10-26-2014, 10:20 AM | #1 |
Old member
Rear end disc
Does anyone have a good step by step for doing a rear end disc swap on a GM 12 bolt truck rear end? I bought the kit from CPP and want to try and get installed next week if possible. It says they have the best instruction with the kit but would like to read over some to see what I need for this.
10-26-2014, 11:12 AM | #2 |
Re: Rear end disc
Is that a bolt-on kit or welding required?
Come on down to GA, we get you squared away - then you can meet DD
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
10-26-2014, 08:27 PM | #3 | |
Old member
Re: Rear end disc
I'm hoping the kit is here tomorrow.
10-27-2014, 09:10 AM | #4 |
Re: Rear end disc
did you download theirs off the website?
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
10-27-2014, 01:34 PM | #5 |
Old member
Re: Rear end disc
Dave I did, would like a little better understanding of how to get the c clips out of the gear. I think I can do it but a little more info would be nice.
Here is the kit. I upgraded to slotted and drilled rotors + the S/S brake lines instead of rubber ones..
10-27-2014, 01:53 PM | #6 |
Re: Rear end disc
Getting the rear axle c clips out so you can slide out the axles I assume??
If so it's pretty easy. Remove rear diff cover Find and remove small bolt holding in center carrier pin Slide out carrier pin Push axles into center of diff allowing c clips to become "free" Use a long magnet and/or pic to pull clips off axles Slide out axles |
10-27-2014, 02:23 PM | #7 |
Re: Rear end disc
Good looking kit. Did you get the right master cylinder and proportioning valve from them also? Do they have a kit for that?
Jimy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
10-27-2014, 03:28 PM | #8 |
Re: Rear end disc
That is going to be nice Andy. Like Ryan said above the c clips come out real easy.
I think when you get in there you will see what he means. The only real tool needed is to remove that small bolt. Also the gears and center section all stay put. I think I read somewhere you might change gears, that is a whole different project none of that will come loose just the axles slide out. I know you just replaced some of your brake master cylinder and booster stuff but I believe you will need a different prop valve and probably a dual disk master like Jimmy was asking.
10-27-2014, 04:31 PM | #9 |
Old member
Re: Rear end disc
RRR18,
Thanks for the info man that is what I was wanting to know. I should be able to do this in the garage with no problems. I'm not 100% on the gear swap yet Dave. I want to do new bearings and seals though for sure. Yes when I upgraded I got a new prop valve as well. The kit was $689.00 after all the upgrades.
10-27-2014, 07:14 PM | #10 |
Old member
Re: Rear end disc
Heading to work tonight my neighbor was outside so we started talking. He has offered his lift to me to do the brake swap. I will be taking my truck over there Friday and starting on taking it a part. He said as long as I was done by the following weekend I could leave it and work a little each day on it. I like that and it's a brand new shop he has built.
10-29-2014, 11:09 PM | #11 |
Old member
Re: Rear end disc
The kit showed up today so I set to start Friday. Will post pictures as I go I hope. Going to try and have my daughter with me to do the pictures as I do the work. The kit looks nice. Going to put the first coat of red on the calipers tomorrow!
10-31-2014, 07:36 PM | #12 |
Old member
Re: Rear end disc
Well I spent 10 hrs on the rear end today and I still have no brakes.
CPP's kit leaves a lot to be desired. No instructions as far as details, they have a sequence but no details. The spacers they have in the kit may are may not have to be used. Drivers side looks tight to me but they are on with spacers passenger side wouldn't go on at all so I called CPP and the answer was if they don't work don't use them! Nothing is mentioned in the instructions about not using them. I took them back off and it fit right up. The rotors are tight but I can spin them by hand and that's all they say. I'm hoping after driving it a little they will loosen up some after the pads are worn in. I may take the drivers side off again and use some shims instead of the spacer. Looking on the drivers side the caliper is up against the bracket, on the passenger side it has a 1/4" gap. The rear hard lines are for a Chevelle are Camaro they wouldn't fit my tee connection. Had to go get the fittings to adapt over to the bigger fitting. Called about that too! They said they sent the most popular size which is for a car not a truck. If you order this kit make sure you tell them you want the bigger fittings.
10-31-2014, 07:46 PM | #13 |
Old member
Re: Rear end disc
Here are some other pictures of the install.
Info on rotor: 1" thick and 11.5" diameter. Taking the axles out was a piece of cake! Getting them back together was a real experience! The spider gears decided to fall out so I spent over a hr getting them back in and timed correctly. I learned something though so it wasn't all bad. The c-clips will only go back in the groove one way also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 10-31-2014 at 09:14 PM. |
11-01-2014, 11:32 AM | #14 |
Old member
Re: Rear end disc
Took the drivers side back off this morning and took the spacer off and put 3 washers on each t bolt to space it out. It was a perfect fit. I will take the spacer and have it shaved down to the same measurement and replace it next time it needs brakes are I feel like doing it again.
The holder for the brake lines wasn't big enough for the S/S flex hose to go through so I had to file it open some for them to fit. Hope by tonight I have brakes again. Old picture
11-01-2014, 05:18 PM | #15 |
Old member
Re: Rear end disc
I have rear disc brakes on the truck. They still need some more bleeding I think though. I drove it home and had to tighten up on the pop valve some it was leaking. I guess I need to bleed them all again. The CPP kit would not be my choice again if I ever do another one that's for sure. The clips that hold the brake lines on the axle didn't even fit the hose fittings
11-01-2014, 09:53 PM | #16 |
Re: Rear end disc
wilwood kits seem to be nice and complete and also I believe are the only ones with the integrated parking brake.
Don't sweat the petty things and don't pet the sweaty things. |
11-02-2014, 10:40 AM | #17 | |
Old member
Re: Rear end disc
These kits have the parking brake also just that they are a real pain to adjust. I'm going to try and adjust them some more today if I get time.
11-03-2014, 03:07 PM | #18 |
Re: Rear end disc
Andy, they look great on there. I hope they perform as well as they look. Most "kits" need tweaking, as you found out, but we always learn something in the process. Thanks for sharing!!
"Its never too late to have a happy childhood." 70 Roadrunner,.. 79 Blazer, ..85 Harley bobber,.. 97 GMC Suburban Diesel,.. 99 Sierra, ..06 Ducati Monster Dark, ..07 Silverado ,.. 11 Audi A4 |
11-03-2014, 08:22 PM | #19 |
Old member
Re: Rear end disc
The kit over all is OK not great but OK. The details are what I hate. I need to do some more bleeding I think. Driving it to work tonight the brake light on the dash would come on so I think I need to bleed the system some more and the pedal isn't that good either. I need to adjust the parking brake cable some more to.
11-04-2014, 07:00 PM | #21 | |
Old member
Re: Rear end disc
The brakes need to be bleed again as well as she never once said the pedal went to the floor while bleeding them. The tires wouldn't spin though while I was bleeding so I figure I have more to do.
11-12-2014, 10:09 AM | #22 |
Re: Rear end disc
Andy, did you get the bugs all worked out of this? How is it stopping now?
11-13-2014, 02:52 PM | #23 |
Old member
Re: Rear end disc
Hey Dave,
yea I think I finally got them all bleed out and adjusted. I ended up having to take the drivers side back off and adjusting the e brake again but I think I have it. I drove it last night to work and it seems to stop pretty good. I can't tell a big difference in normal stopping but if I really mash the pedal it will stop darn quick.
