 PM | #112 |
back when it was still ridin high. i think this was at the time a 2/4 drop ? its been a while.
instagram - @custom.chevy |
01-05-2017, 07:12 PM | #113 |
currently a work in progress. not on 15s but its still static dropped. figure its about 4 to 5 in the front and a flip kit with shackle in the rear with some springs pulled out only because thats what i did in highschool and thought it was cool lol . sad . now i need to buy new springs or go coil over with 4 link. im torn. bed is currently off.
01-05-2017, 10:09 PM | #114 |
My clear coat peeling peach! Current build project. It has 2.5 spindles and 1 coil cut, and rear flip. 15x8 up front and 15x10 in the rear. Installing a 5.3/4L80E with 76mm turbo and retaining the A/C. Going to wait until all of the weight is back on the front end before deciding whether or not more cutting of the front spring will be required.
Mike
All things Chevy truck: 1986 SWB "Jolene" boosted 5.3/4l80e project |
01-05-2017, 11:25 PM | #115 |
5/7
01-06-2017, 01:01 AM | #116 |
My84
01-06-2017, 02:57 AM | #117 |
Mine is 7" lower on all four corners
01-07-2017, 02:44 PM | #118 |
1979 Big 10 Dropped on stocks, awaiting 20" Detroit steel.
The drop in case others want to know.... Western chassis 2.5" spindles and 2" coils Belltech rear flip kit, didn't use c notch yet Belltech drop shocks 4" and 6" Got 4.5" out of the front, and I think 6.25" from rear. There is about 2" between the rear axel and frame still. And truck is leveled at 26.5" to the center of each fender well. Stock 15x8 with 255/75-15 truck turns but rubs at full lock. I would not recommend 15" with drop spindles as I had to cut the balance weight off the back of the rims because new spindle steering rod mount is about 1/8" from touching the inner rim lip. |
01-08-2017, 04:15 PM | #119 |
With 15" Cragars
01-08-2017, 06:17 PM | #120 |
Diggin The SquareLife
I gotta get a set of cragars
01-08-2017, 07:20 PM | #121 |
01-08-2017, 09:22 PM | #122 |
Very nice trucks, glad to see some running around that don't have the 20's and 22's on them.
01-11-2017, 04:32 PM | #123 |
On a budget like Fred Sanford
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
01-11-2017, 09:44 PM | #124 |
SWB85, I really like the look of your 4/4 drop and may have to get 2" spindles to go along with my 2" springs!
Does anyone make a 2" spindle???
01-12-2017, 01:11 PM | #125 |
Not sure....I used 2.5" spindles and cut the factory springs
