01-22-2015, 08:41 AM | #1226 |
Re: Donz '65 SWB Stepper Budget Build...
Long Story short… I was riding in a pack of about 80 bikes, fortunately I was in the very last of the pack... We were on I-65 in N. Central Alabama doing about 70mph when I heard, and felt, a loud Hammering noise... I immediately grasped the clutch lever and switched off the ignition as I, followed by our chase vehicle, slowed to a safe stop on the shoulder. A tentative push on the kick starter confirmed the engine wouldn't spin. We loaded my disabled bike and made our way to our destination. Later, we returned to our starting point and unloaded. A few days later I pulled the top end apart and noticed the Valves had kissed the rear piston... The end result… The shop that rebuilt my motor prior to this event used copious amounts of gasket sealer which ended up plugging the main crankpin oiling port… The rear rod came out egg shaped with a piece lodged in the bottom of the piston… This all happened in '94, Bret's post of his engine that blew a rod out the oil pan, prompted me to post a pic of my trophy on his thread first…
Here's a pic of my former ride… the grey bike in the foreground, pic taken in front of my studio in Montgomery Alabama...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD Last edited by Ta2Don; 01-22-2015 at 09:29 AM. Reason: spelling |
01-22-2015, 08:47 AM | #1227 | |
double wow on the piston. i've spun a few bearings and had a rod knock or two but i've never launched a piston. probably because i drive like a grandma. rather cruise than abuse... |
01-22-2015, 09:34 AM | #1228 | ||
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD Last edited by Ta2Don; 01-22-2015 at 09:35 AM. Reason: spelling |
01-22-2015, 05:47 PM | #1229 |
Changing of the Guard at Windsor Castle
There you go Don, just for you and the other Monarchy lovers. It was the first time I saw it and enjoyed it thoroughly.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
01-25-2015, 07:30 PM | #1230 |
Thanks for the video Rian.. Pretty Neat to see, will chat soon...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD Last edited by Ta2Don; 01-25-2015 at 08:00 PM. Reason: add on |
01-25-2015, 07:56 PM | #1231 |
A bit more work done today... in and amongst keeping Mrs. Boss happy with some HoneyDoos thrown in the mix!
Started out preparing to dismantle old unused dog pen, no pics… trimming trees and removing a small stand of briars that had invaded a small portion of the fence line... Then time to Pressure Wash the frame to remove the crud build-up… Untitled by ta2don, on Flickr Untitled by ta2don, on Flickr Untitled by ta2don, on Flickr Next, with the help of future Son-in-law, we Dis-assembled a hand built dog house and shade structure… Following that, I made my way over to my neighbors to collect a free gas pedal and throttle cable from a square body cab... Free is ALWAYS good!!! Untitled by ta2don, on Flickr Untitled by ta2don, on Flickr Set the now dry frame upside down and located the rear-crossmember for the Chevy trailing arm set-up and marked and drilled the bottom 3 holes per side... Untitled by ta2don, on Flickr Untitled by ta2don, on Flickr Untitled by ta2don, on Flickr I bought this DeWalt Drill bit set (1/16" - 1/2") and it is sure nice to have sharp bits, made quick work of the holes... Second pic is of one of the bits and a spiraled piece of 50 year old frame... Untitled by ta2don, on Flickr Untitled by ta2don, on Flickr Two more days off with great weather forecast... so the plan is to get the rear crossmember cleaned and painted, Clean and Paint the frame, and get the crossmember and Track bar mount bolted on….then the to Rear-end swap will be almost complete... That's all for now Guyz and Gals...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
01-25-2015, 09:55 PM | #1232 |
Nice to see truck time full on.
01-25-2015, 10:25 PM | #1233 |
Just a Heads up my friend… I'm bringing my points to the August meet….Obsolete or not...
01-25-2015, 10:49 PM | #1234 |
Nice progress my friend!!!!
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
01-26-2015, 03:41 AM | #1235 |
No wonder you were so quiet.
Great progress Don. More than I got done.
01-26-2015, 11:17 PM | #1236 |
Finally finished dismantling an unused dog pen… Honey-dos outta the way, I rode into town to pick up some grade 8 hardware to use on re-assembly of the frame...
Upon returning I began cleaning the bottom side of the rear end and was able to get some paint brushed on… I'm using Eastwood's Rust Encapsulator… after cleaning the frame with a wire brush on a drill, I painted the rear of the frame... On to the pics… Untitled by ta2don, on Flickr Untitled by ta2don, on Flickr Untitled by ta2don, on Flickr
01-27-2015, 02:01 AM | #1237 |
Looking good Don
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=611614 |
01-27-2015, 07:15 AM | #1238 |
making good progress Don... looks great.
we got a week of nice weather coming, maybe. |
01-27-2015, 10:06 AM | #1239 |
Thanks Guyz!!!
