Closed Thread
Old 10-30-2014, 11:52 AM   #1276
greywurm
Re: What did you do to your truck today? Chapter II
Originally Posted by Ozzy2013 View Post
Make sure your converter didn't move spin it and make sure its all the way back .You can use some longer bolts temporary and gently pull the trans into place just make sure you don't have too much resistance .If need be take the trans mount loose and wiggle it man!ha ha good luck.
Thanks for the tip. I've read about spinning the TC when changing it out so I went ahead and did it since it did move. Set it all the way back.
One thing I haven't read is if the direction to spin it matters. I spun both directions.
71 Long bed C10 w/68 front clip, 350 SBC+HEI, TH350
06 Yukon XL Denali - Stock
greywurm is offline
Old 10-30-2014, 12:43 PM   #1277
Ozzy2013
Ozzy2013's Avatar
No doesn't matter which direction when its out totally they will drop in then you spin it around again and you will feel it drop into place one last time when the tabs lighn up.When right its about a quarter to half inch from the flywheel.Believe it or not when i was 17 we changed transmissions with a cinder block and a 8 foot long 2x6 we couldn't afford a jack !Ha ha crude but it worked.
Ozzy2013 is offline
Old 10-30-2014, 12:44 PM   #1278
Lou Boffa
Lou Boffa's Avatar
Getting my steelies powder coated. Makes me so happy!
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline
Old 10-30-2014, 12:54 PM   #1279
VWNate1
VWNate1's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
IIRC there are _three_ splines to line up in a torque converter , most of the time one slips right in and you have to invert the tranny and hand spin the T.C. back and forth until you hear / feel it click and drop twice more .
It'll be close to the inside of the bell housing when it's right , at least 1/4" between the flex plate and the T.C. when you offer up the tranny ~ never , EVER force it ! therein lies madness and an empty wallet .
I just got another 'phone call from The paint Jail ~ it seems he's hot to trot on painting my truck now and really wants me to come get my driveline , he says no problems painting the bottom of the cab green to match and suit me , they guy who's paying for it .
I'll go by in a day or so and drop him off some $ if I see progress , I assume there will be .
QUESTION : many of the I6 powered trucks I see , have the inner upper lip of the right hand frame rail , right in front of the passenger side motor mount , cracked and bent up a little bit ~ what's the deal with this ? I am having him heat it , massage flat and butt weld it from underneath as I don't like cracks in anything , they tend to creep with the way I drive .
Please run out to your truck or that nasty old frame in the weeds and take a look see , report back here .
TIA ,
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 10-30-2014, 02:29 PM   #1280
texjake
texjake's Avatar
Re: Prophylactic Measure
Originally Posted by VWNate1 View Post
This is a very good idea and should be done to all our trucks , the collected leaves rusted out and destroyed my other wise perfect low mileage , good original paint cab .
-Nate
I agree. I installed the cowl screen because I just completed the interior and got tired of all the trash coming thru the vents & I was vaccumming up leaves on my new carpet everyday. lol
"Now all I need is a shop to go with my shop vac!"
texjake is offline
Old 10-30-2014, 02:46 PM   #1281
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
Well ;
Back when this truck was new and I was lucky to drive / ride in post WWII vehicles, part & parcel of Spring was to take a spirited ride with those " crotch cooler " A Pillar vents wide open and get leaves and dust into your eyes and mouth , then you'd clean out the cab (trucks) or interior (cars) and be able to use those wonderful vents all Spring and Summer long.....
Times have changed for most but not for a few of us Geezers ~ I unload the entire cab before that ride so I don't get all the other crap I carry , full of leaves .
Maybe I'll have my painter add some screen , is brass screen still available ? .
I am *VERY* excited to be thinking of having my truck back by New year's maybe .
-Nate
Geezer
VWNate1 is offline
Old 10-30-2014, 02:57 PM   #1282
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
On a stock heater.AC combo, I'm all for the anti-leaf screen.
Running VA, I don't use the kick panel vents. So we (Lee The Painter *actually* did it) used sheet metal to seal these up.
Except for the holes for the window washers, it's pretty water tight...Let alone, a good way to keep out the leaves.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 10-30-2014, 05:12 PM   #1283
ChevyLar
What an awesome idea for a thread ... Just commenting so I can check back on this later & get some inspiration after not putting in any work for a while!
ChevyLar is offline
Old 10-30-2014, 07:54 PM   #1284
brian1971
brian1971's Avatar
My new mufflers showed up today.
KOOKS Quad Core Stainless
They look really nice.
