Old 07-14-2019, 12:35 AM   #101
jmking9
jmking9's Avatar
Re: 1967 Chevelle
I wanted to be able to remove the shifter without removing the trans from the car. To accomplish this, I cut the hole big enough to get it out and built a removable cover. There are four nuts welded to the underside of the tunnel that ar used to attach the cover. The welded in nuts, along with short pan head bolts, makes for very little intrusion into the tunnel.
Since this style of transmission was in Mustangs for several years, I figured the best place to find a shifter seal would be in the Mustang world. And I just happened to be right. This one is for fox bodys and worked really well for my application. All I had to do was grind the lip of of it so that I could form it to fit my tunnel.
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 07-14-2019, 12:43 AM   #102
jmking9
jmking9's Avatar
Re: 1967 Chevelle
With all of the fab work done, I pulled the engine and transmission back out of the car for final welding. Once the welding was finished, I sprayed some etching primer on all of it and seam sealed everything. Next up will be shooting the Lizard skin sound/heat insulation on the new tunnel and floor. Here's a few pictures as it sits now.
1970 SWB Build
Old 07-14-2019, 12:56 AM   #103
mongocanfly
Post Whore
mongocanfly's Avatar
Re: 1967 Chevelle
("bent it around an electrical pole to get the basic shape I needed")
been there done that....looks good
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-14-2019, 02:10 AM   #104
jmking9
jmking9's Avatar
Re: 1967 Chevelle
Yeah, sometimes it's doing that kind of stuff that brings me the most joy when working on these cars
1970 SWB Build
Old 08-06-2020, 10:47 PM   #105
jmking9
jmking9's Avatar
Re: 1967 Chevelle
I need to catch this thread up to date. I finished the transmission tunnel
1970 SWB Build
Old 08-06-2020, 11:04 PM   #106
jmking9
jmking9's Avatar
Re: 1967 Chevelle
I got the wiring harness about 95% installed. I just a have a few terminations to make once the engine is sitting in the car. I finished my 3 knob Vintage Air controller piece that uses a modified stock Chevelle heat/air bracket. I modifed the original automatic console to work with the manual transmission. It sounds much simpler than it turned out being. I went through a couple different shift boots looking for something that fit the opening well, and looked like it could have been original. The winner ended up being for a 1970 Mopar B-body. The clock was also removed and the console was made to house the 2 3/4" tach. My goal for all of these little things was for them to blend in with the rest of the mostly stock appearance of the car.
1970 SWB Build
Old 08-06-2020, 11:26 PM   #107
jmking9
jmking9's Avatar
Re: 1967 Chevelle
After several months of waiting, my engine was finally wrapped up and tuned on the dyno. It's a 467c.i. bbc built by Mark Jones (aka Vortecpro) in Colorado Springs. Forged internals, ported heads, roller valvetrain, and a fairly mild 9.6:1 compression. With my Holley 770 Ultra Avenger carb, it made around 590hp and 600ft/lbs. With his 850 xp carb, it made around 605hp. Mark is well known in the Chevelle world for building big blocks that are easy to live with on the street, but make serious power. I'm excited to get it in the car and have some fun.
I mocked up the front accessories using brackets from Alan Grove Components. I'm really happy with the way they fit, and allow you to use off the parts store shelf accessories, and look relatively stock. Now I just need to take it all apart and paint the pieces.
1970 SWB Build
Old 08-06-2020, 11:34 PM   #108
jmking9
jmking9's Avatar
Re: 1967 Chevelle
Checking runout on the flywheel, and dial indicating the bellhousing. The runout was basically nothing with less than .001. The bellhousing is just outside of tolerance at .007 out of center. I ordered some offset dowell pins that will take care of that.
1970 SWB Build
Old 08-13-2020, 08:04 PM   #109
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 1967 Chevelle
Very nice work! That 467 should be very, very fun! I put vintage air in my 71 Camaro and I have to say it was worth it. Now I need to get a few more kits to put in other rides. Where's that money tree again?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 09-15-2020, 05:11 PM   #110
jmking9
jmking9's Avatar
Re: 1967 Chevelle
So the engine is in, and the car is running. I've put about 5 or 6 miles on it with open headers. It feels like it's going to be a lot of fun to drive. I have to take it to the muffler shop in a couple days for exhaust.
Several things left to do, but its getting closer.
