Old 05-03-2015, 08:58 PM   #101
Hankster
Hankster's Avatar
Re: Used Parts Build
Yes you took some pictures of nice cars. Also, That four link looks bad-a**
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 05-16-2015, 11:47 PM   #102
tinydb84
tinydb84's Avatar
Thanks Hankster. I was impressed by a lot of the cars.
David
Instagram: myfabguy
Old 05-16-2015, 11:48 PM   #103
tinydb84
tinydb84's Avatar
Second bodywork class is finished. Had some pretty cool stuff going on during the last one:
One guy is changing his 55(?) chevy over to a modern chassis
Porblem was that the Corvette IRS was too narrow so he couldnt get it done in class
Slow progress on my truck though
David
Instagram: myfabguy
Old 06-14-2015, 11:37 PM   #104
tinydb84
tinydb84's Avatar
Changed my one of my guns up a bit last night (just in case anyone is a gun fan):
New barrel, rail, and compensator. Anyway back to the truck!
This saw works pretty good cutting sheet metal as long as they are straight cuts
Pulled my heater/AC box and started welding up holes:
Little trick that I learned in bodyshop. The tape doesnt mess with the arch like the magnets do and it works pretty well
Tack, tack, tack
Gone!
Primered over all the holes I filled. Only like 20 more to go....
David
Instagram: myfabguy
Old 06-21-2015, 12:34 AM   #105
tinydb84
tinydb84's Avatar
More patch work. This **** is time consuming...
I cut the edges off the wholes as I wanted everything flat.
Used a piece of thin masking paper and a pencil held sideways to get the outline then traced it on to my sheet metal.
Pretty tight fit except for the bottom left:
Tack after tack after tack:
Done:
I am debating on how nice I want this to look (aka how lazy I am going to be) since it is will hidden behind the inner fender. I dont feel like buying a stud welder to do my hammer and dolly work.
David
Instagram: myfabguy
Old 06-24-2015, 01:05 AM   #106
tinydb84
tinydb84's Avatar
This is how I should have done it!
Just kidding. I dont have anyone helping me so I tacked the sheet to the firewall and drew the outline from the inside.
When I cut away the flange the metal bowed inward a bit. I ended up having to use some clamps to get everything in place:
Started tacking
I finished all the tacks tonight but it was too dark to get a decent picture. I have about 5 more holes to fill on the passenger side. I am going out of town for a few days though so it wont likely happen until next week.
David
Instagram: myfabguy
Old 07-02-2015, 02:10 AM   #107
tinydb84
tinydb84's Avatar
Finally got the holes filled:
Primed it for now:
I decided that painting it black in really bad lighting was a smart thing to do...
David
Instagram: myfabguy
Old 07-03-2015, 02:43 PM   #108
tinydb84
tinydb84's Avatar
Started stripping down my engine to mock it up:
Pretty clean on the inside:
Got this bracket off an LS group on facebook
David
Instagram: myfabguy
Old 07-03-2015, 11:37 PM   #109
tinydb84
tinydb84's Avatar
Got some more done today:
Engine is temporarily in
I have the dirty dingo mounts. Everything fits fine but the driver side manifold when flipped (for the future turbo). The brake booster is close but will clear if I run the manifolds normally.
But I have a ton of space under the engine.
I have an inch down without changing anything (Id have to make new motor mounts).
If I section a chunk out of the crossmember like this:
I will have another 2 inches I can go down.
Its hard to see but with the stock truck pan I am even with the crossmember. I have an Fbody pan which is around 3 inches shorter.
The problem is that I dont know if I can lower the trans 3 inches without it hanging below the frame rails due to my sfbd. My uncle stopped by and told me to leave it high and when I replace the brakes get a smaller booster which will clear the manifold.
I really want to keep making forward progress but I also want to lower the engine....
What would you all do?
David
Instagram: myfabguy
Old 07-05-2015, 02:55 AM   #110
tinydb84
tinydb84's Avatar
Am I missing a bolt hole??
