Old 07-25-2014, 02:27 AM   #101
marvgarr68
marvgarr68's Avatar
Re: 68 c10 6.5 turbo diesel
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 08-02-2014, 11:24 PM   #102
marvgarr68
marvgarr68's Avatar
Got most of the motor together. Will install rockers and push rods tomarrow. I installed the 1/2 inch aluminum hard line to the fuel pump. Installed the new poly engine mounts. I will be putting it in truck here soon so stay tuned.
Old 08-02-2014, 11:27 PM   #103
marvgarr68
marvgarr68's Avatar
Here are the pics of the fuel line.
Old 08-02-2014, 11:28 PM   #104
marvgarr68
marvgarr68's Avatar
Here are some more pics.
Old 08-03-2014, 12:47 AM   #105
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work. I don't miss working on the electronic 6.5s for sure. The wiring seemed to be crap on those trucks.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-03-2014, 01:14 AM   #106
marvgarr68
marvgarr68's Avatar
That is for sure the way they run the harness is stupid no wonder they always had problems. I hope the way I did my harness I won't have problems.
Old 08-03-2014, 11:28 PM   #107
jbclassix
Junk Yartist
jbclassix's Avatar
what fitting did you use to run the 1/2" line to the injection pump? I am guessing you had to drill out the adapter thingy?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 08-04-2014, 12:32 AM   #108
marvgarr68
marvgarr68's Avatar
The fitting is a 7/16-20 X 3/4-16 hydraulic 90 deg fitting. I also drilled out the fitting on the 7/16 side for more flow. I know for sure I have no flow issues to the pump at least to the fitting.
Old 08-09-2014, 06:36 PM   #109
marvgarr68
marvgarr68's Avatar
I got the motor in the truck finally. I finished the ECM wiring and checked and double checked it for proper routing. I mounted the acc brackets the alt and ps pump. The trans is in temp to have the engine in the right spot for wiring and the other stuff needing done. I was going to use elec cooling fans but I think a BB fan shroud will work. I am going to by one from member teeitup. I still need to finish the clutch linkage. Here are some pics.
Old 08-09-2014, 06:40 PM   #110
marvgarr68
marvgarr68's Avatar
Here are some more pics. I'm still waiting for the other valve cover to be powder coated wrinkle black. The turbo and manifold are also on there temp to get an idea on intercooler piping.
Old 08-10-2014, 12:10 PM   #111
68post
Looking great , I'm envious.
I miss my old 6.5 na G20 van and my 3500HD turbo 6.5. I still have a military 6.2 that was rebuilt but let sit. New pistons in the box, rings, & gasket set all waiting.
My trucks are all geared too low for a diesel ,and no overdrive either.
Keep up the great work !
68post is offline   Reply With Quote
Old 08-10-2014, 01:58 PM   #112
marvgarr68
marvgarr68's Avatar
Thanks. Just swap in an overdrive trans. I'm sure the mpg increase would pay for that. You can put just about anything behind a na 6.2 even a 700r4.
Old 08-11-2014, 12:15 AM   #113
68post
The G20 van is sitting with a blown-up 6.5 na and a 4L60 that needs rebuilt. I'd be able to tow anything with my 4.10 gears and the 4L60, but it would be in od by 40 mph.
Approx. 2,200 rpm in od with my tire height @ 70 mph.
And you're right, it should average about 16 to 19 mpg !
Old 08-11-2014, 12:28 AM   #114
jbclassix
Junk Yartist
jbclassix's Avatar
Wow! That is officially the first time I have liked one of the 6.5L turbo power beauty covers! That is one sharp looking engine.
-Jeremy
Rebuilding an NP205
Old 08-11-2014, 02:22 AM   #115
marvgarr68
marvgarr68's Avatar
I know what you mean. I wasn't going to use one but thought it would clean it up a little. It is hard as can be to find one of these covers everyone throws them away. This one is for the mech IP but can't find one for the elect IP. They are an ugly looking gray. Thanks for the kind words it does look good hope it runs as good as it looks.
Old 08-11-2014, 02:25 AM   #116
marvgarr68
marvgarr68's Avatar
70 is good for towing 65 is better. I don't like towing fast. You never know what idiot will pull in front and slam on the brakes. 16 to 19 mpg in a 4.10 truck is great.
Old 08-11-2014, 08:46 AM   #117
jbclassix
Junk Yartist
jbclassix's Avatar
I may have the OBD II style laying around somewhere. You could have that if you want it. But I think you're right the 94-95 would look better.
-Jeremy
Rebuilding an NP205
Old 08-11-2014, 03:05 PM   #118
marvgarr68
marvgarr68's Avatar
Yea I will keep my eye out for one. I never liked the newer style covers thanks though. I will find one until then this one will do. You are right the 94-95 would look the best.
Old 08-11-2014, 03:22 PM   #119
Lemield
Lemield's Avatar
Looking really good! You do nice work my friend.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 08-11-2014, 03:43 PM   #120
marvgarr68
marvgarr68's Avatar
Thanks for the kind words.
Old 08-11-2014, 08:25 PM   #121
Dieselwrencher
It looks really nice. It should make for a beast of a 6.5 too.
Ryan
Old 08-11-2014, 09:07 PM   #122
marvgarr68
marvgarr68's Avatar
Thanks.
Old 08-12-2014, 02:06 PM   #123
marvgarr68
marvgarr68's Avatar
Here are some pics of the clutch linkage. I made the bracket on the engine side and the frame side. The bracket is mounted to the bell housing. The bell housing is a 56 Belair.
Old 08-12-2014, 02:08 PM   #124
marvgarr68
marvgarr68's Avatar
Here are some more I still have to paint it.
Old 08-17-2014, 01:43 PM   #125
marvgarr68
marvgarr68's Avatar
I got the main pos cable routed. I routed it over the trans clamped it to the flange the runs over the trans. I got the clutch linkage done. I mounted and wired the baro sensor. I then finished the wiring on the engine I hooked it up to the factory harness in the valley of the engine. I also wired up the glow plug relay and the water sensor in the filter housing.
