Old 04-02-2017, 12:13 PM   #101
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: New 64 Stepper Project
I should have put this hear but forgot - After seeing 64shortbox’s brake pedal I had to give it a go. I received a Camaro pedal arm and cut the pedal off at the back of the pedal from the arm.
Cut the stock pedal off the stock arm and prepped everything to weld out.
Now I just have to find a local welder.
I may have it tacked on the truck to make sure it's straight though.
Old 05-24-2017, 05:58 PM   #102
The Rocknrod
Moderator
So I pretty much smoothed the firewall of mounting holes and will be using these weld mount studs to mount the AC unit, Fuse Block etc inside.
Old 05-24-2017, 06:00 PM   #103
The Rocknrod
Moderator
Went over to The Truck Shop in Orange and got a few things, firewall grommets etc. Oh and to Mooneyes for the fuel gauge and Swagelok for the fuel line fitting.
Old 05-24-2017, 06:19 PM   #104
The Rocknrod
Moderator
Okay I got some p ics from the painter this afternoon. I will be back in Texas Sunday night so I wont be able to see the work till Tuesday.
Old 05-24-2017, 06:21 PM   #105
The Rocknrod
Moderator
The last ones so far, more next week.
Old 05-24-2017, 07:39 PM   #106
schpeen
schpeen's Avatar
shaaaaaawingggggg!
1991 K5 Blazer 4x4 "9 ball"
2019 Chevy Silverado Trail Boss 4x4
2018 Chevy Colorado 2 door ZR2 4x4
1988 23' Mako Marine
2005 Harley Davidson Road King
schpeen is offline   Reply With Quote
Old 05-25-2017, 04:19 PM   #107
The Rocknrod
Moderator
Also picked up a wiring harness and fuse panel, all the stuff to make a relay panel like the one shown below and a main power ground buss for inside the cab.
Old 05-31-2017, 12:37 PM   #108
The Rocknrod
Moderator
Yep, not much change since the last pics at the paint shop. But I did clean up my shop after having been gone so long there were many bugs - crickets. So I vacuumed every inch of the shop - piles of them. Even a big ol black and yellow centipede (found dead), I guess the bug guy works. Momma found a bark scorpion in the house and freaked.
Old 06-03-2017, 06:26 AM   #109
The Rocknrod
Moderator
Not going to be too active for a bit as I'm without a job for a while so I'm kind of looking at other venues - "We keep you alive to serve this ship. Row well, and live"
Old 06-04-2017, 12:33 AM   #110
Captainfab
60-66 Nut
Sorry to hear that. I hope the job search goes well and quick for you.
Old 06-04-2017, 12:39 AM   #111
Prflyer1
Prflyer1's Avatar
This are the builds that make me want to go out and start sanding the patina of my truck and get it painted! lol looks great, love that red/beige or cream combination
1966 Chevy C10 Not named yet, help!
1984 GMC 4x4 SB "The Hunter"
My 66 C10 fun build: http://67-72chevytrucks.com/vboard/s...d.php?t=738705
Prflyer1 is offline   Reply With Quote
Old 06-05-2017, 09:33 AM   #112
The Rocknrod
Moderator
Me too Captainfab - Thanks.
Thank you for the encouragement.
Old 06-19-2017, 01:49 PM   #113
The Rocknrod
Moderator
Well their cut and buffing a bit on it.
Old 06-21-2017, 01:41 PM   #114
The Rocknrod
Moderator
Found the owner hittin it, step one buffing compound (there are 3 steps).
Old 07-08-2017, 08:20 AM   #115
The Rocknrod
Moderator
Picture of my rear disc brake kit.
Old 07-28-2017, 06:09 PM   #116
The Rocknrod
Moderator
Just stopped in at the paint shop and they put the rear fenders on.
Old 07-31-2017, 06:26 PM   #117
The Rocknrod
Moderator
Other side, front is dusty.
Old 08-01-2017, 05:55 PM   #118
The Rocknrod
Moderator
Hard to believe its been that long - http://67-72chevytrucks.com/vboard/s...4&postcount=46
What about 24 work days to go as of 16 Aug 17.
Old 08-08-2017, 01:56 PM   #119
The Rocknrod
Moderator
Steps put on.
Old 08-18-2017, 11:27 PM   #120
64shortbox
64shortbox's Avatar
Wow!! Just checked out your build for the first time! Great Job! I'm jealous! I see in your earlier post you're going to build a relay and fuse board to go along with your new wiring harness & fuse block. I plan on doing the same but I recently found these fused 4 pin relays. It puts the fuses & relays in one neat package. I just ordered some off ebay but they haven't arrived yet. Check out the link and let me know what you think:
http://www.ebay.com/itm/Lot5-12V-30A....c100012.m1985
64shortbox is offline   Reply With Quote
Old 08-18-2017, 11:33 PM   #121
pimpston65
pimpston65's Avatar
Steps put on.
oh baby, she's a looker!!!
pimpston65 is offline   Reply With Quote
Old 08-19-2017, 05:18 AM   #122
The Rocknrod
Moderator
Originally Posted by 64shortbox View Post
Wow!! Just checked out your build for the first time! Great Job! ...
Those relays are way cool making it easier to fuse a relay system. Good find on that.
I was recently looking at this due to the size and all, http://www.ebay.com/itm/Fuse-Box-6-R....c100005.m1851 You can cut down on the footprint of the fuse panel.
With the fused relays you could even buy a small fuse block like that without the relays in it and use those fuses.
Old 08-19-2017, 05:19 AM   #123
The Rocknrod
Moderator
Thanks buddy, I'm hoping she will be once the smoke is cleared. Still looking for a job though.
Old 08-19-2017, 08:11 AM   #124
northern 85
northern 85's Avatar
Yep nice looking truck!
northern 85 is offline   Reply With Quote
Old 08-21-2017, 03:05 PM   #125
The Rocknrod
Moderator
Thank you northern85. I also did some brake pedal work as shown here:
http://67-72chevytrucks.com/vboard/s...&postcount=179