1971 c10 custom deluxe fleetside swb
LS3 w/BTR stage IV cam,4L85E w/3600 stall
67-72chevytrucks.com/vboard/showthread.php?t=558024
brian1971 is offline
Old 10-30-2014, 08:53 PM   #1285
sgt1022
Replaced broken transmission mount
sgt1022 is offline
Old 10-31-2014, 12:45 AM   #1286
Wildcard
got my New 10 1/2 Ubolts in yesterday, going to make drop blocks this weekend
Wildcard
Wildcard is offline
Old 10-31-2014, 04:03 PM   #1287
CST10
CST10's Avatar
Installed the new carb, adjusted it, changed the passenger Side window regulator. The made a trip to the scap yard with the ol truck to sell some old scrap metal. Not a bad day.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 11-01-2014, 05:22 PM   #1288
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today? Chapter II
Got rear disc brakes on the 71 now! They match the fronts almost!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 11-01-2014, 06:33 PM   #1289
72peace
72peace's Avatar
Baby got a new set of 16" Cragar s/s now i need some taller tires.
Cheers,
72peace is offline
Old 11-01-2014, 06:56 PM   #1290
Elliot949
Elliot949's Avatar
Cheers,
Nah bring the truck down to the tires... LOL
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline
Old 11-01-2014, 07:00 PM   #1291
BugzC10
BugzC10's Avatar
[QUOTE=Andy4639;6900102]Got rear disc brakes on the 71 now! They match the fronts almost!]
Looks great....Who's kit did you go with?
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 11-01-2014, 08:34 PM   #1292
Andy4639
Old member
Andy4639's Avatar
[quote=BugzC10;6900215]
I used the CPP kit! I want recommend it though! It's lacking a lot but over all it's all there. The kit lacks instructions for details that you just have to figure out your self. Like the spacers. I ended up not using either one of them. had to add washers to the drivers side and nothing on the passenger side. Brackets to hold brake lines were wrong size. T bolts aren't grade 8 that hold the bracket's on. Calipers are a ***** to get to grab and adjust.
I spent 20hrs the last 2 whole days to get them installed.
Here is a link with more about the install.
http://67-72chevytrucks.com/vboard/s...d.php?t=647684
Andy4639 is offline
Old 11-01-2014, 08:47 PM   #1293
CST10
CST10's Avatar
I changed out my leaking heater core and replaced the blower motor while I was at it.
MyToys:
CST10 is offline
Old 11-01-2014, 09:11 PM   #1294
texasld
texasld's Avatar
I have become fronds with a local powder coater here recently. I asked if I could use his blast booth to blast my cab. I was happy to give him some cash. He refused to take the cash, so I brought him some liquid refresents.
Here are some pictures of it before it went in. I forgot to snap some pictures of the finished product.
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)
2015 GMC 2500 Duramax (Daily Driver)
1999 Jeep TJ
2010 Harley Street Glide
Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981
texasld is offline
Old 11-01-2014, 11:38 PM   #1295
Wildcard
X2 Nice lookin truck will look good lowered down.
Wildcard
Wildcard is offline
Old 11-03-2014, 12:44 AM   #1296
Wildcard
Made me a set of Rear Drop Blocks today, I made four 1inch blocks so I can to 1 or 2 inch option over and above the already installed Jeep TJ rear springs.
made the blocks 7inchs long and 4 1/4inchs ctc on the holes. Ubolts are 3/4 thread I had a one size bigger 13/16 cause that's the only big drill bit I had kept the bit lubed with PB blaster on the drill press and drilled smoothly.
Here are all my parts ready to go in maybe this week or next weekend.
Wildcard is offline
Old 11-03-2014, 08:40 AM   #1297
jethro5333
got the c-notches in and the 5" drop springs in. gonna back it out and power wash the frame and get ready for some paint. any recommendations on frame paint?
jethro5333 is offline
Old 11-03-2014, 08:36 PM   #1298
texas67chevy
texas67chevy's Avatar
Got rid of these ugly humps on the radiator support, ran out of co2 for the welder so couldn't finish. Also sanded on the firewall a little bit.
texas67chevy is offline
Old 11-03-2014, 09:48 PM   #1299
BrianG
BrianG's Avatar
Brought it home...
BrianG is offline
Old 11-03-2014, 09:59 PM   #1300
KMC3420
KMC3420's Avatar
I turned the psi way down on my sandblaster and blasted a spare fender just to see how it would do. Surprisingly it worked very well. No warping. Psi was about 50. Took longer than usual but I am happy with the results. I kept the media flowing almost parrarel to the panel, barely touching the panel. I am confident I can blast most of my panels this way.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline
Closed Thread