1970 SWB Build
Old 09-15-2020, 05:40 PM   #111
mongocanfly
Post Whore
Re: 1967 Chevelle
Sure does look good..!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-16-2020, 12:22 PM   #112
67C10Step
67C10Step's Avatar
Re: 1967 Chevelle
Super, super nice!
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 09-16-2020, 07:05 PM   #113
72c20customcamper
72c20customcamper's Avatar
Re: 1967 Chevelle
I'm on my second MJ motor in my 66 Chevelle SS First one grenaded and he replaced under warranty. This one now has some major issues not even 3 hours on the motor . Looks like the roller cam is toast having it redone locally. I'm sure he would redo the current motor under warranty but I cant wait a year to get it done and pay 300 frieght each way to fix it .
My thread on the start of the 496 . Now it sounds like a diesel running
https://67-72chevytrucks.com/vboard/...d.php?t=809609
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 09-18-2020, 11:21 PM   #114
jmking9
jmking9's Avatar
Re: 1967 Chevelle
Originally Posted by 67C10Step View Post
Super, super nice!
Thank you!
Well that's super comforting But seriously, I'm sorry to hear that.
As im sure you know, Mark comes VERY highly recommended by a ton of people on the team chevelle forum. But FWIW, I was less than impressed with the customer service aspect of his business. But, I put up with it because I had my heart set on one of his engines. Hopefully I have a positive experience. Time will tell.
When you say grenaded, what went wrong? And, do you know what caused the problem with you roller cam?
1970 SWB Build
Old 11-10-2021, 10:56 PM   #115
jmking9
jmking9's Avatar
Re: 1967 Chevelle
I guess I should finish this thread off with a few pictures of the finished product. I've put a couple thousand miles on the car now, and it's a blast. It turns out 600 hp and a manual trans is fun.
1970 SWB Build
Old 11-10-2021, 11:02 PM   #116
jmking9
jmking9's Avatar
Re: 1967 Chevelle
Interior
1970 SWB Build
Old 11-11-2021, 02:46 PM   #117
Dieselwrencher
Re: 1967 Chevelle
It turned out awesome! I tried trading for a rough 67 this summer but someone offered the guy more than I wanted to give up so no 67 Chevelle for me.
Ryan
Old 11-12-2021, 09:58 AM   #118
72c20customcamper
Re: 1967 Chevelle
Originally Posted by jmking9 View Post
Thank you!
Sorry I didnt reply sooner the first one number 8 piston self destructed . No evidence of it hitting a valve and or detonation . Damaged the block beyond repair. Like I said he did replace it under warranty but waited almost a year for the replacement .
It wasnt the cam that went south it was the rocker poly locks they cracked and were backing off had three that were cracked. Cheap Chinese parts but Mark is sending me a complete new set of USA made Scorpion rockers but hes moving his shop to Texas so everything is on hold .
Your Chevelle is coming out great
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-12-2021, 06:31 PM   #119
jmking9
jmking9's Avatar
Re: 1967 Chevelle
Man I hate that for you. I kind of hand picked all the parts I wanted to use on mine, and drop shipped them to him. I stuck with a couple of his recommendations like the Isky cam, and Scorpion rockers. So as long as he used the actual internals I sent, I shouldn't have any lower quality parts in mine. I hope it works out for you.
What part of Texas is he moving to? I know he was sure down on the state of Colorado when I picked mine up.
1970 SWB Build
Old 11-13-2021, 07:16 AM   #120
Dieselwrencher
Re: 1967 Chevelle
jmking9 I bet that thing is a blast to drive! Thanks for the tip on the shifter boot from the fox body. I'm going to order one and add it to my 71 Camaro this winter.
Ryan
Old 11-13-2021, 04:12 PM   #121
72c20customcamper
Re: 1967 Chevelle
Not sure of where but I talked with him a few times about a month ago . He is extremely upset with the parts malfunction . Everything else is perfect he sent me the parts list I get the feeling the supplier gave him a few sets of these rockers/poly locks to try he's contacted the others built with them and replacing them too. Engine Pro brand I've never heard of them
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-24-2022, 08:57 AM   #122
7dee2
7dee2's Avatar
Re: 1967 Chevelle
Had to say your car really turned out great! How are you enjoying that Mark Jones motor?
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 03-02-2022, 05:10 PM   #123
jmking9
jmking9's Avatar
Re: 1967 Chevelle
Love it so far!
1970 SWB Build
Old 03-03-2022, 10:58 AM   #124
7dee2
7dee2's Avatar
Re: 1967 Chevelle
Good for you, he's known for some great engines.
Brett
