05-29-2013, 08:09 PM | #101 |
Re: 1949-50 3100
Looking very good!
How much will you be into replacement panels when the cab is done (not including labor)? I think this is testament that almost any cab can be saved, very glad you're posting for all of us to see - thanks!
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
05-29-2013, 09:08 PM | #102 |
Hollister Road Co.
Re: 1949-50 3100
I think its under 3 k for new panels but I haven't totaled it yet.
05-30-2013, 08:17 AM | #103 |
Re: 1949-50 3100
Hey Dave. It's amazing how you are bringing that cab back. Wondering if I can pick your head a bit. I have a 51 that needs floor, kick panel, lower hinge pocket and cab corner repairs. I'm wondering how I should start going about this. The box is off, cab still bolted to frame, seat and gas tank removed and the doors are still on. What do you think is the first or smartest thing to start first? I'm worried about the cab getting out of square during repairs. I could brace the inside but that would make things hard to work around them. Should I maybe put new cab mount bushings or mounting pads in first? Hope you have some idea's.
Thanks! |
05-30-2013, 11:00 AM | #104 |
Re: 1949-50 3100
Nice work!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
05-30-2013, 06:59 PM | #105 | |
Hollister Road Co.
Re: 1949-50 3100
You did a real nice job on that fender so I think you can do the sheet metal on your 51. |
05-30-2013, 06:59 PM | #106 |
Hollister Road Co.
Re: 1949-50 3100
05-31-2013, 03:18 PM | #107 |
Hollister Road Co.
Re: 1949-50 3100
Getting near the end of the cab work, doing the final weld up. Seams are looking good and tomorrow we fit the inner panel, finish up some odds and ends clean up some welds and send it off to the painter early next week.
05-31-2013, 05:31 PM | #108 |
Certified Car Nut
Re: 1949-50 3100
Beautiful work, thats all I have the say.
06-01-2013, 07:46 PM | #109 |
Hollister Road Co.
Re: 1949-50 3100
06-06-2013, 09:38 PM | #110 |
Hollister Road Co.
Re: 1949-50 3100
No pictures today, We have been working on the inner rear window insert. What a PIA this has been. We have managed to get it in postions but it is slow going to make it look right. Hopefully I'll have some pics tomorrow. We did decide to fill the rear seam so that will get done tomorrow as well.
06-07-2013, 06:56 PM | #111 |
Hollister Road Co.
Re: 1949-50 3100
A little more progress. Working on the upper door gaps. For some reason the front part of the door has a huge gap that needs to be closed up. I used welding rod as fill stock. tacked it and then welded up and ground down to fit the gap with the new drip edge in place. I don't want to make them too tight because when the door hinges wear a little they make shift and start rubbing. This is the beginning of the task with the rods tacked in place
06-07-2013, 09:09 PM | #112 |
Re: 1949-50 3100
Looks fantastic!~
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com |
06-08-2013, 02:14 PM | #113 |
Hollister Road Co.
Re: 1949-50 3100
06-08-2013, 02:15 PM | #114 |
Hollister Road Co.
Re: 1949-50 3100
working on door gaps today. The door is lined up with the beltline and the front gap is good so I have to jack with the top and rear gaps. The rear gap is tight on the top and wide on the bottom so we add metal to the bottom and moved the top. At the beltline it was a 1/16 which is to close and the bottom was 3/8 way to wide. We slit the top partway down and hammered it back. Tacked it in place to widen the gap. half way down we added 3/32 tig rod to the door edge and will trim to fit. These show how we added the metal and started trimming to fit.
06-08-2013, 02:25 PM | #115 |
Hollister Road Co.
Re: 1949-50 3100
Here its way to close so we slit the panel about 3/8 off the edge so it retains the metal corner we won't have to build it up with bondo that will break off later. we then tapped it back and tacked it in place. We will continue to add and move as we go down the gap so it looks straight and even.
06-10-2013, 05:33 PM | #116 |
Hollister Road Co.
Re: 1949-50 3100
Starting to get bored with all that metal work. Heres the suspension for the front. Its a Scott Danforth cross member that can use S10 82-2004, G Body 78-87 and Camaro 82-92 for some parts.
Gbody and S10 spindles, new used or dropped LCA Camaro, S10, G-Body UCA G-Body, S10 Springs Gbody, S10 or bags Rotors/Calipers G-Body, S10, Camaro, Vette big brakes with some mods. Rack or box steering. Power or manual 93-03 Camaro power rack You can fit the original engine if you want without taking it out. My reasoning for this over other types is, S10 , G-Body and Camaro parts are everywhere new and used. Tried and true parts nothing fancy and you get the right width without messing around with control arms. S10 is just about the same GVW as a 3100 so no troubles their. You can bring it to almost any front end shop for alignment. The list goes on.. |
06-17-2013, 02:14 PM | #117 |
Hollister Road Co.
Re: 1949-50 3100
We are back to fixing doors and hinges. The door bottoms were pin holed and badly pitted on the inside but fortunately only at the lower sections. We fabricated a sheet roll so we could get the slight bend that the door bottom has. Its a simple device made of angle iron and a length of pipe that works on most brakes and does the job nicely. Take an angle iron and lay it flat on a table or the floor and weld the pipe to the angle and flip it and weld the other side, its that simple. Then take the sheet you want to shape and slide it in the brake and slide the new bender roll on top of it and clamp the brake down. The gentle push up on the sheet until you get the desired shape for the door bottom. This will work on a metal or heavy wood work bench as well.
06-17-2013, 02:18 PM | #118 |
Hollister Road Co.
Re: 1949-50 3100
Back to the doors. We replaced the inner and outer lower sections. My Harbor freight $200 brake has served well or the years. Its a 20 gage brake but it has done 18 with effort. So here we have the doors we are fixing and some odd damage that also need work. We used the new roll tool for the outer bottom shaping
06-17-2013, 05:46 PM | #119 |
Re: 1949-50 3100
Have you used a Scott Dansforth crossmember before?
I did not know he was still producing these crossmembers.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
06-17-2013, 06:15 PM | #120 |
Hollister Road Co.
Re: 1949-50 3100
I have not used it before. I picked this one up locally from a guy that didn't complete his install. As far as I know Scott is still making them and has a thread over on stovebolt.com
07-12-2013, 05:30 PM | #121 |
Hollister Road Co.
Re: 1949-50 3100
Sorry but we got busy with other work and missed posting some of the work. Its one color now. Doors are on and Altman Ez latches on. Which by the way are by far the best latches going, easy install and open and close very smoothly. Its time for final body work and final fit and off to the paint shop it goes.
07-12-2013, 05:59 PM | #122 |
Re: 1949-50 3100
Cab looks real good, keeping an eye on this one!
RIP John (Lambis), my beloved Father & best Friend. My Build 56 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=486721 |
07-12-2013, 06:43 PM | #123 | |
Re: 1949-50 3100
av8tr33337 AKA Bartman Email av8tr33337@yahoo.com Bartman's Ad-S10 Chassis Swap http://67-72chevytrucks.com/vboard/s...d.php?t=415418 My First Youtube Video http://www.youtube.com/watch?v=B6hSt...eature=channel More Pics of the 51 Project http://s668.photobucket.com/albums/v...hassis%20Swap/ 1951 3100 Pickup |
07-12-2013, 07:19 PM | #124 |
Re: 1949-50 3100
That looks fantastic!! What color will it wind up being?
07-12-2013, 07:46 PM | #125 |
Certified Car Nut
Re: 1949-50 3100
Really top-notch work going on here.