Gotta get after the rest of the frame now... I was curious to see how the paint did with the temp around 60F… Checked it this morning and all is well... As long as the Sun shines as forecasted, and the mercury rises again today I plan to at least get the remainder of the bottom, sides, and crossmembers in paint... Gotta clean and paint the remaining crossmember and track bar mount as well… Another step closer to re-assembly...
01-27-2015, 10:30 AM | #1240 |
Should be a sweet build when done!
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
01-27-2015, 08:51 PM | #1241 |
I sure hope so...
01-27-2015, 09:02 PM | #1242 |
Another Warm Sunny day in the middle of winter… High of 62F or 16C for my mates in the UK...
Untitled by ta2don, on Flickr Started the day hanging a tire swing for my Granddaughter's 9th Birthday… then off to the shed to continue with the frame swap saga... Untitled by ta2don, on Flickr Finished cleaning and painting the Frame, Rear Crossmember, and Track Bar Mount… then bolted the crossmember and mount on with Grade 8 hardware and Loctite…. Here's the bottom side all done… Untitled by ta2don, on Flickr Topside… Untitled by ta2don, on Flickr Track Bar mount… Untitled by ta2don, on Flickr Crossmember… Untitled by ta2don, on Flickr Completed Frame ready for Suspension... Untitled by ta2don, on Flickr
01-27-2015, 09:16 PM | #1243 |
Looking Good Don! You are trucking along. We are having the same weather here in Central Texas although a little bit warmer. High of 74 today and tomorrow maybe a record near 80!
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
01-27-2015, 10:10 PM | #1244 |
Looking great brotha!!! Now ya just need some clear coat! lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
01-28-2015, 10:51 AM | #1245 |
Don you have been a busy man. Your frame looks great. can't wait to see picture of it sittin in front of your tattoo shop.
1965 c-10 swb 1997 c-1500 extended cab 2004 tahoe 1993 mustang gt BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653 |
01-28-2015, 11:19 PM | #1246 |
Thanks Guyz!!!
Upcoming weekend colder and wetter, so I will concentrate on Cleaning and Prepping the Rear-End and Trailing Arms for paint and re-assembly...
01-29-2015, 11:02 AM | #1247 |
Lots of progress!!!!!! Looking good.
01-29-2015, 11:33 AM | #1248 |
Looks great! Keep on truckin' Don!
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
02-01-2015, 08:18 PM | #1249 |
Thanks Guyz!!!
Wet Nasty day today, so when the wife and dog started watching the Puppy Bowl, I made my way to the shed and built a couple of custom tattoo machine foot switches… One of my fellow artists, wanted the Rat Trap one and showed me a pic of a Wrench one, so… Here's the one I fashioned for me… Nevermind the bird poop welding... Untitled by ta2don, on Flickr Rear View of the Electrical hookups… Untitled by ta2don, on Flickr …and a few pics of the Rat Trap one for my friend Klown… Here's the artwork… Untitled by ta2don, on Flickr Finished product… Untitled by ta2don, on Flickr Now it's time to watch the Super Bowl...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD Last edited by Ta2Don; 02-01-2015 at 08:21 PM. Reason: redo pics |
02-03-2015, 07:58 PM | #1250 |
Another day with decent weather and a bit of progress...
This is how the rear end set-up started today… Untitled by ta2don, on Flickr In a matter of minutes I had the trailing arms separated from the rear end and ready to clean and paint… I used a wire wheel to clean the 50 year old bolts… Here is a shot of one cleaned and the other not... Untitled by ta2don, on Flickr Untitled by ta2don, on Flickr Here are the Trailing Arms, U-Bolts, and Lower Shock Mounts painted… Untitled by ta2don, on Flickr Untitled by ta2don, on Flickr Untitled by ta2don, on Flickr Here's a shot of the Trailing Arm Crossmember Mounts painted and installed… Untitled by ta2don, on Flickr The Frame and Trailing Arms now wait for me to get the Rear End Cleaned and Painted... Untitled by ta2don, on Flickr Untitled by ta2don, on Flickr …til nest time...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD Last edited by Ta2Don; 02-03-2015 at 08:00 PM. Reason: add comment |
Tags |
65 swb, c10, step side, tattoo |
