Old 09-20-2012, 03:23 PM   #1401
Frizzle Fry
Frizzle Fry's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Oil Pressure gauge complete. Wired it up to the sender to set zero before buttoning it up:
Frizzle Fry is offline   Reply With Quote
Old 09-20-2012, 03:52 PM   #1402
hgs_notes
GEARHEAD
hgs_notes's Avatar
Slick!
hgs_notes is offline   Reply With Quote
Old 09-20-2012, 07:32 PM   #1403
Frizzle Fry
ECU Wiring:
Old 09-20-2012, 07:42 PM   #1404
mcbassin
Still Learning
mcbassin's Avatar
Awesome work frizzle!
mcbassin is offline   Reply With Quote
Old 09-20-2012, 09:07 PM   #1405
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Originally Posted by Frizzle Fry View Post
Cap with what? Welded caps? I do have a spool for welding Al. Just need to pick up a 2nd tank...
You don't need to weld it. Just make sure the tube is full and make sure you have something on there to keep the sand from getting out.
I like how you mark each terminal. Good idea.
Zoomin is offline   Reply With Quote
Old 09-20-2012, 10:15 PM   #1406
Frizzle Fry
Cool, I'll try the sand if I kink another one.
Old 09-21-2012, 02:03 AM   #1407
Mal
We used bungs, tape them on as well. It was important that there was no air so you need to tap away at it as you fill with sand to condense the sand.
I still have some bits that were bent this way, I will take some pic's and post them up tomorrow.
Keep up the good work. I would love to get another SV and stick a 3.8l V6 Ecotec engine in it.
Cheers Mal
Mal is offline   Reply With Quote
Old 09-21-2012, 03:38 AM   #1408
Frizzle Fry
Cheers Mal
I looked at the V6 options long and hard. There are some great options out there. Thanks for the tips!
Old 09-21-2012, 05:54 AM   #1409
Pop's C-10
Pop's C-10's Avatar
You're a wiring master..*bows
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 09-21-2012, 11:43 AM   #1410
jeff967
duct tape works fine
jeff967 is offline   Reply With Quote
Old 09-22-2012, 04:11 PM   #1411
ERASER5
ERASER5's Avatar
Duct tape ALWAYS works!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 09-23-2012, 12:18 AM   #1412
Mal
Sorry Frizzel, I could not find what I thought I had. So no pic.
Old 09-24-2012, 12:47 PM   #1413
69gmcc10
69gmcc10's Avatar
This build never disappoints! Your level of ingenuity is astonishingly awesome!
"Simply en fuego!"
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 09-24-2012, 01:44 PM   #1414
thor
thor's Avatar
Just getting caught up on the build for this past week. I love how you stabbed some new guts into the old cluster for the oil pressure gauge. And the OCD side of me likes that you labelled all the wiring for the ECU; now I can sleep well at night.
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 09-26-2012, 02:16 PM   #1415
Frizzle Fry
Thanks. You should see some of the stuff I do at work! But I can't show it... :/
No problem. I'm headed out there now. We'll see how it goes!
"Simply en fuego!"
You can say that after it all works as designed
I know when I come back to it a week/month/year later the labels will be appreciated!
Old 09-27-2012, 01:08 PM   #1416
Frizzle Fry
Sand+Thicker-Walls+Annealed-all-at-once+Taking-my-time=
Pics of the process to come...
Old 09-27-2012, 01:39 PM   #1417
ksucatz
Suppose to be workin........
ksucatz's Avatar
As usual, very nice!!!
Brent
'68 C10
'70 C10
'72 LeMans
"03 Trailblazer
"Stupidity is like a skill, some are born with it and some develop it over a period of time."" Author unknown
ksucatz is offline   Reply With Quote
Old 09-28-2012, 12:47 PM   #1418
jeff967
duct tape?
Old 09-28-2012, 02:35 PM   #1419
Frizzle Fry
I annealed the whole stick in one go this time. Went until the soap turned meduim-to-dark brown, not black like the last one:
Filled with used 60/80 garnet from bly blasting cabinet:
Tapped it on the floor and on the side with a rubber coated hammer handle to settle/pack it in. This was the 2nd iteration of that. First time it went down to maybe 3/8" from heaping (was capped on top too).
Into the bender. Plenty of lithium grease on the tube and followers! I went VERY slowly with it this time, which is easy to do with the hydraulic conversion. Just let it pump about a piston cycle/second.
Took about 15min to go 90* You can see the rubber caps I used. I have a bin of assorted sizes. I keep them whenever we get new parts/equipment at work.
Two bends, no kinks! The outer radius is even better (no flatness) than the previous "good" bend.
Next I mod'ed the bead tool a little more to prevent indentations on the OD:
Worked like a champ:
...and the end result (already shown)
Back to the shop!
Old 09-28-2012, 03:06 PM   #1420
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
I have and continue to be amazed...
screamin_c10 is offline   Reply With Quote
Old 09-29-2012, 05:16 AM   #1421
watahyahknow
watahyahknow's Avatar
would be a nice way to make a huge diameter exaust system on turbocars as whell usually the turn right after the turbine needs to be tight due to the space behind it
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 09-29-2012, 12:40 PM   #1422
mcbassin
Still Learning
mcbassin's Avatar
Super write up and work on the tubing! Always learning here.
Old 10-01-2012, 03:23 PM   #1423
Frizzle Fry
Thanks guys. I'm learning as I go here too!
Old 10-03-2012, 02:49 AM   #1424
nuke1
nuke1's Avatar
Very nicely done good sir! I like your style and techniques. the annealing and sand trick worked great. Those pedals in you car sure look familiear. I believe I put a set of those in the "back burner" camaro I did. hehe.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 10-04-2012, 05:55 AM   #1425
76C10Stepside
76C10Stepside's Avatar
Great stuff as usual, FF! I need to send my kid a link to your thread. He's struggling with his first car restoration and needs inspiration, and some perspective on just how easy his project is compared to some of the crazy stuff going on out there!
76C10Stepside is offline   Reply With Quote