David
Instagram: myfabguy
Old 07-05-2015, 02:59 AM   #111
tinydb84
tinydb84's Avatar
Anyway, I decided to lower the engine a bit:
I stole project goldilocks idea. I didnt take a pic but I was able to drop the engine and trans in and clear the tunnel with the space made by notching the crossmember. Problem was that the oil pan and trans were to low by about 2 inches. So I am going to cut the tunnel and raise it to clear. I figured I would but its nice to know I wont have to raise it 4 inches.
David
Instagram: myfabguy
Old 07-05-2015, 03:04 AM   #112
tinydb84
tinydb84's Avatar
I pulled the engine back out and started to weld up the crossmember. I had to make a filler piece because of the way the crossmember was shaped in the back.
Started to burn it all in
I'll make the side filler pieces tomorrow. It took forever to move the engine/trans in and out on my own. I will have to fab up some motor mounts but want to cut the tunnel out first to mock the engine up first.
David
Instagram: myfabguy
Old 07-05-2015, 10:19 AM   #113
old yelr
Nope, all gen IV and up are like that.
old yelr is offline   Reply With Quote
Old 07-05-2015, 07:50 PM   #114
tinydb84
tinydb84's Avatar
THanks old yelr. I never noticed that.
David
Instagram: myfabguy
Old 07-05-2015, 09:01 PM   #115
old yelr
You're welcome. Actually all the LS based engines are like that, gen III and IV.
Old 07-06-2015, 01:59 PM   #116
chevytrucksforme
Crossmember is looking really good. Great work!!
chevytrucksforme is offline   Reply With Quote
Old 07-08-2015, 01:25 AM   #117
tinydb84
tinydb84's Avatar
Thanks Chevy
David
Instagram: myfabguy
Old 07-08-2015, 01:26 AM   #118
tinydb84
tinydb84's Avatar
Finished up the crossmember in the dark tonight
David
Instagram: myfabguy
Old 07-12-2015, 10:57 PM   #119
tinydb84
tinydb84's Avatar
Did some more mocking up on my engine and trans. Ordered some 4 inch poly bushings but they wont be here until tomorrow. Some of the pics are for me to keep track.
Those pics were before I cut the trans tunnel out. Then I cut the tunnel out and mocked everything up.
This is where I am going to put the new mounts.
Nice tight clearance between the pan and crossmember.
Plenty of clearance with the trans
Didnt have enough hands to hold and take pics of the oil pan but it will clear the ground with almost an inch to spare.
David
Instagram: myfabguy
Old 07-15-2015, 02:31 AM   #120
tinydb84
tinydb84's Avatar
Didnt get much done. Starting mocking up the motor mounts then tried to install the poly bushings to measure and ripped the tacks off the mount. Then pulled the bushings to measure and retack everything.
Here is my ghetto jig!
Drew out my mounts. Maybe Thursday will go better....
David
Instagram: myfabguy
Old 07-17-2015, 03:01 AM   #121
tinydb84
tinydb84's Avatar
I need a plasma cutter. I spent way too much time cutting and grinding this crap:
After I weld them in I am going to weld on a tab and make a bolt on piece to support the frame similar to how the original towers did.
David
Instagram: myfabguy
Old 07-18-2015, 11:31 PM   #122
tinydb84
tinydb84's Avatar
David
Instagram: myfabguy
Old 07-18-2015, 11:33 PM   #123
tinydb84
tinydb84's Avatar
Those inverted welds suck! I was going to tack it all together and pull it off the crossmember to weld it up on a table but I want to get more experience welding.
I'm going to weld a tab to the side and build a bolt in plate to mimics the original towers next.
David
Instagram: myfabguy
Old 07-20-2015, 01:47 PM   #124
mattcrp1
mattcrp1's Avatar
Nice fab work.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 07-22-2015, 01:38 AM   #125
tinydb84
tinydb84's Avatar
Originally Posted by mattcrp1 View Post
Nice fab work.
Thanks Matt.
Got the engine and trans in. It went in so easily that I am still worried a missed something...
Going to push the engine back a hair to clear the center link. Once that is done I am going to make the trans crossmember. I have a poly mount that I can use 1 or 2 bolts on it. The stock mount had one bolt. Any benefit using two bolts?
David
Instagram: myfabguy
